I am doing an LT6911UXC (HDMI to MIPI/CSI) chip based board with the Xavier NX Dev Kit.
I am trying to connect the LT6911UXC board and the Xavier NX Dev Kit via J1 connector which using CSI0 2 lanes.
However, before connecting, there is a problem.
Even though the Xavier NX Dev Kit and the LT6911uxc are not physically connected, it is detected on the Xavier NX Dev Kit. When I executed the command ‘/dev/video/’, it detected the device as below.
Is it normal for this situation?
I think there are problems in the device tree file. Can you check my device tree?
These are the processes that I have done so far. I didn’t modify any other things but this.
(And I used the LT6911uxc device driver from the L4T BSP sources, 32.6.1)
- 'tegra194-p3668-all-p3509-0000.dts’
It is placed in this directory, ‘…/public/hardware/nvidia/platform/t19x/jakku/kernel-dts/’
- As you can see it includes two dtsi files.
A) ‘tegra194-p3688-common.dtsi’
It is placed in this directory, ‘…/public/hardware/nvidia/platform/t19x/jakku/kernel-dts/common’
B) ‘tegra194-p3688-0000-a00.dtsi’
In this file I created “tegra194-camera-jakku-rbpcv2-lt6911uxc.dtsi” file and included in it.
This file, “tegra194-camera-jakku-rbpcv2-lt6911uxc.dtsi”, is located in here, ‘…/public/hardware/nvidia/platform/t19x/jakku/kernel-dts/common’.
- I made this device tree,“tegra194-camera-jakku-rbpcv2-lt6911uxc.dtsi”, like below.
Here is the Device tree code.
#include <dt-bindings/media/camera.h>
#define CAM0_PWDN TEGRA194_MAIN_GPIO(P, 4)
#define CAM1_PWDN TEGRA194_MAIN_GPIO(P, 5)
#define CAM_I2C_MUX TEGRA194_AON_GPIO(CC, 3)
host1x {
vi@15c10000 {
num-channels = <1>;
ports {
#address-cells = <1>;
#size-cells = <0>;
vi_port0: port@0 {
reg = <0>;
rbpcv2_lt6911uxc_vi_in0: endpoint {
status = “okay”;
port-index = <0>;
bus-width = <2>;
remote-endpoint = <&rbpcv2_lt6911uxc_csi_out0>;
nvcsi@15a00000 {
num-channels = <1>;
#size-cells = <0>;
csi_chan0: channel@0 {
reg = <0>;
ports {
#size-cells = <0>;
csi_chan0_port0: port@0 {
reg = <0>;
rbpcv2_lt6911uxc_csi_in0: endpoint@0 {
status = "okay";
port-index = <0>;
bus-width = <2>;
remote-endpoint = <&rbpcv2_lt6911uxc_out0>;
csi_chan0_port1: port@1 {
reg = <1>;
rbpcv2_lt6911uxc_csi_out0: endpoint@1 {
status = "okay";
remote-endpoint = <&rbpcv2_lt6911uxc_vi_in0>;
cam_i2cmux{
compatible = "i2c-mux-gpio";
#size-cells = <0>;
i2c-parent = <&cam_i2c>;
mux-gpios = <&tegra_aon_gpio CAM_I2C_MUX GPIO_ACTIVE_HIGH>;
i2c@0 {
reg = <0>;
#size-cells = <0>;
rbpcv2_lt6911uxc_a@2b {
compatible = "nvidia,lt6911uxc";
reg = <0x2b>;
devnode = "video0";
physical_w = "3.674";
physical_h = "2.738";
sensor_model = "lt6911uxc";
use_sensor_mode_id = "true";
status = "okay";
reset-gpios = <&tegra_main_gpio CAM0_PWDN GPIO_ACTIVE_HIGH>;
mode0 { // E2832_1920x1080_60Fps
mclk_khz = "24000";
num_lanes = "4";
phy_mode = "DPHY";
discontinuous_clk = "yes";
dpcm_enable = "false";
cil_settletime = "0";
active_w = "1920";
active_h = "1080";
mode_type = "rgb";
pixel_phase = "rgb888";
csi_pixel_bit_depth = "24";
readout_orientation = "0";
line_length = "1920";
inherent_gain = "1";
mclk_multiplier = "24";
pix_clk_hz = "576000000";
gain_factor = "16";
framerate_factor = "1000000";
exposure_factor = "1000000";
min_gain_val = "16"; /* 1.00x */
max_gain_val = "170"; /* 10.66x */
step_gain_val = "1";
default_gain = "16"; /* 1.00x */
min_hdr_ratio = "1";
max_hdr_ratio = "1";
min_framerate = "2000000"; /* 2.0 fps */
max_framerate = "60000000"; /* 60.0 fps */
step_framerate = "1";
default_framerate = "60000000"; /* 60.0 fps */
min_exp_time = "13"; /* us */
max_exp_time = "683709"; /* us */
step_exp_time = "1";
default_exp_time = "16667"; /* us */
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
rbpcv2_lt6911uxc_out0: endpoint {
status = "okay";
port-index = <0>;
bus-width = <2>;
remote-endpoint = <&rbpcv2_lt6911uxc_csi_in0>;
/*gpio@2200000 {
camera-control-output-low {
gpio-hog;
output-low;
gpios = <CAM0_PWDN 0 CAM1_PWDN 0>;
label = "cam0-pwdn","cam1-pwdn";
tegra-camera-platform {
compatible = “nvidia, tegra-camera-platform”;
num_csi_lanes = <2>;
max_lane_speed = <1500000>;
min_bits_per_pixel = <10>;
vi_peak_byte_per_pixel = <2>;
vi_bw_margin_pct = <25>;
max_pixel_rate = <750000>;
isp_peak_byte_per_pixel = <5>;
isp_bw_margin_pct = <25>;
modules {
cam_module0: module0 {
status = "okay";
badge = "jakku_front_LT6911UXC";
position = "front"; //position = "bottom";
orientation = "1";
cam_module0_drivernode0: drivernode0 {
pcl_id = "v4l2_sensor";
devname = "lt6911uxc 9-002b"; // I2C Bus num and Addr num
proc-device-tree = "/proc/device-tree/cam_i2cmux/i2c@0/rbpcv2_lt6911uxc_a@2b";
Can you check that my device tree wrote correctly?
