I had the display port working on my custom board with JetPack 3.2. Now I’m trying to use JetPack 3.2.1 and the display port isn’t working. I’m using display port 0 at nvdisplay@1520000, but in the syslogs, when I plug in or unplug the display port, the status messages are report 15210000. I’m using the stock tegra186-quill-p3310-1000-a00-00-dp-primary.dtb
*UNPLUG*
tegradc 15210000.nvdisplay: dp: unplug event received
Jun 22 12:12:54 custom-board-v1 kernel: [ 721.352467] hpd: state 3 (Disabled), hpd 0, pending_hpd_evt 1
Jun 22 12:12:54 custom-board-v1 kernel: [ 721.358326] hpd: switching from state 3 (Disabled) to state 0 (Reset)
Jun 22 12:12:54 custom-board-v1 kernel: [ 721.402216] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
Jun 22 12:12:54 custom-board-v1 kernel: [ 721.407779] tegradc 15210000.nvdisplay: blank - powerdown
Jun 22 12:12:54 custom-board-v1 kernel: [ 721.413350] hpd: hpd_switch 0
Jun 22 12:12:54 custom-board-v1 kernel: [ 721.416762] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
Jun 22 12:12:54 custom-board-v1 kernel: [ 721.426189] tegradc 15210000.nvdisplay: blank - powerdown
Jun 22 12:12:54 custom-board-v1 kernel: [ 721.431711] tegradc 15210000.nvdisplay: unblank
Jun 22 12:12:54 custom-board-v1 kernel: [ 721.436333] tegradc 15210000.nvdisplay: unblank
Jun 22 12:12:54 custom-board-v1 kernel: [ 721.440930] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
Jun 22 12:12:54 custom-board-v1 kernel: [ 721.440942] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
*PLUG IN*
Jun 22 12:13:08 custom-board-v1 kernel: [ 735.896460] tegradc 15210000.nvdisplay: dp: plug event received
Jun 22 12:13:08 custom-board-v1 kernel: [ 735.902528] hpd: state 3 (Disabled), hpd 1, pending_hpd_evt 1
Jun 22 12:13:08 custom-board-v1 kernel: [ 735.908389] hpd: switching from state 3 (Disabled) to state 0 (Reset)
Jun 22 12:13:08 custom-board-v1 kernel: [ 735.954291] hpd: state 0 (Reset), hpd 1, pending_hpd_evt 0
Jun 22 12:13:08 custom-board-v1 kernel: [ 735.959860] tegradc 15210000.nvdisplay: blank - powerdown
Jun 22 12:13:08 custom-board-v1 kernel: [ 735.965390] hpd: hpd_switch 0
Jun 22 12:13:08 custom-board-v1 kernel: [ 735.968695] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
Jun 22 12:13:08 custom-board-v1 kernel: [ 735.978553] tegradc 15210000.nvdisplay: blank - powerdown
Jun 22 12:13:08 custom-board-v1 kernel: [ 735.984128] tegradc 15210000.nvdisplay: unblank
Jun 22 12:13:08 custom-board-v1 kernel: [ 735.986202] hpd: state 1 (Check Plug), hpd 1, pending_hpd_evt 0
Jun 22 12:13:08 custom-board-v1 kernel: [ 735.986213] hpd: switching from state 1 (Check Plug) to state 2 (Check EDID)
Jun 22 12:13:08 custom-board-v1 kernel: [ 736.001852] tegradc 15210000.nvdisplay: unblank
Jun 22 12:13:08 custom-board-v1 kernel: [ 736.046240] hpd: state 2 (Check EDID), hpd 1, pending_hpd_evt 0
Jun 22 12:13:08 custom-board-v1 kernel: [ 736.053002] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 1
Jun 22 12:13:08 custom-board-v1 kernel: [ 736.074950] tegradc 15210000.nvdisplay: blank - powerdown
Jun 22 12:13:08 custom-board-v1 kernel: [ 736.080765] hpd: Display connected, hpd_switch 1
Jun 22 12:13:08 custom-board-v1 kernel: [ 736.085460] hpd: switching from state 2 (Check EDID) to state 4 (Enabled)
Jun 22 12:13:08 custom-board-v1 kernel: [ 736.105190] tegradc 15210000.nvdisplay: blank - powerdown
Jun 22 12:13:08 custom-board-v1 kernel: [ 736.110944] tegradc 15210000.nvdisplay: unblank
Jun 22 12:13:08 custom-board-v1 kernel: [ 736.110967] PD DISP0 index2 UP
Jun 22 12:13:08 custom-board-v1 kernel: [ 736.112191] PD DISP1 index3 UP
Jun 22 12:13:08 custom-board-v1 kernel: [ 736.112326] PD DISP2 index4 UP
Jun 22 12:13:08 custom-board-v1 kernel: [ 736.114045] regulator_get() failed for (15210000.nvdisplay,vdd-dp-pwr), -19
Jun 22 12:13:08 custom-board-v1 kernel: [ 736.114054] tegradc 15210000.nvdisplay: dp: couldn't get regulator vdd-dp-pwr
Jun 22 12:13:08 custom-board-v1 kernel: [ 736.114069] regulator_get() failed for (15210000.nvdisplay,avdd-dp-pll), -19
