What is the io standard for the MIPI signals {CSI0_D0+, CSI0_CLK+} in the CSI-2 RX. It is just mentioned MIPI D-PHY Pin type.
Could you respond at the earliest.
Thanks,
Thanks,
Hi, what’s the meaning of ‘io standard’? There are pin related info in OEM DG, pinmux sheet and module specification, did you check them first?
Every pin has signal type. Can i interconnect SLVS signals for CSI-2 RX to the data and clock signals? Yes, no where it is mentioned about the IO standard especially.
My question is what IO standard are the clock and data signals of MIPI CSI ?
MIPI D-PHY specification includes HS: SLVS-400, LP: LVCMOS-1.2V, please check the spec first.
For Nvcsi D-Phy, in which document I/o standard details are available.
Please provide the document name.
-Thanks.
As you can see in module datasheet, the standard that CSI following are MIPI D-PHY® v1.2 Physical Layer specification and MIPI CSI 2.0 Receiver specification .
