Dependency: 'omni.graph.ui' = { version='^' } can't be satisfied
I am unable to install “omni.graph.bundle.action” = {} extension in kit app 106.0.0
I get the following error:
2024-07-16 14:15:29 [1,462ms] [Error] [omni.ext.plugin] Failed to resolve extension dependencies. Failure hints:
        [xyz_app-0.1.0 -> omni.graph.bundle.action-2.0.4] dependency: 'omni.graph.ui' = { version='^' } can't be satisfied. Available versions:
         (none found)
        [xyz_app-0.1.0 -> omni.graph.bundle.action-2.0.3] dependency: 'omni.graph.ui' = { version='^' } can't be satisfied. Available versions:
         (none found)
 Synced registries:
         - kit/default         : found 462 packages
         - kit/sdk             : found 436 packages
         - kit/community       : found 357 packages
         - kit/prod/sdk        : found 436 packages
Thank you for bringing this to our attention. We have a fix already in place which should be out within the next few days. Sorry for the inconvenience.
Hi !
I got the same error information, have you released a new version?
A new version of what ? Kit Based Editor or the Kit app template ?
