Critical Error - "Not Enough Memory to Change Render Resolution" with Latest NVIDIA Drivers
Dear Chaos Group and NVIDIA Support,
I am experiencing a critical error when rendering in Chaos Vantage at 8K resolution using the latest NVIDIA drivers for my RTX 3090. The error message I receive is: “Critical error: Not enough memory to change render resolution.”
Interestingly, when I use an older driver version, I can render the 8K scene without any issues. However, with the latest drivers, I encounter this memory error, even though the GPU has 24GB of VRAM, which should be sufficient for 8K rendering. I using Chaos vantage version 2.6.2
I would appreciate your support in resolving this issue, as I need to update my drivers for gaming while also working with high-resolution renders in Chaos Vantage.
Thank you for your attention to this matter.
Please help me
