Drive AGX ambient temperature
we just checked the Drive AGX installation guide and hardware specs and had some questions regarding operating environment requirements, more specifically the ambient temperature range mentioned there. What are expected failures / most sensitive components that are expected to malfunction if the temperature falls below the given temperature range? Can you share any experiences operating the Drive AGX system outside this temperature range?
Thanks in advance for your help,
Sebastian
Dear Sebastian,
Our team is checking on this internally and get back to you.
Dear Siva,
do you have any updates on this?
Thanks,
Sebastian
Hi Sebastian,
Unfortunately I don’t have any details on specific components would be expected to fail first given out of spec temperature ranges. Exceeding temp is a reliability issue, you could expect random failures based on the amount of time the system is run out of spec.
