Customize Nvblox_examples_bringup
Hi i’ve been running the nvblox example without any problems
ros2 launch nvblox_examples_bringup isaac_sim_example.launch.py
Now I am trying to run the example with another robot in Isaac sim.
I have done the following remaping, but nvblox doesn’t show up in rviz2. The uncommented section works with the Carter robot.
# def get_isaac_sim_remappings(lidar: bool) -> List[Tuple[str, str]]:
#     remappings = []
#     camera_names = ['front_stereo_camera']
#     for i, name in enumerate(camera_names):
#         remappings.append((f'camera_{i}/depth/image', f'{name}/depth/ground_truth'))
#         remappings.append((f'camera_{i}/depth/camera_info', f'{name}/left/camera_info'))
#         remappings.append((f'camera_{i}/color/image', f'{name}/left/image_raw'))
#         remappings.append((f'camera_{i}/color/camera_info', f'{name}/left/camera_info'))
#     if lidar:
#         remappings.append(('pointcloud', '/front_3d_lidar/point_cloud'))
#     return remappings
    remappings = []
    camera_names = ['isaac/camera']
        remappings.append((f'camera_{i}/depth/image', f'{name}_depth'))
        remappings.append((f'camera_{i}/depth/camera_info', f'{name}_camera_info'))
        remappings.append((f'camera_{i}/color/image', f'{name}_rgb'))
        remappings.append((f'camera_{i}/color/camera_info', f'{name}_camera_info'))
    if lidar:
        remappings.append(('pointcloud', '/isaac/point_cloud'))
    return remappings
Is there other parameters that should be changed?
Best Regards,
Kasper
Hi @kaspermh ! Have you checked if the topic names are aligned with the Isaac Sim Scene? If you use a different robot, I assume the camera is at a different height from carter robot. Have you adjusted nvblox parameters for your robot?
Hi @zhengwang
The topics are aligned, and I can see that there are publishers and subscribers for each topic.
I have not adjusted the nvblox parameters for my robot, would this be a cause for no data to be published from nvblox? Or only to get some distorted data?
My Cameras are set up with this guide
https://docs.omniverse.nvidia.com/isaacsim/latest/ros2_tutorials/tutorial_ros2_camera_publishing.html
I’ve noticed this topic appears when I run the example, but it doesnt when I run it on my own robot.
/nvblox_node/back_projected_depth/front_stereo_camera_left_optical
I’ve created the cameras with the graphs instead:
That made it work :D
