Hi everyone,
I’m working on Xavier, JetPack 4.4, L4T R32.4.3.
When I test D-PHY signal by using different lanes(1/2/3/4), only Lane 2 is work on V4l2.
The Device Tree just change 2 parameter:num_lanes and bus-width
Here’s my device tree which is D-PHYx1Lane
mode0 { // OV5693_MODE_2592X1944
mclk_khz = "37125";//?
num_lanes = "1";//?
tegra_sinterface = "serial_e";//?
phy_mode = "DPHY";//?
discontinuous_clk = "no";//?
dpcm_enable = "false";//?
cil_settletime = "0";//?
active_w = "4928";//
active_h = "5000";//
mode_type = "bayer";
pixel_phase = "rggb";//?
//dynamic_pixel_bit_depth = "12";
csi_pixel_bit_depth = "12";//The sensor readout pixel pattern
readout_orientation = "0";//
line_length = "5000";//
inherent_gain = "1";//
mclk_multiplier = "2";//
pix_clk_hz = "74250000";//
gain_factor = "10";
min_gain_val = "0";//
max_gain_val = "720";//
step_gain_val = "3";
default_gain = "0";
min_hdr_ratio = "1";//
max_hdr_ratio = "1";//
framerate_factor = "1000000";
min_framerate = "2000000";//
max_framerate = "30000000";//
step_framerate = "1";
default_framerate = "30000000";
exposure_factor = "1000000";
min_exp_time = "30";//
max_exp_time = "660000";//
step_exp_time = "1";
default_exp_time = "33334";
embedded_metadata_height = "0";//?
ports {
#address-cells = <1>;
#size-cells = <0>;
port@0 {
reg = <0>;
e3326_ov5693_out0: endpoint {
port-index = <4>;
bus-width = <1>;
remote-endpoint = <&e3326_csi_in0>;
Also, I use gst command double check that.
And gst can work!
Below is dmesg
[ 572.999420] t194-nvcsi 15a00000.nvcsi: csi5_mipi_cal,phy_mode = 0, csi5_fops.c
[ 572.999429] csi5_phy_write, csi5_fops.c:52
[ 573.050205] [RCE] vi5_hwinit: firmware CL2018101701 protocol version 2.2
[ 573.057146] t194-nvcsi 15a00000.nvcsi: csi5_stream_set_config: stream_id=4, csi_port=4,phy_mode = 0, csi5_fops.c:147
[ 573.057161] t194-nvcsi 15a00000.nvcsi: csi5_stream_open: stream_id=4, csi_port=4, csi5_fops.c:94
[ 575.573755] tegra194-vi5 15c10000.vi: no reply from camera processor
[ 575.573921] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[ 575.574073] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[ 575.575926] t194-nvcsi 15a00000.nvcsi: csi5_stream_set_config: stream_id=4, csi_port=4,phy_mode = 0, csi5_fops.c:147
[ 575.575938] t194-nvcsi 15a00000.nvcsi: csi5_stream_open: stream_id=4, csi_port=4, csi5_fops.c:94
[ 575.576178] tegra-capture-ivc ivc-bc00000.rtcpu:ivccontrol@3: No callback found for msg id: 0x37
[ 575.576386] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[ 578.389385] tegra194-vi5 15c10000.vi: no reply from camera processor
[ 578.389580] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[ 578.389722] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[ 578.392397] t194-nvcsi 15a00000.nvcsi: csi5_stream_set_config: stream_id=4, csi_port=4,phy_mode = 0, csi5_fops.c:147
[ 578.392409] t194-nvcsi 15a00000.nvcsi: csi5_stream_open: stream_id=4, csi_port=4, csi5_fops.c:94
[ 578.392744] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[ 581.460849] tegra194-vi5 15c10000.vi: no reply from camera processor
[ 581.461050] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[ 581.461204] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[ 581.463433] t194-nvcsi 15a00000.nvcsi: csi5_stream_set_config: stream_id=4, csi_port=4,phy_mode = 0, csi5_fops.c:147
[ 581.463445] t194-nvcsi 15a00000.nvcsi: csi5_stream_open: stream_id=4, csi_port=4, csi5_fops.c:94
[ 581.463774] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[ 584.276512] tegra194-vi5 15c10000.vi: no reply from camera processor
[ 584.276706] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[ 584.276866] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
