I get a crash when running any optix SDK programs on my Gigabyte P57 laptop running Ubuntu 16.04.3 LTS. For instance:
/data/Code/build_optix_sdk/bin$ ./optixHello
pure virtual method called
terminate called without an active exception
Aborted (core dumped)
Running inside gdb results in this stack trace:
#0 0x00007ffff4f71428 in __GI_raise (sig=sig@entry=6) at …/sysdeps/unix/sysv/linux/raise.c:54
#1 0x00007ffff4f7302a in __GI_abort () at abort.c:89
#2 0x00007ffff6ac88e7 in ?? () from /data/Code/NVIDIA-OptiX-SDK-4.1.1-linux64/lib64/liboptix.so.1
#3 0x00007ffff6abea9a in ?? () from /data/Code/NVIDIA-OptiX-SDK-4.1.1-linux64/lib64/liboptix.so.1
#4 0x00007ffff6abeac2 in ?? () from /data/Code/NVIDIA-OptiX-SDK-4.1.1-linux64/lib64/liboptix.so.1
#5 0x00007ffff6ac9792 in ?? () from /data/Code/NVIDIA-OptiX-SDK-4.1.1-linux64/lib64/liboptix.so.1
#6 0x00007ffff5f1492b in ?? () from /data/Code/NVIDIA-OptiX-SDK-4.1.1-linux64/lib64/liboptix.so.1
#7 0x00007ffff5f14f67 in ?? () from /data/Code/NVIDIA-OptiX-SDK-4.1.1-linux64/lib64/liboptix.so.1
#8 0x00007ffff5f13e4a in ?? () from /data/Code/NVIDIA-OptiX-SDK-4.1.1-linux64/lib64/liboptix.so.1
#9 0x00007ffff5ebf932 in ?? () from /data/Code/NVIDIA-OptiX-SDK-4.1.1-linux64/lib64/liboptix.so.1
#10 0x00007ffff5a87d7f in ?? () from /data/Code/NVIDIA-OptiX-SDK-4.1.1-linux64/lib64/liboptix.so.1
#11 0x00007ffff5a92b43 in ?? () from /data/Code/NVIDIA-OptiX-SDK-4.1.1-linux64/lib64/liboptix.so.1
#12 0x00007ffff5a19ba1 in ?? () from /data/Code/NVIDIA-OptiX-SDK-4.1.1-linux64/lib64/liboptix.so.1
#13 0x00007ffff59be676 in rtBufferCreate () from /data/Code/NVIDIA-OptiX-SDK-4.1.1-linux64/lib64/liboptix.so.1
#14 0x0000000000405f76 in main (argc=1, argv=0x7fffffffde18) at /data/Code/NVIDIA-OptiX-SDK-4.1.1-linux64/SDK/optixHello/optixHello.cpp:93
Line 93 of optixHello.cpp is:
RT_CHECK_ERROR( rtBufferCreate( context, RT_BUFFER_OUTPUT, &buffer ) );
so the function rtBufferCreate() is crashing.
My driver version is 384.90. I set LD_LIBRARY_PATH="/usr/lib/nvidia-384". The output of optixDeviceQuery is:
OptiX 4.1.1
Number of Devices = 1
Device 0: GeForce GTX 1060
Compute Support: 6 1
Total Memory: 6367739904 bytes
Clock Rate: 1670500 kilohertz
Max. Threads per Block: 1024
SM Count: 10
Execution Timeout Enabled: 1
Max. HW Texture Count: 1048576
TCC driver enabled: 0
CUDA Device Ordinal: 0
Constructing a context…
Created with 1 device(s)
Supports 2147483647 simultaneous textures
Free memory:
Device 0: 5889589248 bytes
ldd returns; /data/Code/build_optix_sdk/bin$ ldd ./optixHello
linux-vdso.so.1 => (0x00007ffd1ac50000)
libsutil_sdk.so => /data/Code/build_optix_sdk/lib/libsutil_sdk.so (0x00007f6172528000)
liboptix.so.1 => /data/Code/NVIDIA-OptiX-SDK-4.1.1-linux64/lib64/liboptix.so.1 (0x00007f61702c9000)
libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f616ff47000)
libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f616fd31000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f616f967000)
libglut.so.3 => /usr/lib/x86_64-linux-gnu/libglut.so.3 (0x00007f616f71f000)
libGLU.so.1 => /usr/lib/x86_64-linux-gnu/libGLU.so.1 (0x00007f616f4b0000)
libGL.so.1 => /usr/lib/nvidia-384/libGL.so.1 (0x00007f616f20c000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f616ef03000)
libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f616ece6000)
libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f616eae2000)
/lib64/ld-linux-x86-64.so.2 (0x00007f6172802000)
libX11.so.6 => /usr/lib/x86_64-linux-gnu/libX11.so.6 (0x00007f616e7a8000)
libXi.so.6 => /usr/lib/x86_64-linux-gnu/libXi.so.6 (0x00007f616e598000)
libXxf86vm.so.1 => /usr/lib/x86_64-linux-gnu/libXxf86vm.so.1 (0x00007f616e392000)
libGLX.so.0 => /usr/lib/nvidia-384/libGLX.so.0 (0x00007f616e162000)
libGLdispatch.so.0 => /usr/lib/nvidia-384/libGLdispatch.so.0 (0x00007f616de94000)
libxcb.so.1 => /usr/lib/x86_64-linux-gnu/libxcb.so.1 (0x00007f616dc72000)
libXext.so.6 => /usr/lib/x86_64-linux-gnu/libXext.so.6 (0x00007f616da60000)
libXau.so.6 => /usr/lib/x86_64-linux-gnu/libXau.so.6 (0x00007f616d85c000)
libXdmcp.so.6 => /usr/lib/x86_64-linux-gnu/libXdmcp.so.6 (0x00007f616d656000)
Does anyone have an idea what is wrong, or a way to diagnose the problem?
