Create 2022.1.0, Iray, and Omniverse Drive, causing system Lockups
A few times it has locked Windows Explorer requiring a taskkill and last night it prevented machine from restarting without a hard reboot. So far it has been random and after doing multiple Capture Current Frames in the Movie Capture Window.
Scene is not very complex:
Total visible lights: 1
Total visible mesh instances: 75
Total visible triangles for all mesh instances: 34,998
Total visible vertices for all mesh instances: 38,123
Hardware:
Nvidia Geforce RTX 3060
Driver: 511.65
Working locally and remote through RDP with nvidiaopenglrdp
Any thoughts would be greatly appreciated.
Not sure if it is related, but if I open a blank Create, switch to iray, set to 64 samples, and try to do back to back renders the second one never progresses pass 0/64. Below is the log from console.
2022-03-30 20:06:10 [Info] [omni.kit.window.movie_capture.ui_values_interface] Movie capture: no UI settings found for anon:000001F5D95D9370:World0.usd
2022-03-30 20:06:14 [Info] [omni.kit.window.movie_capture.ui.farm_status_widget] Unable to connect to Omniverse Queue at “http://localhost:8222”: Cannot connect to host localhost:8222 ssl:default [The remote computer refused the network connection]
2022-03-30 20:06:22 [Warning] [omni.kit.window.movie_capture.capture_settings_widget] movie type changed to Sequence
2022-03-30 20:06:22 [Info] [omni.kit.window.viewport.plugin] AOV HdrColor is not in viewport window
2022-03-30 20:06:22 [Info] [omni.usd] [UsdContext] Set active Hydra engine ‘iray’
2022-03-30 20:06:22 [Info] [omni.usd] [UsdContext] Checking engine ‘iray’
2022-03-30 20:06:22 [Info] [omni.usd] [UsdContext] Set in context ‘iray’
2022-03-30 20:06:22 [Info] [omni.kit.capture.viewport.extension] Switching to IRay Mode
2022-03-30 20:06:22 [Info] [omni.physx.plugin] Physics USD: Physics scene not found. A temporary default PhysicsScene prim was added automatically!
2022-03-30 20:06:22 [Info] [carb] Plugin omni.hydra.scene_delegate.plugin already has a dependency relationship on omni.stageupdate.plugin; not changing unload order
2022-03-30 20:06:22 [Warning] [omni.usd] Hydra engine iray transitioning from async (/app/runLoops/rendering_0) to synchronous rendering
2022-03-30 20:06:22 [Warning] [omni.usd] Hydra engine “iray” does not support remote rendering.
2022-03-30 20:06:22 [Info] [carb] Plugin omni.usd-abi.plugin already has a dependency relationship on carb.scenerenderer-iray.plugin; not changing unload order
2022-03-30 20:06:24 [Info] [omni.kit.capture.viewport.extension] Capturing C:/Users//Documents/Kit/shared/capture\Capture2.png
2022-03-30 20:06:24 [Info] [omni.usd] [UsdContext] Set active Hydra engine ‘rtx’
2022-03-30 20:06:24 [Info] [omni.usd] [UsdContext] Checking engine ‘iray’
2022-03-30 20:06:24 [Info] [omni.usd] [UsdContext] Checking engine ‘pxr’
2022-03-30 20:06:24 [Info] [omni.usd] [UsdContext] Checking engine ‘rtx’
2022-03-30 20:06:24 [Info] [omni.usd] [UsdContext] Set in context ‘rtx’
2022-03-30 20:06:24 [Info] [omni.kit.window.viewport.plugin] AOV HdrColor is not in viewport window
2022-03-30 20:06:24 [Info] [carb] Plugin omni.hydra.scene_delegate.plugin already has a dependency relationship on omni.stageupdate.plugin; not changing unload order
2022-03-30 20:06:24 [Info] [omni.usd] resetting the animation timeline
2022-03-30 20:06:24 [Info] [rtx.multigpumanager.plugin] View 0 assigned to device 0
2022-03-30 20:06:24 [Info] [rtx.multigpumanager.plugin] View 0 switching to 1x1 layout
2022-03-30 20:06:28 [Warning] [omni.kit.window.movie_capture.capture_settings_widget] movie type changed to Sequence
2022-03-30 20:06:28 [Info] [omni.kit.window.viewport.plugin] AOV HdrColor is not in viewport window
2022-03-30 20:06:28 [Info] [omni.usd] [UsdContext] Set active Hydra engine ‘iray’
2022-03-30 20:06:28 [Info] [omni.usd] [UsdContext] Checking engine ‘iray’
2022-03-30 20:06:28 [Info] [omni.usd] [UsdContext] Set in context ‘iray’
2022-03-30 20:06:28 [Info] [omni.kit.capture.viewport.extension] Switching to IRay Mode
2022-03-30 20:06:28 [Info] [omni.physx.plugin] Physics USD: Physics scene not found. A temporary default PhysicsScene prim was added automatically!
