Contents of the repo.log file
[2025-10-16 10:01:13,823][INFO][omni.repo.man.entry.run:133] Running repo tool: repo_kit_template@1.4.2. args: ['template', 'new']
[2025-10-16 10:02:47,355][INFO][omni.repo.kit_template.backend.template_render.render_template_file:106] Rendering template /home/lestat/my-kit-project/templates/apps/kit_base_editor/kit_base_editor.kit to /home/lestat/my-kit-project/source/apps/my_company.my_editor.kit. Context: {'application_name': 'my_company.my_editor', 'application_display_name': 'My Editor', 'version': '0.1.0', 'repo_rendered_extensions': []}
[2025-10-16 10:03:06,027][INFO][omni.repo.kit_template.backend.repo.render_application_layer:438] Several template variables are passed through and preset: {'application_name': 'my_company.my_editor', 'application_display_name': 'My Editor', 'application_kit_filename': 'my_company.my_editor.kit', 'version': '0.1.0'}
[2025-10-16 10:03:06,029][INFO][omni.repo.kit_template.backend.templates.application_template._query_loop:43] Variable version encountered, will be set by setup extension template context.
[2025-10-16 10:03:06,029][INFO][omni.repo.kit_template.backend.templates.application_template._query_loop:43] Variable application_display_name encountered, will be set by setup extension template context.
[2025-10-16 10:03:06,029][INFO][omni.repo.kit_template.backend.templates.application_template._query_loop:43] Variable application_name encountered, will be set by setup extension template context.
[2025-10-16 10:03:06,029][INFO][omni.repo.kit_template.backend.template_render.render_template_file:106] Rendering template /home/lestat/my-kit-project/templates/apps/streaming_configs/default_stream.kit to /home/lestat/my-kit-project/source/apps/my_company.my_editor_streaming.kit. Context: {'application_name': 'my_company.my_editor', 'application_display_name': 'My Editor', 'application_kit_filename': 'my_company.my_editor.kit', 'version': '0.1.0', 'application_layer_name': 'my_company.my_editor_streaming'}
[2025-10-16 10:03:06,061][INFO][omni.repo.kit_template.backend.repo.render_application_layer:438] Several template variables are passed through and preset: {'application_name': 'my_company.my_editor', 'application_display_name': 'My Editor', 'application_kit_filename': 'my_company.my_editor.kit', 'version': '0.1.0'}
[2025-10-16 10:03:06,063][INFO][omni.repo.kit_template.backend.templates.application_template._query_loop:43] Variable version encountered, will be set by setup extension template context.
[2025-10-16 10:03:06,063][INFO][omni.repo.kit_template.backend.templates.application_template._query_loop:43] Variable application_display_name encountered, will be set by setup extension template context.
[2025-10-16 10:03:06,063][INFO][omni.repo.kit_template.backend.templates.application_template._query_loop:43] Variable application_name encountered, will be set by setup extension template context.
[2025-10-16 10:03:06,063][INFO][omni.repo.kit_template.backend.template_render.render_template_file:106] Rendering template /home/lestat/my-kit-project/templates/apps/streaming_configs/nvcf_stream.kit to /home/lestat/my-kit-project/source/apps/my_company.my_editor_nvcf.kit. Context: {'application_name': 'my_company.my_editor', 'application_display_name': 'My Editor', 'application_kit_filename': 'my_company.my_editor.kit', 'version': '0.1.0', 'application_layer_name': 'my_company.my_editor_nvcf'}
[2025-10-16 10:03:06,098][INFO][omni.repo.kit_template.backend.repo.render_application_layer:438] Several template variables are passed through and preset: {'application_name': 'my_company.my_editor', 'application_display_name': 'My Editor', 'application_kit_filename': 'my_company.my_editor.kit', 'version': '0.1.0'}
[2025-10-16 10:03:06,100][INFO][omni.repo.kit_template.backend.templates.application_template._query_loop:43] Variable version encountered, will be set by setup extension template context.
