In the framework of a project, I want to integrate a NVIDIA Xavier developer kit carrier board as an interface to collect MIPI signal from a custom sensor. I have to use two CSI-2 lanes and a CSI-2 CLK at a bandwidth of 1.5 Gbps.
In the jetson Xavier Developer Kit carrier Board specification (pg 27), a maximum trace delay of 450.27 ps is advised for the sensor carrier board, which is equivalent to only a few cm of trace on our pcb.
Will it be possible to use a microcoax cable between the sensor carrier board and the camera interposer module ? I’ve seen applications that use such cables over dozens of centimeters. Considering the length of the cable way longer than the PCB trace, how can I ensure that a 1.5 Gbps MIPI transmission to the Jetson Xavier can be handled with no risk ?
What interface (cables, connector) would you advise for relatively long distances (up to 50 cm) between the sensor carrier board and the camera interposer module?
it’s a sensor module that use Serializer/Deserializer chips, please access L4T Sources to check reference drivers.
you may also check below drivers to demonstrate sensors with SerDes chips. $l4t-r32.2/public_sources/kernel/nvidia/drivers/media/i2c/imx390.c
$l4t-r32.2/public_sources/hardware/nvidia/platform/t19x/common/kernel-dts/t19x-common-modules/tegra194-camera-imx390-a00.dtsi
MIPI specifies that the flight time between two D-PHY interconnects should not exceed 2 ns, which is equivalent to around 25-30 cm for PCB/flex material trace length. However, referring to my previous post, the trace delay is only of 450.27 ps for PCB/flex material trace length. Why is this value significantly smaller than the MIPI requirements ?
