Custom MIPI Camera: v4l2-ctl error: NULL VI channel received
Hello, I have a customized MIPI camera board and the driver has been successfully registered.
Media device information
driver          tegra-camrtc-ca
model           NVIDIA Tegra Video Input Device
serial
bus info
hw revision     0x3
driver version  5.10.120
Device topology
- entity 1: 13e40000.host1x:nvcsi@15a00000- (2 pads, 2 links)
            type V4L2 subdev subtype Unknown flags 0
            device node name /dev/v4l-subdev0
	pad0: Sink
		<- "rn6752 9-002c":0 [ENABLED]
	pad1: Source
		-> "vi-output, rn6752 9-002c":0 [ENABLED]
- entity 4: 13e40000.host1x:nvcsi@15a00000- (2 pads, 2 links)
            device node name /dev/v4l-subdev1
	pad0: Sink
		<- "rn6752 10-002c":0 [ENABLED]
	pad1: Source
		-> "vi-output, rn6752 10-002c":0 [ENABLED]
- entity 7: rn6752 9-002c (1 pad, 1 link)
            type V4L2 subdev subtype Sensor flags 0
            device node name /dev/v4l-subdev2
	pad0: Source
		[fmt:UYVY8_1X16/1280x720 field:none colorspace:srgb]
		-> "13e40000.host1x:nvcsi@15a00000-":0 [ENABLED]
- entity 9: vi-output, rn6752 9-002c (1 pad, 1 link)
            type Node subtype V4L flags 0
            device node name /dev/video0
	pad0: Sink
		<- "13e40000.host1x:nvcsi@15a00000-":1 [ENABLED]
- entity 23: rn6752 10-002c (1 pad, 1 link)
             device node name /dev/v4l-subdev3
	pad0: Source
- entity 25: vi-output, rn6752 10-002c (1 pad, 1 link)
             device node name /dev/video1
	pad0: Sink
However, executing the command:v4l2-ctl -d /dev/video0 --set-fmt-video=width=1920,height=1080,pixelformat=UYVY --set-ctrl bypass_mode=0 --stream-mmap ,
The following error will be reported:
[  112.852516] bwmgr API not supported
[  115.420466] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[  115.420492] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[  115.421005] (NULL device *): vi_capture_control_message: NULL VI channel received
[  115.421012] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=1, csi_port=1
[  115.421021] (NULL device *): vi_capture_control_message: NULL VI channel received
[  115.421024] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 1 vc- 0
[  115.421397] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
$ sudo cat /sys/kernel/debug/tracing/trace
# tracer: nop
# entries-in-buffer/entries-written: 21/21   #P:6
#                                _-------=> irqs-off
#                               / _------=> need-resched
#                              | / _-----=> need-resched-lazy
#                              || / _----=> hardirq/softirq
#                              ||| / _---=> preempt-depth
#                              |||| / _--=> preempt-lazy-depth
#                              ||||| / _-=> migrate-disable
#                              |||||| /     delay
#           TASK-PID     CPU#  |||||||  TIMESTAMP  FUNCTION
     kworker/4:4-183     [004] .......   104.256482: rtcpu_string: tstamp:3784498673 id:0x04010000 str:"VM0 deactivating."
        v4l2-ctl-2916    [000] .......   112.837685: tegra_channel_open: vi-output, rn6752 9-002c
        v4l2-ctl-2916    [000] .......   112.841391: tegra_channel_set_power: rn6752 9-002c : 0x1
        v4l2-ctl-2916    [000] .......   112.841403: camera_common_s_power: status : 0x1
        v4l2-ctl-2916    [000] .......   112.841412: tegra_channel_set_power: 13e40000.host1x:nvcsi@15a00000- : 0x1
        v4l2-ctl-2916    [000] .......   112.841415: csi_s_power: enable : 0x1
        v4l2-ctl-2916    [000] .......   112.842095: tegra_channel_capture_setup: vnc_id 0 W 1280 H 720 fmt 13
     kworker/4:4-183     [004] .......   112.848451: rtcpu_string: tstamp:4053059467 id:0x04010000 str:"VM0 activating."
        v4l2-ctl-2916    [004] .......   112.848887: tegra_channel_set_stream: enable : 0x1
        v4l2-ctl-2916    [004] .......   112.852823: tegra_channel_set_stream: 13e40000.host1x:nvcsi@15a00000- : 0x1
        v4l2-ctl-2916    [004] .......   112.852826: csi_s_stream: enable : 0x1
        v4l2-ctl-2916    [004] .......   112.853219: tegra_channel_set_stream: rn6752 9-002c : 0x1
     kworker/4:4-183     [004] .......   112.908459: rtcpu_vinotify_event: tstamp:4053697235 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:129702251968 data:0x759d580010000000
     kworker/4:4-183     [004] .......   112.908462: rtcpu_vinotify_event: tstamp:4053697492 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:129702261728 data:0x0000000031000001
     kworker/4:4-183     [004] .......   112.908462: rtcpu_vinotify_event: tstamp:4053697781 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:129702353344 data:0x759d550010000000
     kworker/4:4-183     [004] .......   112.908463: rtcpu_vinotify_event: tstamp:4053698028 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:129702363232 data:0x0000000031000002
 vi-output, rn67-2919    [003] .......   115.421198: tegra_channel_capture_setup: vnc_id 0 W 1280 H 720 fmt 13
     kworker/4:4-183     [004] .......   115.448460: rtcpu_vinotify_event: tstamp:4133992978 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:132274945408 data:0x759d580010000000
     kworker/4:4-183     [004] .......   115.448464: rtcpu_vinotify_event: tstamp:4133993235 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:132275002912 data:0x0000000031000001
     kworker/4:4-183     [004] .......   115.448465: rtcpu_vinotify_event: tstamp:4133993520 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:132275020608 data:0x759d550010000000
     kworker/4:4-183     [004] .......   115.448465: rtcpu_vinotify_event: tstamp:4133993768 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:132275080928 data:0x0000000031000002
Through i2cdump, I can see the value successfully written to the register, but I cannot see the mipi-clock signal through the oscilloscope. What should I do?
Checking with vendor for your HW design.
