jwson3
July 20, 2022, 8:00am
1
I am using Isaac sim with AWS.
First, I run the Isaac Sim container with an interactive Bash session (Terminal 1 on AWS):
$ sudo docker run --name isaac-sim --entrypoint bash -it --gpus all -e “ACCEPT_EULA=Y” --rm --network=host
-v ~/docker/isaac-sim/cache/kit/nv_shadercache:/isaac-sim/kit/cache/Kit/103.1/6e2a27c0/nv_shadercache:rw
-v ~/docker/isaac-sim/cache/ov:/root/.cache/ov:rw
-v ~/docker/isaac-sim/cache/pip:/root/.cache/pip:rw
-v ~/docker/isaac-sim/cache/glcache:/root/.cache/nvidia/GLCache:rw
-v ~/docker/isaac-sim/cache/computecache:/root/.nv/ComputeCache:rw
-v ~/docker/isaac-sim/logs:/root/.nvidia-omniverse/logs:rw
-v ~/docker/isaac-sim/config:/root/.nvidia-omniverse/config:rw
-v ~/docker/isaac-sim/data:/root/.local/share/ov/data:rw
-v ~/docker/isaac-sim/documents:/root/Documents:rw
nvcr.io/nvidia/isaac-sim:2022.1.0
Then I start Isaac Sim with native livestream mode (Terminal 1 on AWS):
$ ./runheadless.native.sh
I Launch the Omniverse Streaming Client (Local)
Then I open another terminal for the running docker container (Terminal 2 on AWS) :
$ sudo docker exec -it isaac-sim /bin/bash
But when I start python script in the docker (Terminal 2 on AWS)
./python.sh test.py
But it failed to run.
Is is possible to run python environment (not script editor) with docker container?
Hi. Does the python script works if you do not run ./runheadless.native.sh first or you run the python script on a second container?
jwson3
July 23, 2022, 8:29am
4
After several attempts, it was possible to run a python script. But I have a question, I am following the Creating New RL Envrionment of ISAAC GYM TUTORIALS. After rl training of cartpole, when performing inference, headless=False should be set for visualization. In this case, how can I visualize carpole policy running? I tried to connect to docker container of aws with omniverse streaming client, But i failed to connect.
To view the Isaac Sim UI when using a container, set headless=True and enable_extension("omni.kit.livestream.native"). Take a look at livestream.py as an example.
jwson3
July 23, 2022, 4:28pm
7
Thanks so much. I will try it now.
jwson3
July 24, 2022, 1:28am
8
Finally, I can run python script and visualize simulation. Thanks so much.
jwson3
July 25, 2022, 2:49pm
9
I have one more question. I try to use RL extension on docker container. Tutorial code is as below.
# create isaac environment
from omni.isaac.gym.vec_env import VecEnvBase
env = VecEnvBase(headless=False)
# create task and register task
from cartpole_task import CartpoleTask
task = CartpoleTask(name="Cartpole")
env.set_task(task, backend="torch")
# import stable baselines
from stable_baselines3 import PPO
# Run inference on the trained policy
model = PPO.load("ppo_cartpole")
env._world.reset()
obs = env.reset()
while env._simulation_app.is_running():
action, _states = model.predict(obs)
obs, rewards, dones, info = env.step(action)
env.close()
In this case, How can i enable livestreaming for remotely accessing?
For livestreaming, SimulationApp should be used. So I tried to add SimulationApp, but it failed.
Sorry for bothering you. I tried to read RL extension API but detailed explanation is missing.
Hi.
Try running it headless:
env = VecEnvBase(headless=True)
Then also enable the livestream server:
from omni.isaac.core.utils.extensions import enable_extension
enable_extension(“omni.kit.livestream.native”)
jwson3
July 25, 2022, 4:22pm
12
I tried it. But it is not working perfectly.
Omniverse Streaming Client is connected. But object is not loaded and “start” button is not pushed.
terminal display is as below.
But when I input ctrl-c on terminal, the objects are shown on display. But it does not work anymore because it shutdown.
Is there any solution?
Hi. Did you get the issue resolved yet?
Please send us the latest copy of your .py file for us to reproduce.
jwson3
August 2, 2022, 2:27am
14
Hi, I didn’t solve it.
The same problem arises.
How can I get your email?
My code is as below
env._world.reset()
obs = env.reset()
env.close()
Thanks. Is this the edited cartpole_task.py from the RL example ?
I’ll try this and file a bug.
jwson3
August 2, 2022, 2:15pm
16
Always thank you for your hard work.
I think I found what’s missing. The update() call:
env._simulation_app.update()
env.close()
jwson3
August 3, 2022, 1:10am
18
It works for me now. Thanks so much
system
Closed
August 17, 2022, 1:10am
19
