Data Center Content Pack Installation
Hi
I’ve very new to Omniverse and trying to find my way. I’ve been trying to install the data center content pack ( Omniverse) however when tying to install I get an error “20:42:27.399 › Error: ENOENT: no such file or directory, open '/home/xxxx/ov-datacenter3dpack-01-100.1.1/launcher.toml”.
Is the launcher.toml file supposed to be installed from another package or by default? Struggling to work out where I can source a launcher.toml file.
All pointers warmly welcomed! Thanks
Dan
You are trying to download a CONTENT PACK from Launcher ? Yes I see the Data Center pack. I just tried it and it downloaded fine. It was only 191mb. Try to download something else. Are you behind a firewall ? Heavy antivirus ?
Hi Richard - thanks for coming back to me.
I’ve been able to download the Linux version (also 191mb) which comes as a ZIP file; its during running the install from the cmd line that the launcher.toml file is reported missing.
I am on an air-gapped system so using an IT Managed Launcher set up and running the install via the custom URL protocol (i.e. omniverse-launcher://install?path=xxxx) but the issue appears to be at install time rather than downloading the .zip/package itself.
Is the launcher.toml something that would be pulled down at install over the Internet maybe rather than inc. in the Linux ZIP package?
Dan
Do you have the launcher installed already ? Can you provide a screenshot of the error and logs if possible.
Hi Richard
I installed the launcher last week and been able to successfully install the USD Explorer application. Below is the output on the CLI when I run the install:
$ xdg-open omniverse-launcher://install?path=./ov-datacenter3dpack-01.100.1.1.linux-x86_64-ent-package.zip
14:43:33.398 › Omniverse Launcher 1.9.10 (production)
14:43:33.404 › Argv: /tmp/.mount_omniveFgCa9U/omniverse-launcher omniverse-launcher://install?path=./ov-datacenter3dpack-01.100.1.1.linux-x86_64-ent-package.zip
14:43:33.405 › Crash dumps directory: /home/s2200026/.config/omniverse-launcher/Crashpad
14:43:33.513 › Reset current installer.
14:43:33.522 › Running production web server.
14:43:33.527 › HTTP endpoints listening at http://localhost:33480
14:43:33.527 › HTTP endpoints listening at http://127.0.0.1:33480
14:43:33.530 › Sharing: false
14:43:34.300 › Started the Navigator web server on 127.0.0.1:34080.
[37540:0421/144334.307634:ERROR:object_proxy.cc(623)] Failed to call method: org.freedesktop.DBus.StartServiceByName: object_path= /org/freedesktop/DBus: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
[37591:0421/144336.419433:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
[37728:0421/144338.193860:ERROR:angle_platform_impl.cc(43)] RendererVk.cpp:157 (VerifyExtensionsPresent): Extension not supported: VK_KHR_surface
ERR: RendererVk.cpp:157 (VerifyExtensionsPresent): Extension not supported: VK_KHR_surface
[37728:0421/144338.194032:ERROR:angle_platform_impl.cc(43)] RendererVk.cpp:157 (VerifyExtensionsPresent): Extension not supported: VK_KHR_xcb_surface
ERR: RendererVk.cpp:157 (VerifyExtensionsPresent): Extension not supported: VK_KHR_xcb_surface
[37728:0421/144338.194109:ERROR:angle_platform_impl.cc(43)] Display.cpp:1019 (initialize): ANGLE Display::initialize error 0: Internal Vulkan error (-7): A requested extension is not supported, in …/…/third_party/angle/src/libANGLE/renderer/vulkan/RendererVk.cpp, enableInstanceExtensions:1639.
ERR: Display.cpp:1019 (initialize): ANGLE Display::initialize error 0: Internal Vulkan error (-7): A requested extension is not supported, in …/…/third_party/angle/src/libANGLE/renderer/vulkan/RendererVk.cpp, enableInstanceExtensions:1639.
[37728:0421/144338.194189:ERROR:gl_display.cc(504)] EGL Driver message (Critical) eglInitialize: Internal Vulkan error (-7): A requested extension is not supported, in …/…/third_party/angle/src/libANGLE/renderer/vulkan/RendererVk.cpp, enableInstanceExtensions:1639.
[37728:0421/144338.194252:ERROR:gl_display.cc(793)] eglInitialize SwANGLE failed with error EGL_NOT_INITIALIZED
[37728:0421/144338.194332:ERROR:gl_display.cc(819)] Initialization of all EGL display types failed.
[37728:0421/144338.194394:ERROR:gl_ozone_egl.cc(26)] GLDisplayEGL::Initialize failed.
[37728:0421/144338.913660:ERROR:angle_platform_impl.cc(43)] RendererVk.cpp:157 (VerifyExtensionsPresent): Extension not supported: VK_KHR_surface
[37728:0421/144338.913801:ERROR:angle_platform_impl.cc(43)] RendererVk.cpp:157 (VerifyExtensionsPresent): Extension not supported: VK_KHR_xcb_surface
[37728:0421/144338.913874:ERROR:angle_platform_impl.cc(43)] Display.cpp:1019 (initialize): ANGLE Display::initialize error 0: Internal Vulkan error (-7): A requested extension is not supported, in …/…/third_party/angle/src/libANGLE/renderer/vulkan/RendererVk.cpp, enableInstanceExtensions:1639.
[37728:0421/144338.913948:ERROR:gl_display.cc(504)] EGL Driver message (Critical) eglInitialize: Internal Vulkan error (-7): A requested extension is not supported, in …/…/third_party/angle/src/libANGLE/renderer/vulkan/RendererVk.cpp, enableInstanceExtensions:1639.