2022-03-30 20:06:28 [Info] [carb] Plugin omni.hydra.scene_delegate.plugin already has a dependency relationship on omni.stageupdate.plugin; not changing unload order
2022-03-30 20:06:28 [Info] [omni.usd] resetting the animation timeline
2022-03-30 20:06:28 [Warning] [omni.usd] Hydra engine iray transitioning from async (/app/runLoops/rendering_0) to synchronous rendering
2022-03-30 20:06:37 [Warning] [omni.kit.capture.viewport.extension] video recording cancelled
2022-03-30 20:06:37 [Info] [omni.usd] [UsdContext] Set active Hydra engine ‘rtx’
2022-03-30 20:06:37 [Info] [omni.usd] [UsdContext] Checking engine ‘iray’
2022-03-30 20:06:37 [Info] [omni.usd] [UsdContext] Checking engine ‘pxr’
2022-03-30 20:06:37 [Info] [omni.usd] [UsdContext] Checking engine ‘rtx’
2022-03-30 20:06:37 [Info] [omni.usd] [UsdContext] Set in context ‘rtx’
2022-03-30 20:06:37 [Info] [omni.kit.window.viewport.plugin] AOV HdrColor is not in viewport window
2022-03-30 20:06:37 [Info] [carb] Plugin omni.hydra.scene_delegate.plugin already has a dependency relationship on omni.stageupdate.plugin; not changing unload order
2022-03-30 20:06:37 [Info] [omni.usd] resetting the animation timeline
2022-03-30 20:06:37 [Info] [rtx.multigpumanager.plugin] View 0 assigned to device 0
2022-03-30 20:06:37 [Info] [rtx.multigpumanager.plugin] View 0 switching to 1x1 layout
Thanks @eric.craft.MH and sorry for these issues - we’re looking into it and will update here.
Cheers,
Edmar
P.S. The Omniverse documentation site has more info and links to all tutorial videos (under the “Learning and Feedback” category on left nav bar): Omniverse Platform Overview — Omniverse Developer documentation
he / him | LinkedIn | Discord ID: Prof E#2041
Omniverse: “A New Era of Collaboration and Simulation” (video)
Omniverse Create’s latest features show & tell: Twitch livestream.
As seen in VentureBeat | Physics Showcase
Omniverse Resources:
Omniverse | Documentation | Tech Requirements | Videos | Roadmap | Twitter | Discord | Twitch
PLEASE NOTE: If you are reporting a bug/issue, please provide OS, GPU, GPU Driver, the version of the app, and full log file (if applicable). For crashes, please zip and provide a link to your logs → C:\Users\ [YOUR NAME] \ .nvidia-omniverse\logs
No problems. Happy to run into it sooner rather than later. I sent you a link to the crash logs for some of the instances where the application had locked up and asked to close.