Jun 22 12:13:08 custom-board-v1 kernel: [ 736.114075] tegradc 15210000.nvdisplay: dp: couldn't get regulator avdd-dp-pll
Jun 22 12:13:08 custom-board-v1 kernel: [ 736.114089] regulator_get() failed for (15210000.nvdisplay,vdd-edp-sec-mode), -19
Jun 22 12:13:08 custom-board-v1 kernel: [ 736.114096] tegradc 15210000.nvdisplay: dp: couldn't get regulator vdd-edp-sec-mode
Jun 22 12:13:08 custom-board-v1 kernel: [ 736.114109] regulator_get() failed for (15210000.nvdisplay,vdd-dp-pad), -19
Jun 22 12:13:08 custom-board-v1 kernel: [ 736.114115] tegradc 15210000.nvdisplay: dp: couldn't get regulator vdd-dp-pad
Jun 22 12:13:11 custom-board-v1 kernel: [ 736.114917] Parent Clock set for DC plld3
Jun 22 12:13:11 custom-board-v1 kernel: [ 736.128571] dp lt: state 4 (link training fail/disable), hpd 1, pending_lt_evt 1
Jun 22 12:13:11 custom-board-v1 kernel: [ 736.128579] dp lt: switching from state 4 (link training fail/disable) to state 0 (Reset)
Jun 22 12:13:11 custom-board-v1 kernel: [ 736.128593] dp lt: state 0 (Reset), hpd 1, pending_lt_evt 0
Jun 22 12:13:11 custom-board-v1 kernel: [ 736.129760] dp lt: switching from state 0 (Reset) to state 2 (clock recovery)
Jun 22 12:13:11 custom-board-v1 kernel: [ 736.129776] dp lt: state 2 (clock recovery), hpd 1, pending_lt_evt 0
Jun 22 12:13:11 custom-board-v1 kernel: [ 736.129986] dp lt: config: lane 0: vs level: 0, pe level: 0, pc2 level: 0
Jun 22 12:13:11 custom-board-v1 kernel: [ 736.130003] dp lt: config: lane 1: vs level: 0, pe level: 0, pc2 level: 0
Jun 22 12:13:11 custom-board-v1 kernel: [ 736.130019] dp lt: config: lane 2: vs level: 0, pe level: 0, pc2 level: 0
Jun 22 12:13:11 custom-board-v1 kernel: [ 736.130035] dp lt: config: lane 3: vs level: 0, pe level: 0, pc2 level: 0
Jun 22 12:13:11 custom-board-v1 kernel: [ 736.130043] dp lt: tx_pu: 0x22
Jun 22 12:13:11 custom-board-v1 kernel: [ 736.131241] dp lt: CR done
Jun 22 12:13:11 custom-board-v1 kernel: [ 736.131247] dp lt: switching from state 2 (clock recovery) to state 3 (channel equalization)
Jun 22 12:13:11 custom-board-v1 kernel: [ 736.131262] dp lt: state 3 (channel equalization), hpd 1, pending_lt_evt 0
Jun 22 12:13:11 custom-board-v1 kernel: [ 736.132880] dp lt: CE not done
Jun 22 12:13:11 custom-board-v1 kernel: [ 736.133451] dp lt: new config: lane 0: vs level: 1, pe level: 0, pc2 level: 0
Jun 22 12:13:11 custom-board-v1 kernel: [ 736.133455] dp lt: new config: lane 1: vs level: 1, pe level: 0, pc2 level: 0
Jun 22 12:13:11 custom-board-v1 kernel: [ 736.133459] dp lt: new config: lane 2: vs level: 1, pe level: 0, pc2 level: 0
Jun 22 12:13:11 custom-board-v1 kernel: [ 736.133463] dp lt: new config: lane 3: vs level: 1, pe level: 0, pc2 level: 0
Jun 22 12:13:11 custom-board-v1 kernel: [ 736.133480] dp lt: config: lane 0: vs level: 1, pe level: 0, pc2 level: 0
Jun 22 12:13:11 custom-board-v1 kernel: [ 736.133496] dp lt: config: lane 1: vs level: 1, pe level: 0, pc2 level: 0
Jun 22 12:13:11 custom-board-v1 rsyslogd-2007: action 'action 9' suspended, next retry is Fri Jun 22 12:14:11 2018 [v8.16.0 try http://www.rsyslog.com/e/2007 ]
Jun 22 12:13:11 custom-board-v1 kernel: [ 736.133512] dp lt: config: lane 2: vs level: 1, pe level: 0, pc2 level: 0
Jun 22 12:13:11 custom-board-v1 kernel: [ 736.133527] dp lt: config: lane 3: vs level: 1, pe level: 0, pc2 level: 0
Jun 22 12:13:11 custom-board-v1 kernel: [ 736.133534] dp lt: tx_pu: 0x33
Jun 22 12:13:11 custom-board-v1 kernel: [ 736.134145] dp lt: CE retry
Jun 22 12:13:11 custom-board-v1 kernel: [ 736.134151] dp lt: switching from state 3 (channel equalization) to state 3 (channel equalization)
Jun 22 12:13:11 custom-board-v1 kernel: [ 736.134207] dp lt: state 3 (channel equalization), hpd 1, pending_lt_evt 0
I checked the device tree and verified that
:/proc/device-tree/host1x$ cat nvdisplay@15200000/status
okay
ubuntu@akhita-v1
:/proc/device-tree/host1x$ cat nvdisplay@15210000/status
disabled
Any idea what is going on?
