I’m interested in getting Deepstream to run in WSL2, now that there is CUDA support.
In a fresh WSL2 environment, I installed the following:
- Nvidia Driver 440 (using sudo apt-get install nvidia-driver 440)
- Cuda Toolkit 10.2 (using sudo apt-get install cuda-toolkit-10-2, according to the documentation)
- TensorRT 7.0.0 (using nv-tensorrt-repo-ubuntu1804-cuda10.2-trt7.0.0.11-ga-20191216_1-1_amd64.deb)
- Other Deepstream dependencies like librdkafka and gstreamer (as documented Quickstart Guide — DeepStream 6.1.1 Release documentation)
- Deepstream 5.0.1 (using deepstream-5.0_5.0.1-1_amd64.deb)
For the record, I have installed this configuration on a different system with an actual Ubuntu 18.04 LTS OS with success, and I currently develop on that system. It would however be nice to be able to run it on my Windows machine with WSL2 as well.
All of this installs correctly, but when I try to run a pipeline I get the following issue:
nvbufsurftransform:cuInit failed : 100
(gst-plugin-scanner:306): GStreamer-WARNING **: 12:09:34.330: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so’: libtrtserver.so: cannot open shared object file: No such file or directory
(gst-plugin-scanner:307): GStreamer-WARNING **: 12:09:34.334: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so’: libtrtserver.so: cannot open shared object file: No such file or directory
Which causes it to be unable to create the nvstreammux element.
When I run gst-inspect-1.0 nvstreammux, I get No such element or plugin ‘nvstreammux’.
Any idea what the issue could be? Has anyone succeeded in installing Deepstream in WSL2 and running an example?
