Isaac Sim Version
5.0.0
Operating System
Windows 11
GPU Information
- Model: NVIDIA GeForce RTX 5060 Laptop GPU
- Driver Version: 572.96
Topic Description
Detailed Description
Steps to Reproduce
(Add more steps as needed)
Error Messages
[crash] Crash detected in pid 23512 thread 20492
[crash] Note: some long metadata and file name values below may be truncated. The
[crash] full values of each piece of metadata and each full file name can still
[crash] be found in the file ‘c:/users/songy/appdata/local/programs/python/python311/lib/site-packages/omni/data/Kit/Isaac-Sim/5.0\b5aa8b92-23e8-4ac3-a27e-4caa6ce715c9.dmp.toml’.
[crash] This file can be found in either the crash report’s ‘.dmp.zip’ file or
[crash] in the same directory as the crash report file(s):
[crash] ‘c:/users/songy/appdata/local/programs/python/python311/lib/site-packages/omni/data/Kit/Isaac-Sim/5.0’.
[crash]
[crash] Crash metadata:
[crash] BuildGitlabJobID = ‘182268560’
[crash] CarbSdkVersion = ‘206.4+release.9396.3c6f8191.gl’
[crash] CrashTime = ‘Mon Sep 15 23:16:45 2025 GMT’
[crash] DriverShaderCacheWrapper = ‘disabled’
[crash] DumpId = ‘b5aa8b92-23e8-4ac3-a27e-4caa6ce715c9’
[crash] LastUploadStatus = ‘200’
[crash] ProductName = ‘OmniverseKit’
[crash] PythonTracebackStatus = ‘‘py-spy.exe’ successfully wrote info to c:/users/songy/appdata/local/programs/python/python311/lib/site-packages/omni/data/Kit/Isaac-Sim/5.0/b5aa8b92-23e8-4ac3-a27e-4caa6ce715c9.py.txt’
[crash] RetryCount = ‘0’
[crash] StartupTime = ‘1757978129’
[crash] UploadSuccessful = ‘0’
[crash] UptimeSeconds = ‘76’
[crash] UserStory = ‘’
[crash] UserStoryStatus = ‘‘crashreport.gui.exe’ exited with code 2’
[crash] Version = ‘107.3.1+production.206797.8131b85d.gl’
[crash] aftermath_enabled = ‘1’
[crash] aftermath_flags = ‘3’
[crash] aftermath_status = ‘auto-enabled’
[crash] aftermath_version = ‘2024.1’
[crash] appName = ‘Isaac-Sim’
[crash] appState = ‘started’
[crash] appVersion = ‘5.0.0’
[crash] autoloadExts = ‘’
[crash] buildBranch = ‘production’
[crash] buildCi = ‘gl’
[crash] buildConfig = ‘release’
[crash] buildGitlabJobName = ‘kit-build-release-windows-x86_64’
[crash] buildGitlabJobStage = ‘kit-build’
[crash] buildGitlabPipelineID = ‘30713850’
[crash] buildHash = ‘8131b85d’
[crash] buildMajor = ‘107’
[crash] buildMinor = ‘3’
[crash] buildNumber = ‘206797’
[crash] buildPatch = ‘1’
[crash] buildVersion = ‘107.3.1’
[crash] carboniteFrameworkVersion = ‘206.4+release.9396.3c6f8191.gl’
[crash] carboniteSdkVersion = ‘206.4+release.9396.3c6f8191.gl’
[crash] commandLine = ‘python day3_1.1.grasp_object_statemachine.py’
[crash] cpuCoreLimited = ‘-1’
[crash] cpuId = ‘AMD64 Family 26 Model 96 Stepping 0’
[crash] cpuLogicalCoresBareMetal = ‘16’
[crash] cpuName = 'AMD Ryzen AI 7 350 w/ Radeon 860M ’
[crash] cpuPhysicalCoresBareMetal = ‘8’
[crash] cpuUsageQuota = ‘-1.000000’
[crash] cpuVendor = ‘AuthenticAMD’
[crash] desktopOrigin = ‘(0, 0)’
[crash] desktopSize = ‘2560x1600’
[crash] displayCount = ‘1’
[crash] displayRes_0 = ‘2560x1600x32bit@60Hz’
[crash] environmentName = ‘Individual’
[crash] externalBuild = ‘1’
[crash] extraExts = ‘omni.physx.fabric-107.3.18’
[crash] gpuDriver_0 = ‘572.96’
[crash] gpuDriver_1 = ‘0x800149’
[crash] gpuVRAM_0 = ‘8189378560’
[crash] gpuVRAM_1 = ‘783278080’
[crash] gpu_0 = ‘NVIDIA GeForce RTX 5060 Laptop GPU’
[crash] gpu_1 = ‘AMD Radeon™ Graphics’
[crash] kitRendererDriverVersion = ‘572.96’
[crash] lastCommand = ‘CreateAttrCommand(node=?,attr_name=state:sdp_intergraph_downstream_node_handles,attr_type=?,attr_port=?,attr_default=?,attr_extended_type=?)’
