It said: Signal Requirement is
Max Intra-pair Skew 1 ps
Max Trace Delay Skew between DQ & CLK 5 ps
This number seems too strict in 2.5Gbps or 400ps UI world.
Are those right?
Are those right?
Yes, please follow design guide.
In MIPI D-PHY Dynamic Data to Clock Skew Window RX Tolerance is minimum 0.5UI. It will be 200ps at 2.5Gbps.
It requires maximum 5ps still?
This skew is for PCB, in fact there is other skew in chip. The total skews are following D-PHY request.