[2025-10-16 10:03:06,100][INFO][omni.repo.kit_template.backend.templates.application_template._query_loop:43] Variable application_display_name encountered, will be set by setup extension template context.
[2025-10-16 10:03:06,100][INFO][omni.repo.kit_template.backend.templates.application_template._query_loop:43] Variable application_name encountered, will be set by setup extension template context.
[2025-10-16 10:03:06,100][INFO][omni.repo.kit_template.backend.template_render.render_template_file:106] Rendering template /home/lestat/my-kit-project/templates/apps/streaming_configs/gdn_stream.kit to /home/lestat/my-kit-project/source/apps/my_company.my_editor_gdn_streaming.kit. Context: {'application_name': 'my_company.my_editor', 'application_display_name': 'My Editor', 'application_kit_filename': 'my_company.my_editor.kit', 'version': '0.1.0', 'application_layer_name': 'my_company.my_editor_gdn_streaming'}
[2025-10-16 10:03:20,160][INFO][omni.repo.man.entry.run:133] Running repo tool: repo_build@1.13.2. args: ['build']
[2025-10-16 10:03:20,161][INFO][omni.repo.man.utils.set_niceness:1013] set IO niceness to 3 (idle)
[2025-10-16 10:03:20,163][INFO][omni.repo.man.utils.set_niceness:1027] set process niceness to 19 (max)
[2025-10-16 10:03:20,163][INFO][omni.repo.man.configuration.set_token:231] Token: 'platform_target' set to 'linux-aarch64'
[2025-10-16 10:03:20,163][INFO][omni.repo.man.configuration.set_token:231] Token: 'platform_target_abi' set to 'manylinux_2_35_aarch64'
[2025-10-16 10:03:20,163][INFO][omni.repo.build.dependencies.pull_files:275] Skipping project file (doesn't exist): /home/lestat/my-kit-project/deps/host-deps.packman.xml
[2025-10-16 10:03:20,163][INFO][omni.repo.build.dependencies.pull_files:275] Skipping project file (doesn't exist): /home/lestat/my-kit-project/tools/deps/host-deps.packman.xml
[2025-10-16 10:03:32,929][INFO][omni.repo.man.utils.run_process:241] running process: /home/lestat/my-kit-project/repo.sh precache_exts -c release
[2025-10-16 10:03:33,518][INFO][omni.repo.man.entry.run:133] Running repo tool: repo_precache_exts@None. args: ['precache_exts', '-c', 'release']
[2025-10-16 10:03:33,518][INFO][omni.repo.precache_exts.run:315] precaching app: /home/lestat/my-kit-project/source/apps/my_company.my_editor.kit
[2025-10-16 10:03:33,519][INFO][omni.repo.man.utils.run_process:241] running process: /home/lestat/my-kit-project/_build/linux-aarch64/release/kit/kit /home/lestat/my-kit-project/source/apps/my_company.my_editor.kit --allow-root --portable --ext-precache-mode --/crashreporter/gatherUserStory=0 --/app/settings/persistent=0 --/app/settings/loadUserConfig=0 --/app/extensions/generateVersionLock=1 --/app/extensions/parallelPullEnabled=1 --/app/enableStdoutOutput=1 --/app/extensions/detailedSolverExplanation=1 --/app/extensions/registryEnabled=1 --/app/extensions/mkdirExtFolders=0 '--/app/extensions/registryCacheFull='"'"'/home/lestat/my-kit-project/_build/linux-aarch64/release/extscache'"'"'' --/log/flushStandardStreamOutput=1 '--/exts/omni.kit.registry.nucleus/registries/0/name="kit/prod/default"' '--/exts/omni.kit.registry.nucleus/registries/0/url="https://ovextensionsprod.blob.core.windows.net/exts/kit/prod/${kit_version_major}/shared"' '--/exts/omni.kit.registry.nucleus/registries/1/name="kit/prod/sdk"' '--/exts/omni.kit.registry.nucleus/registries/1/url="https://ovextensionsprod.blob.core.windows.net/exts/kit/prod/sdk/${kit_version_short}/${kit_git_hash}"' '--/exts/omni.kit.registry.nucleus/registries/2/name="kit/community"' '--/exts/omni.kit.registry.nucleus/registries/2/url="https://dw290v42wisod.cloudfront.net/exts/kit/community"' --/app/extensions/target/config=release --ext-folder /home/lestat/my-kit-project/source/extensions --ext-folder /home/lestat/my-kit-project/source/apps --portable-root /home/lestat/my-kit-project/_build/linux-aarch64/release --/app/extensions/generateVersionLockSkipLocalExts=1
