CuMotion Robotics Examples issue
Isaac Sim Version:
6.0.0
5.1.0
Operating System
Ubuntu 26.04
GPU Information
  • Model: 3090
  • Driver Version: 590
Detailed Description
When running the path planning robotics example on isaac sim 5.1.0 compared to 6.0.0, the 5.1.0 version seems to run better and actually tends to avoid the walls, whereas when running the 6.0.0 version of the example, that has cumotion alot of the time it tends to collide with a wall. When colliding with the wall it seems to stop moving as well until the wall is removed. Why does this example work better with the Lula version and not the Cumotion version? Could this be due to some underlying update that hasn’t been implemented.
Steps to Reproduce
  1. Open Isaac Sim 5.1.0 and then go into robotics examples.
  2. Go to manipulation then run path planning after placing a wall infront of the block (while still making the cube reachable for the franka)
  3. Repeat the samething with isaac sim 6.0.0.
Hi @asadel.ali,
Thanks for the detailed report. This difference is expected and comes down to how the two examples build their collision world rather than a cuMotion regression — but there are a couple of things worth checking.
In 5.1, the Path Planning example uses the Lula RRT planner. It does two things that make it very conservative: it explicitly registers every wall you add with the planner, and it loads a robot description with inflated collision spheres (franka_conservative_spheres_robot_description.yaml). That combination gives the arm a wide berth, so it reliably routes around walls.
In 6.0, that example was replaced by the cuMotion Graph Planner example. cuMotion builds its collision world automatically from prims that have a physics collision API within a region around the robot — it does not track visual-only geometry. So the first thing to check:
  1. Does your wall have a collider? Select the wall, and in the Property panel confirm it has a Collider/collision API applied (Add → Physics → Colliders Preset). If it’s visual-only, cuMotion can’t see it and will plan straight through — which matches the “collides with the wall” behavior.
  2. Re-plan after placing/moving the wall. The Graph Planner plans once against a snapshot of the scene and then executes that trajectory open-loop; it doesn’t reactively re-plan mid-motion. After you add or move a wall, press Plan again so the new obstacle is included.
The “stops moving until the wall is removed” part is actually cuMotion working correctly: if the goal or the path is blocked, the planner returns no solution (you should see a “Planning failed: Unable to find a valid path” message), and the robot holds position. Removing the wall lets the next plan succeed.
If the wall does have a collider and you’re re-planning but the arm still grazes it, then it’s a margin-tuning issue — cuMotion’s default obstacle inflation in that example is small (1 cm), versus the deliberately inflated robot spheres the old Lula example shipped. Increasing the obstacle inflation or using a more conservative robot sphere config closes that gap.
Hi Michalin,
Thank you for your response. I have added a collider to the wall, though I added a rigid body with colliders preset as for some reason I could not just select colliders preset. I hope this does not cause a major change. After doing this though, I have noticed that the Franka tends to smash the wall away just to reach the block. I also noticed that I do not receive this “Planning failed: Unable to find a valid path” message, instead occasionally when it cannot find an approach angle it will say "No plan could be generated for target position ", this is probably due to distance or me not having the collision preset set at that time.
Hi @asadel.ali,
Sorry, I missed some steps. Can you try:
  1. Make the wall static. Keep CollisionAPI, but remove RigidBodyAPI. The Rigid Body with Colliders preset makes the wall dynamic, so the Franka can push it away. If necessary, select the wall’s actual Cube or Mesh child and apply only the Collider preset there.
  2. Register the wall with cuMotion. A manually created collider is visible to PhysX but is not automatically added to the example’s planning world after the example has loaded. The easiest option is to use the example’s Add Wall button, which creates a static collider and calls CumotionWorldInterface.add_cubes(...). For a custom wall, make the equivalent add_cubes(...) call—or rebuild the WorldBinding and planner after the wall exists.
  3. Plan again. Press Plan To Target only after the wall is registered. If the target is unreachable or the wall leaves no valid route, No plan could be generated to target position is the expected result.
Could you try the built-in Add Wall button first and confirm whether the Franka avoids it?
Hello!
We noticed that this topic hasn’t received any recent updates from anyone reporting this issue, so we are closing it for now to help keep the forum organized.
If you are still experiencing this issue or have related questions, please create a GitHub Discussion or Issue in the Isaac Sim repository and include a link to this topic along with updated details. Mentioning or linking to this original topic provides helpful context and makes it easier for others to assist you.
Best regards,
