Display Errors and Boot Time Delays on TX2 NX
Issue Description
  1. When using the official L4T 32.7.1 (non-customized) to flash the TX2 NX core board, there are log differences observed on our carrier board. The logs from the abnormal core board display a series of errors related to nvdisplay. However, the logs from the normal core board are relatively clean and do not show similar errors.
  2. The occurrence of the first issue is due to the flashing of our modified L4T 32.7.1 onto the abnormal core board during the production process. Subsequently, we noticed an unusually long system boot time and encountered numerous “edid invalid” errors in the system logs. To address this issue, we initiated troubleshooting steps.
  3. Multiple abnormal core boards have still been observed recently.
  4. We are still experiencing the issue with L4T 32.7.4.
Differences Logs in Official L4T 32.7.1
Example of logs from the abnormal core board:
$ journalctl|grep nvdisplay
Apr 26 04:13:25 abcd kernel: [    0.415768] iommu: Adding device 15200000.nvdisplay to group 29
Apr 26 04:13:25 abcd kernel: [    0.416078] iommu: Adding device 15210000.nvdisplay to group 30
Apr 26 04:13:25 abcd kernel: [    0.923450] tegradc 15200000.nvdisplay: disp0 connected to head0->/host1x/sor1
Apr 26 04:13:25 abcd kernel: [    0.923556] tegradc 15200000.nvdisplay: DT parsed successfully
Apr 26 04:13:25 abcd kernel: [    0.923578] tegradc 15200000.nvdisplay: Display dc.ffffff800b3e0000 registered with id=0
Apr 26 04:13:25 abcd kernel: [    0.929427] tegradc 15200000.nvdisplay: vblank syncpt # 8 for dc 0
Apr 26 04:13:25 abcd kernel: [    0.929432] tegradc 15200000.nvdisplay: vpulse3 syncpt # 9 for dc 0
Apr 26 04:13:25 abcd kernel: [    0.931989] tegradc 15200000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
Apr 26 04:13:25 abcd kernel: [    0.931993] tegradc 15200000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
Apr 26 04:13:25 abcd kernel: [    0.935407] tegradc 15200000.nvdisplay: probed
Apr 26 04:13:25 abcd kernel: [    0.935747] tegradc 15200000.nvdisplay: fb registered
Apr 26 04:13:25 abcd kernel: [    0.936530] tegradc 15210000.nvdisplay: disp1 connected to head1->/host1x/sor
Apr 26 04:13:25 abcd kernel: [    0.936663] tegradc 15210000.nvdisplay: DT parsed successfully
Apr 26 04:13:25 abcd kernel: [    0.936694] tegradc 15210000.nvdisplay: Display dc.ffffff800b4a0000 registered with id=1
Apr 26 04:13:25 abcd kernel: [    0.936893] tegradc 15210000.nvdisplay: vblank syncpt # 11 for dc 1
Apr 26 04:13:25 abcd kernel: [    0.936898] tegradc 15210000.nvdisplay: vpulse3 syncpt # 12 for dc 1
Apr 26 04:13:25 abcd kernel: [    0.948120] tegradc 15210000.nvdisplay: probed
Apr 26 04:13:25 abcd kernel: [    0.948289] tegradc 15210000.nvdisplay: fb registered
Apr 26 04:13:25 abcd kernel: [    0.952887] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 2
Apr 26 04:13:25 abcd kernel: [    0.954071] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 1
Apr 26 04:13:25 abcd kernel: [    0.955533] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 0
Apr 26 04:13:25 abcd kernel: [    0.957127] tegradc 15210000.nvdisplay: dp: aux write got error (0x10000100)
Apr 26 04:13:25 abcd kernel: [    0.964207] tegradc 15210000.nvdisplay: dp: Failed for I2C write addr:80, size:1, stat:0x10000100
Apr 26 04:13:25 abcd kernel: [    0.979019] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 2
Apr 26 04:13:25 abcd kernel: [    0.980474] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 1
Apr 26 04:13:25 abcd kernel: [    0.981967] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 0
Apr 26 04:13:25 abcd kernel: [    0.983422] tegradc 15210000.nvdisplay: dp: aux write got error (0x10000100)
Apr 26 04:13:25 abcd kernel: [    0.990496] tegradc 15210000.nvdisplay: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
Apr 26 04:13:25 abcd kernel: [    1.000201] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 2
Apr 26 04:13:25 abcd kernel: [    1.001548] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 1
Apr 26 04:13:25 abcd kernel: [    1.003004] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 0
Apr 26 04:13:25 abcd kernel: [    1.004457] tegradc 15210000.nvdisplay: dp: aux write got error (0x10000100)
Apr 26 04:13:25 abcd kernel: [    1.011525] tegradc 15210000.nvdisplay: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
Apr 26 04:13:25 abcd kernel: [    1.021230] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 2
Apr 26 04:13:25 abcd kernel: [    1.022686] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 1
Apr 26 04:13:25 abcd kernel: [    1.024141] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 0
Apr 26 04:13:25 abcd kernel: [    1.025596] tegradc 15210000.nvdisplay: dp: aux write got error (0x10000100)
