I just tried to install the new Cuda version 2.1. Driver and Toolkit worked fine, but trying to install the isntallatiomn just does not continue after uncompressing the sdk. anyone else experienced similar problems or knows even how to fix this???
I am experiencing the same problem. It just hangs after all the dots. I’m considering upgrading to 11.1 to see if that fixes it. Or maybe copying an SDK installation from another machine.
Found the solution: the default terminal in OpenSuse 11/11.1 is buggy. The script is showing a prompt with “where to install the SDK?”, but because there is no newline after it, it is buffered and not yet shown. Just hit Enter, and it will magically continue!