[crash] lastCommands = ‘CreatePreviewSurfaceMaterialPrim(mtl_path=/Visuals/FrameTransformer/connecting_line/geometry/material,select_new_prim=False),ChangePropertyCommand(prop_path=/Visuals/FrameTransformer/connecting_line/geometry/material/Shader.inputs:diffuseColor,value=?,prev=?,type_to_create_if_not_exist=?,usd_context_name=?),ChangePropertyCommand(prop_path=/Visuals/FrameTransformer/connecting_line/geometry/material/Shader.inputs:emissiveColor,value=?,prev=?,type_to_create_if_not_exist=?,usd_context_name=?),ChangePropertyCommand(prop_path=/Visuals/FrameTransformer/connecting_line/geometry/material/Shader.inputs:roughness,value=1.0,prev=?,type_to_create_if_not_exist=?,usd_context_name=?),ChangePropertyCommand(prop_path=/Visuals/FrameTransformer/connecting_line/geometry/material/Shader.inputs:metallic,value=0.0,prev=?,type_to_create_if_not_exist=?,usd_context_name=?),ChangePropertyCommand(prop_path=/Visuals/FrameTransformer/connecting_line/geometry/material/Shader.inputs:opacity,value=1.0,prev=?,type_to_create_if_not_exist=?,usd_context_name=?),BindMaterialCommand(prim_path=/Visuals/FrameTransformer/connecting_line/geometry/mesh,material_path=/Visuals/FrameTransformer/connecting_line/geometry/material,strength=strongerThanDescendants,stage=?),ChangePropertyCommand(prop_path=/Visuals/FrameTransformer/connecting_line/geometry/mesh.primvars:invisibleToSecondaryRays,value=True,prev=?,type_to_create_if_not_exist=?),CreateAttrCommand(node=?,attr_name=state:sdp_intergraph_downstream_node_handles,attr_type=?,attr_port=?,attr_default=?,attr_extended_type=?),CreateAttrCommand(node=?,attr_name=state:sdp_intergraph_downstream_node_handles,attr_type=?,attr_port=?,attr_default=?,attr_extended_type=?)’
[crash] lib_isaacSim_buildBranch = ‘HEAD’
[crash] lib_isaacSim_buildDate = ‘Thu Jul 31 02:50:55 2025 +0000’
[crash] lib_isaacSim_buildHash = ‘184afb1’
[crash] lib_isaacSim_buildRepo = ‘https://gitlab-ci-token:glcbt-64_asbgTSLk2yqLSS56tsUZ@gitlab-master.nvidia.com/omniverse/isaac/omni_isaac_sim.git’
[crash] lib_isaacSim_buildVersion = ‘5.0.0-rc.45’
[crash] lib_physx_buildBranch = ‘HEAD’
[crash] lib_physx_buildDate = ‘Jul-23-2025’
[crash] lib_physx_buildHash = ‘214216c’
[crash] lib_physx_buildRepo = ‘gitlab-master.nvidia.com/omniverse/physics’
[crash] lib_physx_buildVersion = ‘107.3.18’
[crash] memoryStats = ‘(avail/total) RAM: 12.8947/31.119GB, Swap: 16.8739/41.619GB, VM: 130937/131072GB’
[crash] nvidia-smi = ’
==============NVSMI LOG==============
Timestamp : Tue Sep 16 08:15:32 2025
Driver Version : 572.96
CUDA Version : 12.8
Attached GPUs : 1
GPU 00000000:64:00.0
Product Name : NVIDIA GeForce RTX 5060 Laptop GPU
Product Brand : GeForce
Product Architecture : Blackwell
Display Mode : Disabled
Display Active : Disabled
Persistence Mode : N/A
Addressing Mode : N/A
MIG Mode
Current : N/A
Pending : N/A
Accounting Mode : Disabled
Accounting Mode Buffer Size : 4000
Driver Model
Current : WDDM
Pending : WDDM
Serial Number : N/A
GPU UUID : GPU-a40209eb-66a2-1cb1-cf0f-c6588635637b
Minor Number : N/A
VBIOS Version : 98.06.2a.40.9a
MultiGPU Board : No
Board ID : 0x6400
Board Part Number : N/A
GPU Part Number : 2D19-750-A1
FRU Part Number : N/A
Platform Info
Chassis Serial Number :
Slot Number : 0
Tray Index : 0
Host ID : 1
Peer Type : Direct Connected
Module Id : 1
GPU Fabric GUID : 0x0
Inforom Version
Image Version : G005.0000.98.01
OEM Object : 2.1
ECC Object …’
[crash] osDistro = ‘24H2’
[crash] osName = ‘Windows 11 Pro’
[crash] osVersion = ‘10.00.26100’
[crash] portableMode = ‘1’
[crash] primaryDisplayRes = ‘2560x1600x32bit@60Hz’
[crash] runEnvironment = ‘Individual’
[crash] runningInContainer = ‘0’
[crash] shaderdb_debugSymbols = ‘0’
[crash] shaderdb_dumpIncludeOverrides = ‘0’
