Hi!
I am trying to run an experiment with 2 VMs running CUDA applivations on the same GPU. From the licensing guide I found out that I need QUADRO vDWS to run CUDA applications, but it also says that for Maxwell applications it only supports 8GB 1:1 profile. What exactly does this mean? Will I be able to set up 2VMs with CUDA on Quadro M4000?
Thanks for your reply!
