I downloaded the zip from the Replicator Insight early access program and installed it according to the instructions. On starting up under Windows 10 though, I get an error:
C:\Users\BrunoVetter\Downloads\replicator-insight-2022.0.0-main.0.daad3f2e.local.windows-x86_64.release>.\replicator.insight.bat
Loading user config located at: ‘C:/Users/BrunoVetter/AppData/Local/ov/data/Kit/Replicator Insight/0.1/user.config.json’
[Info] [carb] Logging to file: C:/Users/BrunoVetter/.nvidia-omniverse/logs/Kit/Replicator Insight/0.1/kit_20230224_171405.log
[0.219s] Failed to solve some dependencies locally, syncing with extension registry…
[0.224s] [ext: omni.usd.config-1.0.0] startup
[0.238s] [ext: omni.usd.libs-1.0.0] startup
[0.410s] [ext: omni.kit.async_engine-0.0.0] startup
[0.415s] [ext: omni.assets.plugins-0.0.0] startup
[0.421s] [ext: omni.client-0.1.1] startup
[0.433s] [ext: omni.kit.registry.nucleus-0.0.0] startup
2023-02-24 16:14:06 [436ms] [Warning] [omni.client.plugin] Tick: authentication: Could not resolve host name “kit-extensions.ov.nvidia.com”
2023-02-24 16:14:06 [437ms] [Warning] [omni.client.plugin] Tick: authentication: Could not resolve host name “kit-extensions.ov.nvidia.com”
2023-02-24 16:14:06 [442ms] [Error] [omni.ext.plugin] Failed to resolve extension dependencies. Failure hints:
Can’t find extension with name: omni.flux.content_library.property.widget
Available versions:
(none found)
Can’t find extension with name: omni.flux.content_library.widget
Available versions:
(none found)
Can’t find extension with name: omni.flux.content_viewer.widget
Available versions:
(none found)
Can’t find extension with name: omni.flux.footer.widget
Available versions:
(none found)
Can’t find extension with name: omni.flux.header_navigator.widget
Available versions:
(none found)
Can’t find extension with name: omni.flux.header_nvidia.widget
Available versions:
(none found)
Can’t find extension with name: omni.flux.properties_pane.properties.usd.widget
Available versions:
(none found)
Can’t find extension with name: omni.flux.properties_pane.properties.widget
Available versions:
(none found)
Can’t find extension with name: omni.flux.properties_pane.transformation.usd.widget
Available versions:
(none found)
Can’t find extension with name: omni.flux.properties_pane.transformation.widget
Available versions:
(none found)
Can’t find extension with name: omni.flux.property_widget_builder.delegates
Available versions:
(none found)
Can’t find extension with name: omni.flux.property_widget_builder.model.file
Available versions:
(none found)
Can’t find extension with name: omni.flux.property_widget_builder.model.usd
Available versions:
(none found)
Can’t find extension with name: omni.flux.property_widget_builder.widget
Available versions:
(none found)
Can’t find extension with name: omni.flux.tree_panel.widget
Available versions:
(none found)
Can’t find extension with name: omni.flux.utils.common
Available versions:
(none found)
Can’t find extension with name: omni.flux.utils.widget
Available versions:
(none found)
2023-02-24 16:14:06 [442ms] [Error] [omni.kit.app.plugin] Exiting app because of dependency solver failure…
[0.511s] [ext: omni.kit.registry.nucleus-0.0.0] shutdown
[0.521s] [ext: omni.client-0.1.1] shutdown
2023-02-24 16:14:06 [468ms] [Warning] [carb] unloadPlugin: Failed to find a plugin at: c:/users/brunovetter/downloads/replicator-insight-2022.0.0-main.0.daad3f2e.local.windows-x86_64.release/kit/extscore/omni.client/bin/deps/carb.datasource-omniclient.plugin.dll.
[0.536s] [ext: omni.assets.plugins-0.0.0] shutdown
[0.537s] [ext: omni.kit.async_engine-0.0.0] shutdown
[0.547s] [ext: omni.usd.libs-1.0.0] shutdown
[0.610s] [ext: omni.usd.config-1.0.0] shutdown
Any help appreciated
Bruno
