I’m trying to develope a camera module board for JETSON TX1.
On the Jetson TX1 OEM Product DG for MIPI CSI Routing Requirements, the parameter “Max Trace Length/Delay” has become a 1100ps.
However, MIPI CSI trace length of the camera module will exceed 1100ps.
If do not meet this, how far do it be acceptable?
Or, Is there a limit to the delay of the Inter Pair Skew (pair to pair)?
If the received signal quality passes the MIPI RX criteria, is it okay to over the Requirement of trace delay?
Also, is it possible to be received by LVDS with MIPI CSI port of TX1?
For example, Is it possible to receive the LVDS obtained by converting the MIPI signal in the MC20001 of meticom in TX1?
