Isaac Sim Version
4.2.0
Operating System
Ubuntu 22.04
GPU Information
- Model: Quadro RTX 6000
- Driver Version: 650.35.03
- CUDA 12.6
Topic Description
Detailed Description
I’m simulating an RTX LiDAR sensor(Rotary type) in Isaac Sim and publishing its output over ROS2, visualized via RViz. However, the point cloud appears heavily distorted: points seem smeared, lingering across frames, or misplaced relative to the sensor motion (see screenshot). In RViz, the scan clusters resemble curved stripes or persistent tails rather than a clean scan sweep.
Steps to Reproduce
- Create a rotating RTX LiDAR prim (e.g. via
omni.isaac.range_sensor) with your chosen rotation rate.
- Use
IsaacReadRtxLidarPointDataor ROS bridge to publish sensor data asPointCloud2. - Visualize in RViz.
- Rotate or move the LiDAR sensor during simulation.
- Observe distortions persisting across frames or smeared trailing points.
Observations:
