I have a HP ZBook Fury 17 G7 with hybrid graphics (Intel and Nvidia) on Debian 11. I have two external monitors, a Dell 24" 1080 (using a DP to HDMI adapter) and a LG 27" 4K hooked up via a HP Thunderdock. I’m using the nvidia-driver package 460.91.03-1 from the Debian non-free repository.
I would like to have three monitors working: laptop display to my left; 4K monitor in front and above it, the 1080 monitor.
This has worked before, broken, worked again and now broken once again. I took the laptop on vacation and when I came back and hooked everything up, the symptoms came back. Nothing was changed otherwise.
If I enable both the 4K and 1080 monitors, I get the distorted video on the 1080 monitor seen in the image above. If I disable the 4K monitor, the 1080 monitor works. If I disable the 1080 monitor, the 4K monitor works. The laptop display is not affected.
I have tried different DP-to-HDMI adapters. In fact, using two 1080 monitors works fine.
Nothing in /etc/X11/xorg.conf.d/ at the moment, but I have tried several things. It has worked without anything explicitly configured.
$ xrandr
Screen 0: minimum 8 x 8, current 7680 x 2160, maximum 32767 x 32767
eDP1 connected primary 3840x2160+0+0 (normal left inverted right x axis y axis) 340mm x 190mm
3840x2160 60.00*+ 40.00
DP1 disconnected (normal left inverted right x axis y axis)
DP2 disconnected (normal left inverted right x axis y axis)
DP3 disconnected (normal left inverted right x axis y axis)
HDMI1 disconnected (normal left inverted right x axis y axis)
HDMI2 disconnected (normal left inverted right x axis y axis)
HDMI3 disconnected (normal left inverted right x axis y axis)
VIRTUAL1 disconnected (normal left inverted right x axis y axis)
DP-1-0.1 connected 3840x2160+3840+0 (normal left inverted right x axis y axis) 600mm x 340mm
3840x2160 60.00*+ 30.00
2560x1440 59.95
1920x1080 60.00 59.94
[...truncated...]
DP-1-0.2 connected (normal left inverted right x axis y axis)
1920x1080 60.00 + 59.94 50.00
1600x900 60.00
1280x1024 75.02 60.02
[...truncated...]
DP-1-0 disconnected (normal left inverted right x axis y axis)
DP-1-1 disconnected (normal left inverted right x axis y axis)
DP-1-2 disconnected (normal left inverted right x axis y axis)
DP-1-3 disconnected (normal left inverted right x axis y axis)
DP-1-4 disconnected (normal left inverted right x axis y axis)
DP-1-5 disconnected (normal left inverted right x axis y axis)
$ lspci | grep VGA
00:02.0 VGA compatible controller: Intel Corporation CometLake-H GT2 [UHD Graphics] (rev 05)
01:00.0 VGA compatible controller: NVIDIA Corporation TU104GLM [Quadro RTX 5000 Mobile / Max-Q] (rev a1)
$ xrandr --listproviders
Providers: number : 2
Provider 0: id: 0x49 cap: 0xf, Source Output, Sink Output, Source Offload, Sink Offload crtcs: 3 outputs: 7 associated providers: 1 name:modesetting
Provider 1: id: 0x2c6 cap: 0x2, Sink Output crtcs: 4 outputs: 8 associated providers: 1 name:NVIDIA-G0
nvidia-bug-report.log.gz (1.3 MB)
