Unwanted Lidar Point Smearing in Isaac Sim 4.5.0
Isaac Sim Version
  • 4.5.0
Operating System
  • Ubuntu 22.04
GPU Information
  • Model: RTX 3090 Ti
  • Driver Version: 570.124.04
Topic Description
Detailed Description
An issue has been observed with the RTX lidar sensor created via the API in Isaac Sim 4.5.0. The point cloud shows extra points that seem to linger from previous frames. These unwanted points sometimes vanish after 5–10 seconds, but other times they remain, creating a smearing effect.
Steps to Reproduce
  1. Run the debug_draw standalone example in Isaac Sim 4.5.0. (standalone_examples/api/isaacsim.util.debug_draw/rtx_lidar.py )
  2. Quickly move or rotate the lidar sensor.
  3. Notice the point cloud displaying lingering points from earlier frames.
Error Messages
No error messages are shown.
Screenshots or Videos
For additional context, similar issues have been discussed in these threads:
Additional Information
What Has Been Tried
  • Compared behavior between Isaac Sim 4.2 and 4.5.0 using the debug_draw example (the issue appears only in 4.5.0).
  • Tested on a fresh installation of Ubuntu 22.04 with Isaac Sim 4.5.0 and the latest GPU driver (570.124.04).
  • Evaluated different lidar configurations with varying horizontal and vertical resolutions, all with the same outcome.
this is a video of the problem. i also tried to publish this points in ROS2 and visualize in RVIZ. same problem. so it is not about the debug_draw extension.
Thanks @mohammad.ehteshami. Our engineers are currently investigating this issue.
I’m also facing this issue. The lidar full scan usage is totally ruined. I’m looking forward to the solution ASAP!
We recently updated the document to include a warning for this
If the lidar rotation rate is slower than the frame rate, the scan buffer will contain returns from multiple frames. If the lidar prim moves between frames, or objects move in the scene, the buffer may contain returns from before the lidar or object(s) moved, causing points to appear as though they are “dragging” behind objects when viewed with the debug draw point cloud writer.
I’m experiencing the same issue. It’s not just a problem with the debug draw point cloud— even the actual point data is affected. The points have incorrect distances, and these “corrupted” points persist even after new measurements are taken. They don’t disappear right away and sometimes stay in the data for a while, which ends up affecting multiple scans and results.
Let me un-resolve this post for now. Our internal team found two issues causing lidar point smearing. One is due to the lidar rotation rate being slower than the frame rate. Our internal team is still trying to root cause and figure out a fix for the other issue.
I met the same issue, and I think it’s just a simple bug that the point buffer is not truncated properly by the real-time point length. It explained the reason that persistent points remain at a fixed region - the tail of the buffer (as lidar scan rotates clockwise, the tail possibly is a fixed region).
I also noticed it is a new bug in 4.5, as 4.2 works well.
But luckily I don’t need the full range of lidar points, so I avoid this issue by rotating the buffer tail to the insignificant region.
I am also experiencing the same issue. Has there been any progress or updates on this? Seems like this has been a persistent issue for several months.
As an aside, I have also written a node that subscribes to the partial point cloud messages and merges them as seen here: RTX Lidar drag points issue in debug view and full scan point cloud publishing - #7 by heiscsy.
However, this is a band aid solution that doesn’t address downstream services (e.g., using a point cloud as an observation in an Isaac Lab RL environment).
I’ve been away from this project for a while, but I recall fixing the issue (probably not the most optimized solution, but it works). I’m sharing the piece of code that might help others experiencing the same problem. This worked with Isaac Sim 4.5.0, at least for me.
LiDAR Setup
import numpy as np
from isaacsim.sensors.rtx import LidarRtx
import rclpy
from rclpy.node import Node
my_world = World(stage_units_in_meters=1.0, physics_dt=1 / 500, rendering_dt=1 / 50)
pts_per_rev = 512
rot_hz = 50
fire_hz = pts_per_rev * rot_hz
lidar = world.scene.add(
    LidarRtx(
        prim_path="/World/Robot/lidar",
        name="rotary_lidar",
        translation=np.array([0, 0, 0]),
        orientation=np.array([1, 0, 0, 0]),
        firing_frequency=fire_hz,
        firing_dt=1.0 / fire_hz,
        rotation_frequency=rot_hz,
        rotation_dt=1.0 / rot_hz,
        valid_range=(1, 120.0),
        scan_type="rotary",
        elevation_range=(-1.5, 1.5),
lidar.add_point_cloud_data_to_frame()
my_lidar.add_range_data_to_frame()
ROS 2 Publisher
rclpy.init()
node = rclpy.create_node("lidar_pub")
pc_pub = node.create_publisher(PointCloud2, "cloud_topic", 10)
while sim_app.is_running():
    world.step(render=True)
    frame = lidar.get_current_frame()  # dict containing "point_cloud_data"
    pts = frame["point_cloud_data"].astype(np.float32)
    # Minimal PointCloud2 message (you can add other fields if needed)
    header = Header()
    header.stamp = node.get_clock().now().to_msg()
    header.frame_id = "sim_lidar"
    fields = [
        PointField("x", 0, PointField.FLOAT32, 1),
        PointField("y", 4, PointField.FLOAT32, 1),
        PointField("z", 8, PointField.FLOAT32, 1),
    cloud = pc2.create_cloud(header, fields, pts)
    pc_pub.publish(cloud)
    rclpy.spin_once(node, timeout_sec=0.0)
You can add other fields like intensity to the point cloud using methods like add_intensities_data_to_frame if needed.
I’m not certain this is the most optimized method to manually read and publish the LiDAR point cloud. However, since I had additional processing requirements before publishing, this approach worked well for my specific use case.
I’m not sure I can help you further than that. i have been long away from this project and I cannot remember the specifics. just saw others had the same problem and taught my code might help.
Which part of this code is the fix? Is it these parameters: firing_frequency=fire_hz,
or the use of add_point_cloud_data_to_frame()?
Not really sure. I don’t think that it is because of the exact parameters, rather because of different API. Surely there should be some configuration with the new API that works, but in my case, as I remember, when i changed the code and used the older API, the code worked with the first configuration that i tried.
This issue should be resolved in Isaac Sim 5.0. Please stay tuned for the new release.
Here is a test done by the internal team with Isaac Sim 5.0. The lidar smearing issue is gone.
