Hello everyone,
I’m experiencing an issue with my Jetson Xavier NX and hope someone can assist.
Problem Description:
- Hardware: Jetson Xavier NX (same hardware configuration)
- JetPack Versions:
- 4.6.4: During boot, the fan remains off. Only after the operating system has fully loaded and the NVIDIA Fan Control is running does the fan start operating as expected.
- 5.1.2: During boot, even before the kernel starts, the fan turns on and runs at about 50% speed. After the operating system has loaded and the NVIDIA Fan Control is active, the fan behavior is the same as in the previous version.
It seems that the changed fan behavior during the early boot process is related to the UEFI settings, particularly with MT1 and MT2.
What I’ve Tried So Far:
- Comparing Thermal Configurations: After the operating system starts, the fan control is identical in both versions, indicating that the thermal settings within the OS are correct.
- Investigating UEFI: Since the issue occurs before the kernel loads, I suspect it has to do with changed UEFI settings. However, I’m unsure how to adjust these.
Question:
How can I configure the fan behavior during boot under JetPack 5.1.2 to match that of JetPack 4.6.4? I want the fan to remain off or even better at around 10% during the boot process and only be controlled by the NVIDIA Fan Control after the OS has started.
Has anyone experienced similar issues or can provide guidance on how to adjust the UEFI or bootloader settings to change the fan behavior during boot?
Thank you in advance for your help!
Best regards,
d.glaesner1
