CSI0 is OK,CSI2 no stream
I use custom board and TX2 NX module. There are some NVP6188 AHD to MIPI chips. CSI0 is streaming ok, but CSI2 no stream output. This is pin usage , error information and device topology. I have no idea how to solve it. Thanks a lot.
The trace log show the SPURIOUS_DATA_STREAM.
Spurious data means VI sees some other packets before FS packet, as VI alwasy expect the 1st packet to be frame start
kworker/5:0-14741 [005] ....  8061.308172: rtcpu_vinotify_event: tstamp:252153540554 tag:CSIMUX_STREAM channel:0xff frame:16 vi_tstamp:252153540028 data:0x00000100
What may be causing this? Is my device topology binding right? CSI A → CSI0 ->port index 0 bandwidth 2. CSI C ->CSI 2 ->port index 2 bandwidth. CSI1 not used.
I solve it , MIPI signal has some problem, I fix the AD driver. Thank you.
