LiDAR smearing and persistant points in IsaacSim 4.5
Isaac Sim Version
4.5.0
4.2.0
4.1.0
4.0.0
4.5.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Operating System
Ubuntu 22.04
Ubuntu 20.04
Windows 11
Windows 10
GPU Information
  • Model: A5000 ADA
  • Driver Version: 535.183.01
LiDAR smearing and persistent points in IsaacSim 4.5
We are publishing LiDAR points (Hesai XT32) using the LiDAR helper action graph. We have found that when we drop the robot into the scene, there are streaks in the LiDAR points and that anything scanned before hitting the ground remains persistent. This issue does not occur in IsaacSim 4.2.
Here are the streaks.
This is the LiDAR action graph.
Thanks for bringing this issue up! I have passed it down to our internal team.
Did you enable “publish full scan” in ROS2 RTX Lidar Helper?
I see similar issue when simulation Ouster-0 sensor in Isaac Sim 4.5. Video attached below explain this clearly. Please advice on how to mitigate this.
OS: Ubuntu 20.04
GPU: Nvidia A3000 RTX
yes, publish full scan is enabled
@gartsw thanks. Yes this is a known issue. We are currently investigating this.
We recently updated the document to include a warning for this
If the lidar rotation rate is slower than the frame rate, the scan buffer will contain returns from multiple frames. If the lidar prim moves between frames, or objects move in the scene, the buffer may contain returns from before the lidar or object(s) moved, causing points to appear as though they are “dragging” behind objects when viewed with the debug draw point cloud writer.
In my case, the points are not just dragging, they never disappear. It appears that all points scanned before the robot touches the ground are persistent.
Sorry. It might be a different issue. Let me reach out to the internal team
I’m facing the same issue as described above. Looking forward to a fix or any possible workaround.
Thanks in advance to anyone who can help!
Here is a test done by the internal team with Isaac Sim 5.0. The lidar smearing issue is gone.
@zhengwang , is it possible to share this .usd file?
I don’t get the RTXLidar working in isaac sim 5 and it would be nice to see an example that works
Hi @benjamin.yde! Here is the usd file. You will have to manually add Nova Carter ROS in the scene as it is too big and it won’t be able to upload to the forum. After adding Nova Carter ROS, please enable ROS2 RTX Lidar Helper Node and enable show debug view.
isim_3148_carter_lidar_smearing.zip (2.0 MB)