[37728:0421/144338.914005:ERROR:gl_display.cc(793)] eglInitialize SwANGLE failed with error EGL_NOT_INITIALIZED
[37728:0421/144338.914064:ERROR:gl_display.cc(819)] Initialization of all EGL display types failed.
[37728:0421/144338.914118:ERROR:gl_ozone_egl.cc(26)] GLDisplayEGL::Initialize failed.
[37728:0421/144338.943936:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
14:43:39.783 › Saving omniverse-launcher.desktop file to /tmp/omniverse-launcher-9XmsLG…
14:43:39.784 ›
[Desktop Entry]
Name=omniverse-launcher
Exec=“/home/s2200026/omniverse-launcher-1.9.10-linux-enterprise.AppImage” %u
Type=Application
Terminal=false
MimeType=x-scheme-handler/omniverse-launcher
14:43:40.082 › Saving omniverse.desktop file to /tmp/omniverse-launcher-7pRcAQ…
14:43:40.082 ›
[Desktop Entry]
Type=Application
Terminal=false
14:43:40.178 › Failed to set launch on login: Error: EACCES: permission denied, copyfile ‘/home/s2200026/.local/share/applications/nvidia-omniverse-launcher.desktop’ → ‘/home/s2200026/.config/autostart/nvidia-omniverse-launcher.desktop’
14:43:40.178 › Found /install command…
14:43:40.179 › Run omniverse-launcher://install?path=./ov-datacenter3dpack-01.100.1.1.linux-x86_64-ent-package.zip command…
14:43:40.179 › Enqueue [5ea58e6e-5af7-4201-9d59-5eff2472e257] .
14:43:40.179 › Set current installer [5ea58e6e-5af7-4201-9d59-5eff2472e257] .
14:43:40.189 › Initialized.
14:43:40.190 › [5ea58e6e-5af7-4201-9d59-5eff2472e257] Extracting ./ov-datacenter3dpack-01.100.1.1.linux-x86_64-ent-package.zip to /home/s2200026/.local/share/ov/pkg/2okCwm…
14:43:40.193 › (node:37540) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
(Use omniverse-launcher --trace-deprecation ... to show where the warning was created)
14:43:43.630 › [5ea58e6e-5af7-4201-9d59-5eff2472e257] Read description.toml file from /home/s2200026/.local/share/ov/pkg/2okCwm
14:43:43.637 › [5ea58e6e-5af7-4201-9d59-5eff2472e257] Extracting /home/s2200026/.local/share/ov/pkg/2okCwm/linux-x86_64/package.zip to /home/s2200026/.local/share/ov/pkg/2okCwm/linux-x86_64…
14:43:50.250 › [5ea58e6e-5af7-4201-9d59-5eff2472e257] Detected thick package installation, moving /home/s2200026/.local/share/ov/pkg/2okCwm/linux-x86_64 to /home/s2200026/ov-datacenter3dpack-01-100.1.1…
14:43:50.303 › [5ea58e6e-5af7-4201-9d59-5eff2472e257] Loading background.png image…
14:43:50.304 › [5ea58e6e-5af7-4201-9d59-5eff2472e257] Loaded background.png from file:///home/s2200026/ov-datacenter3dpack-01-100.1.1/background.png.
14:43:50.305 › [5ea58e6e-5af7-4201-9d59-5eff2472e257] Loading card.jpg image…
14:43:50.305 › [5ea58e6e-5af7-4201-9d59-5eff2472e257] Loaded card.jpg from file:///home/s2200026/ov-datacenter3dpack-01-100.1.1/card.jpg.
14:43:50.305 › [5ea58e6e-5af7-4201-9d59-5eff2472e257] Loading image.png image…
14:43:50.305 › [5ea58e6e-5af7-4201-9d59-5eff2472e257] Loaded image.png from file:///home/s2200026/ov-datacenter3dpack-01-100.1.1/image.png.
14:43:50.306 › [5ea58e6e-5af7-4201-9d59-5eff2472e257] Loading icon.png image…
14:43:50.306 › [5ea58e6e-5af7-4201-9d59-5eff2472e257] Loaded icon.png from file:///home/s2200026/ov-datacenter3dpack-01-100.1.1/icon.png.
14:43:50.306 › [5ea58e6e-5af7-4201-9d59-5eff2472e257] Delete temporary folder /home/s2200026/.local/share/ov/pkg/2okCwm
14:43:50.307 › [5ea58e6e-5af7-4201-9d59-5eff2472e257] Load installation scripts from /home/s2200026/ov-datacenter3dpack-01-100.1.1
14:43:50.308 › Dequeue [5ea58e6e-5af7-4201-9d59-5eff2472e257] ov-datacenter3dpack-01.
14:43:50.308 › Reset current installer.
14:43:50.308 › Error: ENOENT: no such file or directory, open ‘/home/s2200026/ov-datacenter3dpack-01-100.1.1/launcher.toml’
HI Dan,
If you’re using the IT Managed Launcher, you shouldn’t need to “install” the content packs within the Launcher once the zip files are downloaded, you should simply unpack them to your local system and either place them in a local Nucleus location, or local folder and point Omniverse directly to see them.
We have docs specifically for this process:
3D Content Pack Installation — Omniverse Launcher latest documentation (nvidia.com)
Feel free to let us know if something doesn’t make sense here.
Sincerely,
-=Beau
Thanks Beau
That is very helpful guidance - thank you!
Dan
