Hi All,
NVCSI spec:
- Supports both D-PHY, v1.2 and C-PHY, v1.0
- MIPI CSI-2, v1.3, protocol stack
Our CSI-2 Tx Spec:
- D-PHY Specification, version 1.1
- MIPI CSI-2 standard, v1.1
Whether both are compatible or not? Any extra configuration is required between these devices?
-Thanks.
Suppose it’s backward compatible.
Need to confirm the compatible.
What are the points, we need to check for this.
-Thanks.
In link, Image Sensors World: MIPI Alliance Officially Releases C-PHY v1.0, D-PHY v1.2, and M-PHY v3.1 Specs
It is given as:
The updated MIPI D-PHY specification, v1.2, introduces lane-based data skew control in the receiver to achieve a peak transmission rate of 2.5 Gbps/lane or 10 Gbps over 4 lanes, compared to the v1.1 peak transmission rate of 1.5 Gbps/lane or 6 Gbps over 4 lanes.
It is mentioned that data rate is varying between two versions. So need to confirm the compatible between
two ends.
Please ask Nvcsi team regarding this.
-Thanks.
I believe that tell the max support for V1.2 is 2.5G and also support the speed below 2.5G