[crash] shaderdb_dumpIntermediates = ‘0’
[crash] shaderdb_obfuscateCode = ‘1’
[crash] shaderdb_optimizationLevel = ‘1’
[crash] systemInfo = ’
| Driver Version: 572.96 | Graphics API: Vulkan
| GPU | Name | Active | LDA | GPU Memory | Vendor-ID | LUID |
| | | | | | Device-ID | UUID |
| | | | | | Bus-ID | |
| 0 | NVIDIA GeForce RTX 5060 Laptop.. | Yes: 0 | | 7810 MB | 10de | 00610100.. |
| | | | | | 2d19 | a40209eb.. |
| | | | | | 64 | |
| 1 | AMD Radeon™ Graphics | | | 746 MB | 1002 | e73f0100.. |
| | | | | | 1114 | 00000000.. |
| | | | | | N/A | |
| OS: Windows 11 Pro, Version: 10.0 (24H2), Build: 26100, Kernel: 10.0.26100.6584
| Processor: AMD Ryzen AI 7 350 w/ Radeon 860M
| Cores: 8 | Logical Cores: 16
| Total Memory (MB): 31865 | Free Memory: 18735
| Total Page/Swap (MB): 42617 | Free Page/Swap: 26647
[crash] telemetrySessionId = ‘13070809411456024535’
[crash] terminatedByAbort = ‘0’
[crash] totalRamBareMetalMB = ‘31865’
[crash] totalRamLimitedMB = ‘31865’
[crash] totalSwapBareMetalMB = ‘42617’
[crash] totalSwapLimitedMB = ‘42617’
[crash] userId = ‘default’
[crash] workingDirectory = ‘D:\AI\AILab여름2025\AILAB-summer-school-2025-main\AILAB-summer-school-2025-main\day3’
[crash]
[crash] Crash files:
[crash] metadataFile = ‘c:/users/songy/appdata/local/programs/python/python311/lib/site-packages/omni/data/Kit/Isaac-Sim/5.0\b5aa8b92-23e8-4ac3-a27e-4caa6ce715c9.dmp.toml’
[crash] upload_file_minidump = ‘c:/users/songy/appdata/local/programs/python/python311/lib/site-packages/omni/data/Kit/Isaac-Sim/5.0\b5aa8b92-23e8-4ac3-a27e-4caa6ce715c9.dmp’
[crash] upload_file_traceback = ‘c:/users/songy/appdata/local/programs/python/python311/lib/site-packages/omni/data/Kit/Isaac-Sim/5.0/b5aa8b92-23e8-4ac3-a27e-4caa6ce715c9.py.txt’
[crash]
[crash] Thread 20492 backtrace follows:
000: omni.syntheticdata.plugin.dll!+0x44513
001: omni.syntheticdata.plugin.dll!+0x46432
002: omni.graph.core.plugin.dll!omni::graph::core::debug::tokenAsString+0xb4b4
003: omni.graph.core.plugin.dll!omni::graph::core::debug::tokenAsString+0x1fa6e
004: omni.graph.core.plugin.dll!omni::graph::core::debug::tokenAsString+0x5c44
005: omni.graph.core.plugin.dll!omni::graph::core::debug::tokenAsString+0x71f4
006: omni.graph.core.plugin.dll!omni::graph::core::debug::tokenAsString+0x46b6c
007: omni.graph.core.plugin.dll!omni::graph::core::debug::tokenAsString+0x474e4
008: omni.graph.core.plugin.dll!omni::graph::core::debug::tokenAsString+0x1fad0
009: omni.graph.core.plugin.dll!omni::graph::core::debug::tokenAsString+0x5c44
010: omni.graph.core.plugin.dll!omni::graph::core::debug::tokenAsString+0x71f4
011: omni.graph.core.plugin.dll!omni::graph::core::debug::tokenAsString+0x78202
012: omni.graph.core.plugin.dll!carbOnPluginShutdown+0x12d
013: carb.dll!carbReallocate+0xa68a
014: carb.dll!releaseFrameworkAndTerminate+0x1d922
015: carb.dll!omniReleaseStructuredLog+0x7018
016: carb.dll!releaseFrameworkAndTerminate+0x1e5e9
017: carb.scripting-python.plugin.dll!+0x1c366
018: carb.scripting-python.plugin.dll!+0x135d
019: carb.scripting-python.plugin.dll!+0xfd3b
020: python311.dll!PyArg_Parse_SizeT+0x86
021: python311.dll!PyObject_Call+0xac
022: python311.dll!PyIndex_Check+0x2c7
023: python311.dll!Py_FinalizeEx+0x4f
024: python311.dll!Py_RunMain+0x1a
025: python311.dll!Py_Main+0x25
026: python.exe!+0x1230
027: KERNEL32.DLL!BaseThreadInitThunk+0x17
028: ntdll.dll!RtlUserThreadStart+0x2c
Screenshots or Videos
(If applicable, add screenshots or links to videos that demonstrate the issue)
Additional Information
What I’ve Tried
(Describe any troubleshooting steps you’ve already taken)
Related Issues
(If you’re aware of any related issues or forum posts, please link them here)
Additional Context
(Add any other context about the problem here)