[2025-10-16 10:03:33,521][ERROR][omni.repo.man.utils.run_process:264] error running: /home/lestat/my-kit-project/_build/linux-aarch64/release/kit/kit /home/lestat/my-kit-project/source/apps/my_company.my_editor.kit --allow-root --portable --ext-precache-mode --/crashreporter/gatherUserStory=0 --/app/settings/persistent=0 --/app/settings/loadUserConfig=0 --/app/extensions/generateVersionLock=1 --/app/extensions/parallelPullEnabled=1 --/app/enableStdoutOutput=1 --/app/extensions/detailedSolverExplanation=1 --/app/extensions/registryEnabled=1 --/app/extensions/mkdirExtFolders=0 '--/app/extensions/registryCacheFull='"'"'/home/lestat/my-kit-project/_build/linux-aarch64/release/extscache'"'"'' --/log/flushStandardStreamOutput=1 '--/exts/omni.kit.registry.nucleus/registries/0/name="kit/prod/default"' '--/exts/omni.kit.registry.nucleus/registries/0/url="https://ovextensionsprod.blob.core.windows.net/exts/kit/prod/${kit_version_major}/shared"' '--/exts/omni.kit.registry.nucleus/registries/1/name="kit/prod/sdk"' '--/exts/omni.kit.registry.nucleus/registries/1/url="https://ovextensionsprod.blob.core.windows.net/exts/kit/prod/sdk/${kit_version_short}/${kit_git_hash}"' '--/exts/omni.kit.registry.nucleus/registries/2/name="kit/community"' '--/exts/omni.kit.registry.nucleus/registries/2/url="https://dw290v42wisod.cloudfront.net/exts/kit/community"' --/app/extensions/target/config=release --ext-folder /home/lestat/my-kit-project/source/extensions --ext-folder /home/lestat/my-kit-project/source/apps --portable-root /home/lestat/my-kit-project/_build/linux-aarch64/release --/app/extensions/generateVersionLockSkipLocalExts=1, code: -1, message: "[Errno 8] Exec format error: '/home/lestat/my-kit-project/_build/linux-aarch64/release/kit/kit'"
[2025-10-16 10:03:33,528][ERROR][omni.repo.man.exceptions_utils.print_log:182] SystemExit exception stack trace dumped to logfile /home/lestat/my-kit-project/_repo/repo.log. Stacks dumped to console via `--verbose` or `--tracebacks`.
SystemExit: -1
[2025-10-16 10:03:33,529][ERROR][omni.repo.emit_stack_to_logfile:156] SystemExit encountered while running repo_precache_exts via ['/home/lestat/my-kit-project/tools/repoman/repoman.py', 'precache_exts', '-c', 'release']:
File "/home/lestat/my-kit-project/_repo/deps/repo_man/omni/repo/man/entry.py", line 138, in run
options.func(options)
File "/home/lestat/my-kit-project/_repo/deps/repo_man/omni/repo/man/entry.py", line 90, in <lambda>
func=lambda args, func=func, config=self.merged_tool_config: func(args, config),
File "/home/lestat/src/omniverse/kit/dev/tools/repoman/precache_exts.py", line 481, in run_repo_tool
run(tool_config, options, repo_folders["root"], platform_host)
File "/home/lestat/src/omniverse/kit/dev/tools/repoman/precache_exts.py", line 434, in run
sys.exit(returncode)
SystemExit: -1
[2025-10-16 10:03:33,593][ERROR][omni.repo.man.utils.run_process:264] error running: /home/lestat/my-kit-project/repo.sh precache_exts -c release, code: 255, message: ""
[2025-10-16 10:03:33,597][WARNING][omni.repo.man.version.get_tool_version:312] Retrieving repo_build version via VERSION file.
