I’ve encountered a problem with the Nsight debugger. The GPU debugger (Legacy mode only supported for my Nvidia Geforce 930m) simply ignores all my breakpoints.
It might be just a stupid mistake on my side but I can’t seem to find the solution.
Using Windows 10 64 bit, Nvidia 930 m, driver 419.67, Visual Studio 2017.
Before I was able to successfully debug. Debug is not working on new projects inside my solution, I have also tried old projects inside that solution and debugger ignores breakpoints in there too, before it worked though.
Maybe it has something to do with the fact that I have installed this new driver a few days ago (I cant really say whether the debugging broke Immediately after the update or not). I dont know what driver I was using before.
Do you have any idea of what could be wrong? I would be grateful for any help.
You can get the recommended drivers from the same page
(I don't know that 419.67 is the problem, though)
Maybe the code wasn't compiled with symbolics?
If you can't hit source breakpoints in your __global__ or __device__ kernel functions,
you would still be able to set/hit function breakpoints on the same functions.
Ctrl+B (in VS2017), then enter .* for the function name to set all function breakpoints
If this works, ensure you are using nvcc with the -G switch to generate debug information (symbolics)
for GPU/device code
Are your source and binaries in sync?
Are breakpoints showing up on other lines of code?
This is a sign that the breakpoints are jumping to valid lines of code (ie. from a comment line)
Can you set an SASS/PTX breakpoint and have it hit on the expected line
It would be interesting to know what version of NsightVSE you were using before.
I guess it is possible that there was some incompatibility between the old NsightVSE and the new driver.
