Digital Output from Jetson Nano Developer Kit
Hello Team,
We want to give digital outputs to control 04 nos of Relays using the Jetson Nano developer kit. The Relay can support input voltages from 1.8 to 5 VDC and can Switch Outputs of 24 VDC. Can you help us in understanding which all GPIO pins should we consider for this control Operation?
Please refer to the product design guide and P3449 schematic in DLC. The pins marked as GPIO on 40-pin header can be used for that.
Hello @albin.manjaly ,
Checking his post might be beneficial for you.
Regards.