[2025-10-16 10:03:33,599][ERROR][omni.repo.man.exceptions_utils.print_log:182] SystemExit exception stack trace dumped to logfile /home/lestat/my-kit-project/_repo/repo.log. Stacks dumped to console via `--verbose` or `--tracebacks`.
SystemExit: 255
[2025-10-16 10:03:33,600][ERROR][omni.repo.emit_stack_to_logfile:156] SystemExit encountered while running repo_build via ['/home/lestat/my-kit-project/tools/repoman/repoman.py', 'build']:
File "/home/lestat/my-kit-project/_repo/deps/repo_build/omni/repo/build/main.py", line 1576, in run_repo_tool
run_build(options, repo_folders, None, config)
File "/home/lestat/my-kit-project/_repo/deps/repo_build/omni/repo/build/utils.py", line 49, in wrapper
return func(*args, **kwargs)
File "/home/lestat/my-kit-project/_repo/deps/repo_build/omni/repo/build/main.py", line 1124, in run_build
process_after_pull_commands(
File "/home/lestat/my-kit-project/_repo/deps/repo_build/omni/repo/build/dependencies.py", line 364, in process_after_pull_commands
run_command(command, repo_folders, platform_target, config, extra_tokens, print_name="After Pull Commands")
File "/home/lestat/my-kit-project/_repo/deps/repo_build/omni/repo/build/utils.py", line 23, in run_command
run_process(command, exit_on_error=True)
File "/home/lestat/my-kit-project/_repo/deps/repo_man/omni/repo/man/utils.py", line 266, in run_process
SystemExit: 255
[2025-10-16 10:25:19,962][INFO][omni.repo.man.entry.run:133] Running repo tool: repo_kit_template@1.4.2. args: ['template', 'new']
[2025-10-16 10:26:58,251][INFO][omni.repo.kit_template.backend.template_render.render_template_file:106] Rendering template /home/lestat/my-kit-project/templates/apps/kit_base_editor/kit_base_editor.kit to /home/lestat/my-kit-project/source/apps/my_company.my_editor.kit. Context: {'application_name': 'my_company.my_editor', 'application_display_name': 'My Editor ', 'version': '0.1.0', 'repo_rendered_extensions': []}
[2025-10-16 10:26:58,276][INFO][omni.repo.kit_template.backend.templates.application_template._add_app_to_premake:197] App define string: define_app("my_company.my_editor.kit") found in premake file: /home/lestat/my-kit-project/premake5.lua
[2025-10-16 10:26:58,298][INFO][omni.repo.kit_template.backend.templates.application_template._add_repo_precache_exts:234] Kit app ${root}/source/apps/my_company.my_editor.kit is already present.
[2025-10-16 10:28:10,307][INFO][omni.repo.kit_template.backend.repo.render_application_layer:438] Several template variables are passed through and preset: {'application_name': 'my_company.my_editor', 'application_display_name': 'My Editor ', 'application_kit_filename': 'my_company.my_editor.kit', 'version': '0.1.0'}
[2025-10-16 10:28:10,308][INFO][omni.repo.kit_template.backend.templates.application_template._query_loop:43] Variable version encountered, will be set by setup extension template context.
[2025-10-16 10:28:10,308][INFO][omni.repo.kit_template.backend.templates.application_template._query_loop:43] Variable application_display_name encountered, will be set by setup extension template context.
[2025-10-16 10:28:10,308][INFO][omni.repo.kit_template.backend.templates.application_template._query_loop:43] Variable application_name encountered, will be set by setup extension template context.
