Anout CSI D-PHY PCB trace allowances
We are designing the carrier board for AGX Orin. In the DG document, it is stated that for the MIPI CSI DPHY PCB trace, when the data rate is 2.5Gbps, the length should not exceed 80mm. May I ask whether this length is calculated starting from the AGX Orin module(699Pin) or from the CSI connector(120Pin Samtec)?
Please refer to section 6.4 Routing Guidelines in Jetson Download Center | NVIDIA Developer
