Suddly i cant run Omniverse Kit anymore
I was using Omniverse for days but suddenly i cant start it anymore and i get this mistakes from the console.
2024-11-06 18:51:13 [Error] [gpu.foundation.plugin] Failed to initialize rtx::psodb::Context
2024-11-06 18:51:13 [Error] [carb.scripting-python.plugin] RuntimeError: Failed to acquire interface: omni::hydratexture::IHydraTextureFactory (pluginName: nullptr)
2024-11-06 18:51:13 [Error] [carb.scripting-python.plugin] At:
2024-11-06 18:51:13 [Error] [carb.scripting-python.plugin] c:/users/kerem/appdata/local/ov/pkg/kit-106.0.2/extscache/omni.kit.hydra_texture-1.2.6+36286b8b.wx64.r.cp310/omni/kit/hydra_texture/scripts/extension.py(6): on_startup
2024-11-06 18:51:13 [Error] [carb.scripting-python.plugin] c:\users/kerem/appdata/local/ov/pkg/kit-106.0.2/kit/kernel/py\omni\ext_impl_internal.py(166): startup_ext
2024-11-06 18:51:13 [Error] [carb.scripting-python.plugin] c:\users/kerem/appdata/local/ov/pkg/kit-106.0.2/kit/kernel/py\carb\profiler_init
.py(86): wrapper
2024-11-06 18:51:13 [Error] [carb.scripting-python.plugin] c:\users/kerem/appdata/local/ov/pkg/kit-106.0.2/kit/kernel/py\omni\ext_impl_internal.py(224): startup
2024-11-06 18:51:13 [Error] [carb.scripting-python.plugin] c:\users/kerem/appdata/local/ov/pkg/kit-106.0.2/kit/kernel/py\omni\ext_impl_internal.py(328): startup_extension
2024-11-06 18:51:13 [Error] [carb.scripting-python.plugin] PythonExtension.cpp::startup()(2):
2024-11-06 18:51:13 [Error] [omni.ext.plugin] [ext: omni.kit.hydra_texture-1.2.6] Failed to startup python extension.
2024-11-06 18:51:13 [Error] [gpu.foundation.plugin] Invalid arguments provided.
2024-11-06 18:51:13 [Error] [omni.ext._impl.custom_importer] Failed to import python module omni.example.airoomgenerator. Error: No module named ‘omni.example’. Traceback:
2024-11-06 18:51:13 [Error] [omni.ext._impl.custom_importer] Traceback (most recent call last):
2024-11-06 18:51:13 [Error] [omni.ext._impl.custom_importer] File “c:\users/kerem/appdata/local/ov/pkg/kit-106.0.2/kit/kernel/py\omni\ext_impl\custom_importer.py”, line 76, in import_module
2024-11-06 18:51:13 [Error] [omni.ext._impl.custom_importer] return importlib.import_module(name)
2024-11-06 18:51:13 [Error] [omni.ext.impl.custom_importer] File "c:\users\kerem\appdata\local\ov\pkg\kit-106.0.2\kit\python\lib\importlib_init.py", line 126, in import_module
2024-11-06 18:51:13 [Error] [omni.ext._impl.custom_importer] return _bootstrap._gcd_import(name[level:], package, level)
2024-11-06 18:51:13 [Error] [omni.ext._impl.custom_importer] File “”, line 1050, in _gcd_import
2024-11-06 18:51:13 [Error] [omni.ext._impl.custom_importer] File “”, line 1027, in _find_and_load
2024-11-06 18:51:13 [Error] [omni.ext._impl.custom_importer] File “”, line 992, in _find_and_load_unlocked
2024-11-06 18:51:13 [Error] [omni.ext._impl.custom_importer] File “”, line 241, in _call_with_frames_removed
2024-11-06 18:51:13 [Error] [omni.ext._impl.custom_importer] File “”, line 1004, in _find_and_load_unlocked
2024-11-06 18:51:13 [Error] [omni.ext._impl.custom_importer] ModuleNotFoundError: No module named ‘omni.example’
2024-11-06 18:51:13 [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘omni.example.airoomgenerator’ in ‘c:\users\kerem\desktop\probe\kit-extension-sample-airoomgenerator-main (1)\kit-extension-sample-airoomgenerator-main\exts\omni.example.airoomgenerator\config’ failed to load.