Apr 26 04:13:25 abcd kernel: [    1.032662] tegradc 15210000.nvdisplay: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
Apr 26 04:13:25 abcd kernel: [    1.042378] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 2
Apr 26 04:13:25 abcd kernel: [    1.043846] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 1
Apr 26 04:13:25 abcd kernel: [    1.045313] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 0
Apr 26 04:13:25 abcd kernel: [    1.046783] tegradc 15210000.nvdisplay: dp: aux write got error (0x10000100)
Apr 26 04:13:25 abcd kernel: [    1.053838] tegradc 15210000.nvdisplay: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
Apr 26 04:13:25 abcd kernel: [    1.062882] tegradc 15210000.nvdisplay: dp: failed to exit panel power save mode (0xfffffff2)
Apr 26 04:13:25 abcd kernel: [    1.182102] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 2
Apr 26 04:13:25 abcd kernel: [    1.183565] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 1
Apr 26 04:13:25 abcd kernel: [    1.185027] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 0
Apr 26 04:13:25 abcd kernel: [    1.186491] tegradc 15210000.nvdisplay: dp: aux write got error (0x10000100)
Apr 26 04:13:25 abcd kernel: [    1.193546] tegradc 15210000.nvdisplay: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
Apr 26 04:13:25 abcd kernel: [    1.203251] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 2
Apr 26 04:13:25 abcd kernel: [    1.204715] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 1
Apr 26 04:13:25 abcd kernel: [    1.206180] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 0
Apr 26 04:13:25 abcd kernel: [    1.207643] tegradc 15210000.nvdisplay: dp: aux write got error (0x10000100)
Apr 26 04:13:25 abcd kernel: [    1.214694] tegradc 15210000.nvdisplay: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
Apr 26 04:13:25 abcd kernel: [    1.224401] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 2
Apr 26 04:13:25 abcd kernel: [    1.225866] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 1
Apr 26 04:13:25 abcd kernel: [    1.227329] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 0
Apr 26 04:13:25 abcd kernel: [    1.228819] tegradc 15210000.nvdisplay: dp: aux write got error (0x10000100)
Apr 26 04:13:25 abcd kernel: [    1.235883] tegradc 15210000.nvdisplay: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
Apr 26 04:13:25 abcd kernel: [    1.245605] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 2
Apr 26 04:13:25 abcd kernel: [    1.247063] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 1
Apr 26 04:13:25 abcd kernel: [    1.248518] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 0
Apr 26 04:13:25 abcd kernel: [    1.249984] tegradc 15210000.nvdisplay: dp: aux write got error (0x10000100)
Apr 26 04:13:25 abcd kernel: [    1.257047] tegradc 15210000.nvdisplay: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
Apr 26 04:13:25 abcd kernel: [    1.266098] tegradc 15210000.nvdisplay: dp: failed to exit panel power save mode (0xfffffff2)
Apr 26 04:13:25 abcd kernel: [    2.282897] tegradc 15210000.nvdisplay: blank - powerdown
Apr 26 04:13:28 abcd kernel: [    5.339820] tegradc 15200000.nvdisplay: blank - powerdown
Apr 26 04:13:28 abcd kernel: [    5.339828] tegradc 15210000.nvdisplay: blank - powerdown
Example of logs from the normal core board:
Apr 26 03:43:49 abcd kernel: [    0.416483] iommu: Adding device 15200000.nvdisplay to group 29
Apr 26 03:43:49 abcd kernel: [    0.416798] iommu: Adding device 15210000.nvdisplay to group 30
Apr 26 03:43:49 abcd kernel: [    0.861516] tegradc 15200000.nvdisplay: disp0 connected to head0->/host1x/sor1
Apr 26 03:43:49 abcd kernel: [    0.861619] tegradc 15200000.nvdisplay: DT parsed successfully
Apr 26 03:43:49 abcd kernel: [    0.861638] tegradc 15200000.nvdisplay: Display dc.ffffff800b3e0000 registered with id=0
Apr 26 03:43:49 abcd kernel: [    0.867523] tegradc 15200000.nvdisplay: vblank syncpt # 8 for dc 0
Apr 26 03:43:49 abcd kernel: [    0.867528] tegradc 15200000.nvdisplay: vpulse3 syncpt # 9 for dc 0
Apr 26 03:43:49 abcd kernel: [    0.868481] tegradc 15200000.nvdisplay: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350937
Apr 26 03:43:49 abcd kernel: [    0.870446] tegradc 15200000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
Apr 26 03:43:49 abcd kernel: [    0.870451] tegradc 15200000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
Apr 26 03:43:49 abcd kernel: [    0.872569] tegradc 15200000.nvdisplay: probed
Apr 26 03:43:49 abcd kernel: [    0.884195] tegradc 15200000.nvdisplay: fb registered
Apr 26 03:43:49 abcd kernel: [    0.951971] tegradc 15200000.nvdisplay: hdmi: tmds rate:148351K prod-setting:prod_c_hdmi_111m_223m
Apr 26 03:43:49 abcd kernel: [    0.952395] tegradc 15200000.nvdisplay: hdmi: get RGB quant from REG programmed by BL.
