according to MIPI specification, 3-phase symbol encoding technology delivers approximately 2.28 bits-per-symbol.
hence, 2.28 bits/sym * 2.5 Gsym/s = 5.7 Gbps
also, according to Jetson AGX Xavier OEM Product Design Guide, for C-PHY, Xavier supports each lane (Trio) supports up to 2.5 Gsps.
the maximum data rate should be 5.715 (2.5x2.286) Gbps, which should be able to cover your request.
Please check comment #6 for correct CPHY data rate. thanks
For AGX Xavier, please check “1.4.1 MIPI Camera Serial Interface (CSI)” section of AGX Xavier datasheet.
Features:
• Supports both the MIPI D-PHY v1.2 and the MIPI C-PHY v1.1 physical layer options.
MIPI D-PHY supports up to 2.5 Gbits/sec per pair, for an aggregate bandwidth of 40 Gbps from 16 pairs
MIPI C-PHY supports up to[b] 1.7 G symbol/sec /b per trio
Hi, on Xavier, data rate of C-PHY is up to 1.7Gsym/s per trio. There is a doc issue of 2.5Gsysm/s per tiro supported in OEM DG which will be corrected. C-PHY is not supported on Jetson TX2 platform.
Hi Trumany,
According to Xavier TRM V1.3p which revised on 20191004.
In Table 7.7, Peak bandwidth in C-PHY is changed from 109 (3.0 x 2.28 x 4 x 4) to 91 (2.5 x 2.28 x 4 x 4). That means the original design of C-PHY is 3Gs/s and TRM V1.3p modify it to 2.5Gs/s.
Moreover, in Table 7.10 System Lvel Peak Bandwidth, there are 3 PHY mode on C-PHY depending on different NVCSI clock and lane clock.
Target VLV LV SV
BW/Trio 1.68 Gs/s 2.0 Gs/s 3.0 Gs/s
Totaol BW 61 Gbps 73 Gbps 109 Gps
Lane clock 240MHz 286 MHz 428.6 MHz
NVCSI clock 240MHz 314 MHz 428.6 MHz
I have two questions:
Looks like Xavier could only run VLV mode, what causes the limitation? NVCSI, VI or other issue?
NVCSI clock is adjustable and I can modify it but I can’t find where to set Lane clock. Coudl you show me how to set lane clock?
TRM is for chip level, some features are not implemented on Jetson platform for some reasons. Please take module datasheet and OEM DG as spec and so not try to set NVCSI clock manually.
