My system is lacking the cuDNN 6 library and I can’t find it anywhere. I’ve setup too many things to reinstall my TX1 with JetPack, I would loose too many things. Would any of you help me by sending me the cuDNN 6 archive or at least a tar of the /usr/local/cuda folder ?
Many thanks,
Jean-Noël
Hi Jean-Noël, you should be able to find the DEB package for cuDNN on the machine you ran JetPack on, under the jetpack_downloads/ folder. JetPack downloads the packages there to the PC before installing them to the Jetson.
I’ll have a look, thanks Dusty !
I found it and I could setup my whole CUDA + cuDNN stack on my TX1, thanks again !
