Hi there,
I’ve been attempting to install CUDA in openSUSE 11.1 (64 bit) for some time now, but to no avail and would really appreciate any help, I have the following set up:
Desktop: KDE4
Card: GeForce 9500 GT
Driver: 185.18.14
I’m using the default kernel for the driver installed through Yast; I attempted installing the driver manually, but sax2 ended up not being able to start and I was without any X, so I reverted to the former. I’ve noticed that at least a few people on this site have used a work around by adding uppermem, vmalloc and pci to the grub boot file (menu.lst); I tried this too:
root (hd0,0)
uppermem 524288
kernel /vmlinuz-2.6.27.23-0.1-default root=/dev/md0 resume=/dev/disk/by-id/ata-ST3500320AS_9QM4X7MA-part3 splash=silent showopts vga=0x31a vmalloc=256MB pci=nommconf
initrd /initrd-2.6.27.23-0.1-default
But my deviceQuery still gives the following output:
CUDA Device Query (Runtime API) version (CUDART static linking)
There is no device supporting CUDA.
Device 0: "Device Emulation (CPU)"
CUDA Capability Major revision number: 9999
CUDA Capability Minor revision number: 9999
Total amount of global memory: 4294967295 bytes
Number of multiprocessors: 16
Number of cores: 128
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 16384 bytes
Total number of registers available per block: 8192
Warp size: 1
Maximum number of threads per block: 512
Maximum sizes of each dimension of a block: 512 x 512 x 64
Maximum sizes of each dimension of a grid: 65535 x 65535 x 1
Maximum memory pitch: 262144 bytes
Texture alignment: 256 bytes
Clock rate: 1.35 GHz
Concurrent copy and execution: No
Run time limit on kernels: No
Integrated: Yes
Support host page-locked memory mapping: Yes
Compute mode: Default (multiple host threads can use this device simultaneously)
Test PASSED
I had CUDA working on XP before I decided to switch to Linux, so this is fairly frustrating… any help would be wonderful, thanks!