[2025-10-16 10:28:10,309][INFO][omni.repo.kit_template.backend.template_render.render_template_file:106] Rendering template /home/lestat/my-kit-project/templates/apps/streaming_configs/default_stream.kit to /home/lestat/my-kit-project/source/apps/my_company.my_editor_streaming.kit. Context: {'application_name': 'my_company.my_editor', 'application_display_name': 'My Editor ', 'application_kit_filename': 'my_company.my_editor.kit', 'version': '0.1.0', 'application_layer_name': 'my_company.my_editor_streaming'}
[2025-10-16 10:28:10,318][INFO][omni.repo.kit_template.backend.templates.application_template._add_app_to_premake:197] App define string: define_app("my_company.my_editor_streaming.kit") found in premake file: /home/lestat/my-kit-project/premake5.lua
[2025-10-16 10:28:10,341][INFO][omni.repo.kit_template.backend.templates.application_template._add_repo_precache_exts:234] Kit app ${root}/source/apps/my_company.my_editor_streaming.kit is already present.
[2025-10-16 10:28:10,342][INFO][omni.repo.kit_template.backend.repo.render_application_layer:438] Several template variables are passed through and preset: {'application_name': 'my_company.my_editor', 'application_display_name': 'My Editor ', 'application_kit_filename': 'my_company.my_editor.kit', 'version': '0.1.0'}
[2025-10-16 10:28:10,343][INFO][omni.repo.kit_template.backend.templates.application_template._query_loop:43] Variable version encountered, will be set by setup extension template context.
[2025-10-16 10:28:10,343][INFO][omni.repo.kit_template.backend.templates.application_template._query_loop:43] Variable application_display_name encountered, will be set by setup extension template context.
[2025-10-16 10:28:10,343][INFO][omni.repo.kit_template.backend.templates.application_template._query_loop:43] Variable application_name encountered, will be set by setup extension template context.
[2025-10-16 10:28:10,343][INFO][omni.repo.kit_template.backend.template_render.render_template_file:106] Rendering template /home/lestat/my-kit-project/templates/apps/streaming_configs/nvcf_stream.kit to /home/lestat/my-kit-project/source/apps/my_company.my_editor_nvcf.kit. Context: {'application_name': 'my_company.my_editor', 'application_display_name': 'My Editor ', 'application_kit_filename': 'my_company.my_editor.kit', 'version': '0.1.0', 'application_layer_name': 'my_company.my_editor_nvcf'}
[2025-10-16 10:28:10,356][INFO][omni.repo.kit_template.backend.templates.application_template._add_app_to_premake:197] App define string: define_app("my_company.my_editor_nvcf.kit") found in premake file: /home/lestat/my-kit-project/premake5.lua
[2025-10-16 10:28:10,378][INFO][omni.repo.kit_template.backend.templates.application_template._add_repo_precache_exts:234] Kit app ${root}/source/apps/my_company.my_editor_nvcf.kit is already present.
[2025-10-16 10:28:10,379][INFO][omni.repo.kit_template.backend.repo.render_application_layer:438] Several template variables are passed through and preset: {'application_name': 'my_company.my_editor', 'application_display_name': 'My Editor ', 'application_kit_filename': 'my_company.my_editor.kit', 'version': '0.1.0'}
[2025-10-16 10:28:10,381][INFO][omni.repo.kit_template.backend.templates.application_template._query_loop:43] Variable version encountered, will be set by setup extension template context.
[2025-10-16 10:28:10,381][INFO][omni.repo.kit_template.backend.templates.application_template._query_loop:43] Variable application_display_name encountered, will be set by setup extension template context.
[2025-10-16 10:28:10,381][INFO][omni.repo.kit_template.backend.templates.application_template._query_loop:43] Variable application_name encountered, will be set by setup extension template context.