Apr 26 03:43:49 abcd kernel: [    0.952405] tegradc 15200000.nvdisplay: hdmi: BL set VIC 0
Apr 26 03:43:49 abcd kernel: [    0.952408] tegradc 15200000.nvdisplay: hdmi: get YCC quant from REG programmed by BL.
Apr 26 03:43:49 abcd kernel: [   11.141796] tegradc 15210000.nvdisplay: disp1 connected to head1->/host1x/sor
Apr 26 03:43:49 abcd kernel: [   11.141879] tegradc 15210000.nvdisplay: DT parsed successfully
Apr 26 03:43:49 abcd kernel: [   11.141898] tegradc 15210000.nvdisplay: Display dc.ffffff800ba90000 registered with id=1
Apr 26 03:43:49 abcd kernel: [   11.142040] tegradc 15210000.nvdisplay: vblank syncpt # 11 for dc 1
Apr 26 03:43:49 abcd kernel: [   11.142044] tegradc 15210000.nvdisplay: vpulse3 syncpt # 12 for dc 1
Apr 26 03:43:49 abcd kernel: [   11.148944] tegradc 15210000.nvdisplay: probed
Apr 26 03:43:49 abcd kernel: [   11.149076] tegradc 15210000.nvdisplay: fb registered
Apr 26 03:43:49 abcd kernel: [   11.152258] tegradc 15210000.nvdisplay: blank - powerdown
Apr 26 03:43:52 abcd kernel: [   14.999985] tegradc 15200000.nvdisplay: unblank
Apr 26 03:43:52 abcd kernel: [   14.999999] tegradc 15210000.nvdisplay: blank - powerdown
ps:
I’m unable to upload the log files in TXT and ZIP format here. If you need them, please provide me with your email address, and I’ll send them to.
What does your “core board” mean here when you already used the other term “module”?
I described it poorly and have now change “module” to “core board”.
Do you have Xavier NX devkit carrier board that can check if it is broken module since you keep mentioning there are working and non-working modules.
了解到这里可以使用中文交流。
我们使用了Xavier NX devkit 载板做验证,异常核心板没有上述问题。
請問你的custom board也是DP+HDMI 2個port的設計嗎
没有使用HDMI和DP口,载板上DP和HDMI都是悬空的。
請問你確定你講的是對的嗎… 你的log跟你說的看起來不太符合…
以上log代表你至少HDMI port有做出來…
仔细确认了原理图,可以确认下面引脚号均为浮空:
引脚号 名称 引脚号 名称
41 DP0_TXD0 65 DP1_TXD0 (HDMI_TXD2)
39 DP0_TXD0 63 DP1_TXD0 (HDMI_TXD2)
47 DP0_TXD1 71 DP1_TXD1 (HDMI_TXD1)
45 DP0_TXD1 69 DP1_TXD1 (HDMI_TXD1)
53 DP0_TXD2 77 DP1_TXD2 (HDMI_TXD0)
51 DP0_TXD2 75 DP1_TXD2 (HDMI_TXD0)
59 DP0_TXD3 83 DP1_TXD3 (HDMI_TXC)
57 DP0_TXD3 81 DP1_TXD3 (HDMI_TXC)
92 DP0_AUX 100 DP1_AUX_P (HDMI_DDC_SCL)
90 DP0_AUX 98 DP1_AUX_N (HDMI_DDC_SDA)
88 DP0_HPD 96 DP1_HPD (HDMI_HPD)
94 HDMI_CEC
ok… 那就請你把沒在使用的nvdisplay跟SOR關掉… 這條就純粹這樣而已
我们想知道,为什么这个TX2 NX核心板和之前的核心板有不一样,因为同样的产品我们已经生产了2年+,在硬件软件都未变更的情况下,最近的买到的核心板频繁出现这样的问题。
你之前的軟體這樣配置就是會有問題 不是說以前沒問題你的軟體就是對的…
沒有在使用的東西就請你關掉