2024-11-06 18:51:13 [Error] [carb.scripting-python.plugin] c:\users/kerem/appdata/local/ov/pkg/kit-106.0.2/kit/kernel/py\omni\ext_impl_internal.py(213): startup
2024-11-06 18:51:13 [Error] [omni.ext.plugin] [ext: config-1.0.0] Failed to startup python extension.
2024-11-06 18:51:14 [Error] [omni.kit.app._impl] [py stderr]: Traceback (most recent call last):
2024-11-06 18:51:14 [Error] [omni.kit.app._impl] [py stderr]: File “c:/users/kerem/appdata/local/ov/pkg/kit-106.0.2/extscache/omni.kit.widget.viewport-106.0.3+36286b8b/omni/kit/widget/viewport/widget.py”, line 125, in on_usd_context_event
2024-11-06 18:51:14 [Error] [omni.kit.app._impl] [py stderr]: self.__on_stage_opened(self.__ensure_usd_stage(), camera_path, resolution, hd_engine)
2024-11-06 18:51:14 [Error] [omni.kit.app._impl] [py stderr]: File “c:/users/kerem/appdata/local/ov/pkg/kit-106.0.2/extscache/omni.kit.widget.viewport-106.0.3+36286b8b/omni/kit/widget/viewport/widget.py”, line 495, in __on_stage_opened
2024-11-06 18:51:14 [Error] [omni.kit.app._impl] [py stderr]: hydra_texture = self.__viewport_texture._on_stage_opened(self.__set_image_data, camera_path, self.__is_first_instance())
2024-11-06 18:51:14 [Error] [omni.kit.app._impl] [py stderr]: File “c:/users/kerem/appdata/local/ov/pkg/kit-106.0.2/extscache/omni.kit.widget.viewport-106.0.3+36286b8b/omni/kit/widget/viewport/impl/texture.py”, line 317, in _on_stage_opened
2024-11-06 18:51:14 [Error] [omni.kit.app._impl] [py stderr]: self.__set_hd_engine(self.hydra_engine, None, first_init)
2024-11-06 18:51:14 [Error] [omni.kit.app._impl] [py stderr]: File “c:/users/kerem/appdata/local/ov/pkg/kit-106.0.2/extscache/omni.kit.widget.viewport-106.0.3+36286b8b/omni/kit/widget/viewport/impl/texture.py”, line 494, in __set_hd_engine
2024-11-06 18:51:14 [Error] [omni.kit.app._impl] [py stderr]: self.__hydra_texture_factory = omni.hydratexture.acquire_hydra_texture_factory_interface()
2024-11-06 18:51:14 [Error] [omni.kit.app._impl] [py stderr]: RuntimeError: Failed to acquire interface: omni::hydratexture::IHydraTextureFactory (pluginName: nullptr)
I would need a little more information. Is this running the new Kit App Template 106.0.2? Have you previously made it and run it successfully? It seems that something has changed. Have you accidently deleted a required library or directory? Did you change your video drivers?
I would focus in on “HydraTextureFactory” and “omni.ext._impl.custom_importer” as two areas. It looks like something has been removed, deleted, etc. You could try deleting the app build files and rebuilding it from your kit template.
Thank you for your answer. I was using it for days, but suddenly it doesnt work anymore. I changed nothing i deinstall it and install it new, but i have the same issues. It is the Omniverse Kit 106.0.2.
Can you show me a tutorial or something else i dont know how to change the files.
Well if I were honest, you are using a pretty old version of the KAT. You need to be on the very latest, the KAT 106.3. So I would just delete that whole template and the entire development folder, and start fresh with the 106.3 template from GitHub. GitHub - NVIDIA-Omniverse/kit-app-template: Omniverse Kit App Template
Do you have a tutorial how i can deinstall everything in a clear way?
There is no special way with this. It is literally just a simple download and run system. Therefore you would just use normal Windows Explorer to delete the entire Omniverse Kit App Template folder from the root and re-build. If you have a custom app that you would want to “upgrade” to the latest version of kit then there would be a special upgrade path.
Okay i will try it at the weekend and give you an answer.
I am not able to fix this problem, what is KAT and how i can implement it to my system
I reinstalled it and it worked, but i dont know why.
Ok good to hear.