[2025-10-16 10:28:10,381][INFO][omni.repo.kit_template.backend.template_render.render_template_file:106] Rendering template /home/lestat/my-kit-project/templates/apps/streaming_configs/gdn_stream.kit to /home/lestat/my-kit-project/source/apps/my_company.my_editor_gdn_streaming.kit. Context: {'application_name': 'my_company.my_editor', 'application_display_name': 'My Editor ', 'application_kit_filename': 'my_company.my_editor.kit', 'version': '0.1.0', 'application_layer_name': 'my_company.my_editor_gdn_streaming'}
[2025-10-16 10:28:10,402][INFO][omni.repo.kit_template.backend.templates.application_template._add_app_to_premake:197] App define string: define_app("my_company.my_editor_gdn_streaming.kit") found in premake file: /home/lestat/my-kit-project/premake5.lua
[2025-10-16 10:28:10,458][INFO][omni.repo.kit_template.backend.templates.application_template._add_repo_precache_exts:234] Kit app ${root}/source/apps/my_company.my_editor_gdn_streaming.kit is already present.
[2025-10-16 10:29:02,558][INFO][omni.repo.man.entry.run:133] Running repo tool: repo_build@1.13.2. args: ['build']
[2025-10-16 10:29:02,559][INFO][omni.repo.man.utils.set_niceness:1013] set IO niceness to 3 (idle)
[2025-10-16 10:29:02,560][INFO][omni.repo.man.utils.set_niceness:1027] set process niceness to 19 (max)
[2025-10-16 10:29:02,560][INFO][omni.repo.man.configuration.set_token:231] Token: 'platform_target' set to 'linux-aarch64'
[2025-10-16 10:29:02,560][INFO][omni.repo.man.configuration.set_token:231] Token: 'platform_target_abi' set to 'manylinux_2_35_aarch64'
[2025-10-16 10:29:02,560][INFO][omni.repo.build.dependencies.pull_files:275] Skipping project file (doesn't exist): /home/lestat/my-kit-project/deps/host-deps.packman.xml
[2025-10-16 10:29:02,560][INFO][omni.repo.build.dependencies.pull_files:275] Skipping project file (doesn't exist): /home/lestat/my-kit-project/tools/deps/host-deps.packman.xml
[2025-10-16 10:29:02,564][INFO][omni.repo.man.utils.run_process:241] running process: /home/lestat/my-kit-project/repo.sh precache_exts -c release
[2025-10-16 10:29:03,189][INFO][omni.repo.man.entry.run:133] Running repo tool: repo_precache_exts@None. args: ['precache_exts', '-c', 'release']
[2025-10-16 10:29:03,190][INFO][omni.repo.precache_exts.run:315] precaching app: /home/lestat/my-kit-project/source/apps/my_company.my_editor.kit
[2025-10-16 10:29:03,190][INFO][omni.repo.man.utils.run_process:241] running process: /home/lestat/my-kit-project/_build/linux-aarch64/release/kit/kit /home/lestat/my-kit-project/source/apps/my_company.my_editor.kit --allow-root --portable --ext-precache-mode --/crashreporter/gatherUserStory=0 --/app/settings/persistent=0 --/app/settings/loadUserConfig=0 --/app/extensions/generateVersionLock=1 --/app/extensions/parallelPullEnabled=1 --/app/enableStdoutOutput=1 --/app/extensions/detailedSolverExplanation=1 --/app/extensions/registryEnabled=1 --/app/extensions/mkdirExtFolders=0 '--/app/extensions/registryCacheFull='"'"'/home/lestat/my-kit-project/_build/linux-aarch64/release/extscache'"'"'' --/log/flushStandardStreamOutput=1 '--/exts/omni.kit.registry.nucleus/registries/0/name="kit/prod/default"' '--/exts/omni.kit.registry.nucleus/registries/0/url="https://ovextensionsprod.blob.core.windows.net/exts/kit/prod/${kit_version_major}/shared"' '--/exts/omni.kit.registry.nucleus/registries/1/name="kit/prod/sdk"' '--/exts/omni.kit.registry.nucleus/registries/1/url="https://ovextensionsprod.blob.core.windows.net/exts/kit/prod/sdk/${kit_version_short}/${kit_git_hash}"' '--/exts/omni.kit.registry.nucleus/registries/2/name="kit/community"' '--/exts/omni.kit.registry.nucleus/registries/2/url="https://dw290v42wisod.cloudfront.net/exts/kit/community"' --/app/extensions/target/config=release --ext-folder /home/lestat/my-kit-project/source/extensions --ext-folder /home/lestat/my-kit-project/source/apps --portable-root /home/lestat/my-kit-project/_build/linux-aarch64/release --/app/extensions/generateVersionLockSkipLocalExts=1
