Hi All,
I think, I received (again) a DOA (Dead on Arrival) Jetson Nano 2GB - Developer kit.
jetson nano 2 gb developer kit with wireless usb adapter
model : P3531
When plugging in :
5.1v 3.0a official raspberry pi power usb-c connector, the green light turns on, but no signal (test1) on hdmi connected dell monitor1, (test2) on another hdmi connceted dell monitor2, (test3) hdmi connected samsung TV.
Tried with a apple 5v 2.1a power socket, (different usb-c cable on above monitors… (test4, test5, test6) again no output.
Then tried both power adapters, with no hdmi connected.
to see if my usb optical mouse, would give signal. Tested on all usb ports, no optical light. Did the same for my DELL keyboard, to see if capslock/numlock light would give any signal. No lights there…
(Not sure, but is checking lights on usb mouse/keyboard a good test?)
Also will the Jetson Nano maybe make a “beep” after bios check?
Important, this is the SECOND jetson nano 2 GB - developer kit I have received, the FIRST one, had exact same issues and was send back, for which I have received this one.
So am the I only one? or do I need to adjust a jumper? I’m missing something?
Otherwise, I need to send it back as DOA again. :( but find it very strange that I received a double DOA.
ps : The above mentioned poweradapters are working fine with other periphals.
ps : no SD card was attached.
other questions, with the earlier send DOA jetson nano 2 GB, will nvidia do any research, what the cause was of the DOA? and if it was a real DOA? I’m just curious.
