Hi and thanks for the post. We recently updated the master registry for kit 107.0, yes. Are you trying to install Replicator through Isaac Sim, or through USD Composer ? It is really designed for Isaac Sim. What exact version are you using?
I was trying to develop a custom extension for Synthetic Data Generation using Replicator. (NOTE: If possible please add more details in the documentation of replicator)
My main target is to add it as a dependency to make a headless app deployed in an container for Synthetic Data Generation and I was trying to build it so that I can use the help of VS Code.
Ok great. Thanks for that. Yes, Replicator requires Isaac Sim, full app. Not a template. It is special code. You cannot break it away from Isaac Sim, and you cannot use it in a custom template. It is designed for very special specific robotic SDG workflow, which is part of Isaac Sim.
So if you want to use it, just download Isaac Sim, download Replicator and use it there. We already have a container for SDG workflow for Isaac Sim. Just use that.
Well because Isaac Sim is always behind the Kit App Template. Isaac is at 106.5 and the KAT is now at 107.0. So you are trying to force replicator based on 106 into a 107 kit template. So just stick to 106.5 for your kit app template for now.
