Hardware: NVIDIA Jetson Orin NX 16GB
Environment: Ubuntu 20.04 Docker container, running inside a host VM Ubuntu 20.04
SDK Manager 2.3, JetPack 6.2.1
I have flashed my device succeasfully by SDK Manager running in the VM Ubuntu 20.04 before, now I’m trying to refer to this guidance Docker Images — SDK Manager to build my own Docker.
Download & Pre-Installation went pretty smoothly, images are created, however after the device booted up into initrd and the flashing was meant to started, I got this error
I also tried to go inside the device and perform manual mount from there, but also failed no matter how I refresh my host side’s /etc/exports or restart the nfs-kernel-server service.
Thank you for your reply, while waiting for your guidance I’ll try to provide as much context as possible.
On my VM Host, I have:
created a user named “thong”, then switch to that user and create these 2 folders (empty) at:
/home/thong/nvidia/nvidia_sdk/JetPack…/Linux_for_Tegra/rootfs
/home/thong/nvidia/nvidia_sdk/JetPack…/Linux_for_Tegra/tools/kernel_flash/images
set their owner as root.root & give permission 755
exported them by adding these lines in /etc/exports
/home/<new_user>/nvidia_VM/nvidia_sdk/JetPack_6.2.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/rootfs *(rw,nohide,insecure,no_subtree_check,async,no_root_squash)
/home/<new_user>/nvidia_VM/nvidia_sdk/JetPack_6.2.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images *(rw,nohide,insecure,no_subtree_check,async,no_root_squash)
used the user’s name, UID and GID to create a new user inside Docker container, and when building I also map them like this (I can only map the outmost parent folder, if I map the full path they would not be removed and created again during the flash process):
-v /home/thong/nvidia:/home/thong/nvidia
Inside the container, I created /run/nvidia_initrd_flash/docker_host_network
During the flash process, I continuously supervise the content of the 2 folders (form when they were still empty until they got all files). In some tests I also try running sudo exportfs -ra to refresh the export status after I see something changed inside those folders, but I still failed to proceed.
Instead of exporting directly the folders that the devices are going to mount (and fail due to “stale file handle”, we try to export the parent folder and add “no_subtree_check” flag as below