[2025-10-16 10:29:03,192][ERROR][omni.repo.man.utils.run_process:264] error running: /home/lestat/my-kit-project/_build/linux-aarch64/release/kit/kit /home/lestat/my-kit-project/source/apps/my_company.my_editor.kit --allow-root --portable --ext-precache-mode --/crashreporter/gatherUserStory=0 --/app/settings/persistent=0 --/app/settings/loadUserConfig=0 --/app/extensions/generateVersionLock=1 --/app/extensions/parallelPullEnabled=1 --/app/enableStdoutOutput=1 --/app/extensions/detailedSolverExplanation=1 --/app/extensions/registryEnabled=1 --/app/extensions/mkdirExtFolders=0 '--/app/extensions/registryCacheFull='"'"'/home/lestat/my-kit-project/_build/linux-aarch64/release/extscache'"'"'' --/log/flushStandardStreamOutput=1 '--/exts/omni.kit.registry.nucleus/registries/0/name="kit/prod/default"' '--/exts/omni.kit.registry.nucleus/registries/0/url="https://ovextensionsprod.blob.core.windows.net/exts/kit/prod/${kit_version_major}/shared"' '--/exts/omni.kit.registry.nucleus/registries/1/name="kit/prod/sdk"' '--/exts/omni.kit.registry.nucleus/registries/1/url="https://ovextensionsprod.blob.core.windows.net/exts/kit/prod/sdk/${kit_version_short}/${kit_git_hash}"' '--/exts/omni.kit.registry.nucleus/registries/2/name="kit/community"' '--/exts/omni.kit.registry.nucleus/registries/2/url="https://dw290v42wisod.cloudfront.net/exts/kit/community"' --/app/extensions/target/config=release --ext-folder /home/lestat/my-kit-project/source/extensions --ext-folder /home/lestat/my-kit-project/source/apps --portable-root /home/lestat/my-kit-project/_build/linux-aarch64/release --/app/extensions/generateVersionLockSkipLocalExts=1, code: -1, message: "[Errno 8] Exec format error: '/home/lestat/my-kit-project/_build/linux-aarch64/release/kit/kit'"
[2025-10-16 10:29:03,198][ERROR][omni.repo.man.exceptions_utils.print_log:182] SystemExit exception stack trace dumped to logfile /home/lestat/my-kit-project/_repo/repo.log. Stacks dumped to console via `--verbose` or `--tracebacks`.
SystemExit: -1
[2025-10-16 10:29:03,199][ERROR][omni.repo.emit_stack_to_logfile:156] SystemExit encountered while running repo_precache_exts via ['/home/lestat/my-kit-project/tools/repoman/repoman.py', 'precache_exts', '-c', 'release']:
SystemExit: -1
[2025-10-16 10:29:03,262][ERROR][omni.repo.man.utils.run_process:264] error running: /home/lestat/my-kit-project/repo.sh precache_exts -c release, code: 255, message: ""
[2025-10-16 10:29:03,266][WARNING][omni.repo.man.version.get_tool_version:312] Retrieving repo_build version via VERSION file.
[2025-10-16 10:29:03,268][ERROR][omni.repo.man.exceptions_utils.print_log:182] SystemExit exception stack trace dumped to logfile /home/lestat/my-kit-project/_repo/repo.log. Stacks dumped to console via `--verbose` or `--tracebacks`.
SystemExit: 255
[2025-10-16 10:29:03,269][ERROR][omni.repo.emit_stack_to_logfile:156] SystemExit encountered while running repo_build via ['/home/lestat/my-kit-project/tools/repoman/repoman.py', 'build']:
SystemExit: 255
