Hello, I am having an issue with an NVIDIA DRIVE AGX Orin.
The system does not boot normally. I do not get display output and SSH is not reachable. However, I can access NvShell / AURIX through the debug port using PuTTY.
From NvShell, the AURIX version shown is:
DRIVE-V6.0.6-P3710-AFW-Aurix-StepB-5.07.06
What I observed:
AURIX/NvShell is accessible
I do not see normal Tegra UEFI/Linux boot logs
no display output
What I tried:
power cycle
minimum setup with only required peripherals
display/monitor checks
SSH test
serial debug connection through PuTTY
tegrareset x1 -
tegrarecovery x1 onfollowed bytegrareset x1
Results:
tegrareset x1did not bring the system to normal boot -
recovery commands were accepted, but I could not confirm that Tegra actually entered recovery mode on the host side
I did not observe an additional USB device clearly indicating Tegra recovery
after the recovery attempt, the same error pattern continued
Main log messages/errors:
SAFE_3V3 OutOfRange -
VRS11 PGOOD Failure -
OrinVMON -
E2E Frame Error -
No valid next bootchain loaded -
Fan 2 RPM : 0 -
maxrpm of fan2 has more than 50 percent deviation against rated maxrpm -
moving to error state
show_fanrpm output:
Fan 1 RPM : 5000 -
Fan 2 RPM : 0
At this point, this looks more like a power / safety / fan / board-level issue than a display-only issue.
My questions:
Does this error pattern point to a known hardware issue?
Is there anything else safe to check from NvShell/AURIX?
Could the inability to clearly enter recovery indicate a deeper board-level problem?
Can
Fan 2 RPM : 0prevent Tegra from booting normally on DRIVE AGX Orin? -
Would you recommend checking fan/header/power-related hardware first?
I can share the full serial log if needed.
Best regards,
Deniz
