• Hardware Platform (Jetson / GPU) DGPU / Jetson NX
• DeepStream Version 5.x
• JetPack Version (valid for Jetson only) 4.6
• TensorRT Version
We have built a Deepstream application that uses the TLT(3) Detectnet v2 Object detection example that detects 1 class (lets say car). The accuracy of the trained model is quite good. For further specification of the car make, we trained another model → an image classifier, again folowing the example notebook in TLT. This model will work as a secondary classifier (SGIE).
The image classifier is trained using 5k+ images and the inference results IN TLT are really good (mAP >92%)
Now when we try the image classifier in the deepstream app, the accuracy is very very poor.
According to other forum posts, I’ve been fiddling with the “Offsets” values’ in the SGIE config file which changes the inference accuracy, but there’s no documentation about the offsets values, So I can’t tell which values to tweak.
While looking for similar posts, I saw there were even differences isn what offsets to use between the different forum moderators. Which values should I use?
The TLT trainingspec is
the default classifier
Here’s the configfile for the SGIE:
classifier-threshold, is-classifier
Optional properties for classifiers:
classifier-async-mode(Secondary mode only, Default=false)
Optional properties in secondary mode:
operate-on-gie-id(Default=0), operate-on-class-ids(Defaults to all classes),
input-object-min-width, input-object-min-height, input-object-max-width,
input-object-max-height
Following properties are always recommended:
batch-size(Default=1)
Other optional properties:
net-scale-factor(Default=1), network-mode(Default=0 i.e FP32),
model-color-format(Default=0 i.e. RGB) model-engine-file, labelfile-path,
mean-file, gie-unique-id(Default=0), offsets, process-mode (Default=1 i.e. primary),
custom-lib-path, network-mode(Default=0 i.e FP32)
The values in the config file are overridden by values set through GObject
properties.
[property]
The gie unique id is the main ID which helps in acessing objects of config file which is currently processed.
gie-unique-id=2
Scaling images
net-scale-factor=1
Path to the tlt model
model-engine-file=models/secondary/final_model.trt
Path to label file
labelfile-path=models/secondary/labels.txt
Input dims of the image
input-object-min-width=50
#input-object-min-height=2
Model-color-format(Default=0 i.e. RGB)
model-color-format=0
offsets=124;117;104
force-implicit-batch-dim=1
0=FP32, 1=INT8, 2=FP16 mode
network-mode=1
0=Detector, 1=Classifier, 2=Segmentation, 100=Other
network-type=1
num-detected-classes=3
Class IDs of the parent GIE on which this GIE must operate.
The parent GIE is specified using operate-on-gie-id.
operate-on-class-ids=0
operate-on-gie-id=1
It is used when we are using Classifier after detection
classifier-async-mode=1
classifier-threshold=0.5
#scaling-filter=0
#scaling-compute-hw=0
