Software Version
DRIVE OS 6.0.10.0
DRIVE OS 6.0.8.1
[O] DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
[O] Linux
QNX
other
Hardware Platform
[O] DRIVE AGX Orin Developer Kit (not sure its number)
other
SDK Manager Version
2.1.0
[O] other → 2.2.0
Host Machine Version
[O] native Ubuntu Linux 20.04 Host installed with DRIVE OS Docker Containers
other
Issue Description
Hello, I’m trying to flash and setup DRIVE AGX Orin DevKit.
It seems that there are 2 ways to do it. and I’m trying to do both ways, but I have questions regarding this process
- Docker Container
I followed the instruction to pull below command.
sudo docker run -it --privileged --net=host -v /dev/bus/usb:/dev/bus/usb -v ${WORKSPACE}:/home/nvidia/
nvcr.io/drive/driveos-sdk/drive-agx-orin-linux-aarch64-sdk-build-x86:latest
But i got the following messages from the terminal.
Is there any mistyping for the command?
or should I enter specific argument into ${WORKSPACE}?
- SDK Manager
I tried to do it with SDK Manager 2.2.0.
and when the process turned into flahs, below error messages appeared.
14:12:44 INFO: Flash DRIVE OS - flash: else
14:12:44 INFO: Flash DRIVE OS - flash: fi
14:12:44 INFO: Flash DRIVE OS - flash: export NV_WORKSPACE=/home/dspace/nvidia/nvidia_sdk/DRIVE_OS_6.0.6_SDK_Linux_DRIVE_AGX_ORIN_DEVKITS/DRIVEOS/
14:12:44 INFO: Flash DRIVE OS - flash: exec_command: /home/dspace/.nvsdkm/replays/scripts/DRIVE_OS_6.0.6_SDK_Linux/NV_DRIVE_FLASH_DRIVE_COMP.sh
14:12:47 INFO: Flash DRIVE OS - flash: Waiting for cache lock: Could not get lock /var/lib/dpkg/lock-frontend. It is held by process 115328 (apt-get)…
14:12:48 INFO: Flash DRIVE OS - flash: Waiting for cache lock: Could not get lock /var/lib/dpkg/lock-frontend. It is held by process 115328 (apt-get)…
14:12:49 INFO: Flash DRIVE OS - flash: Waiting for cache lock: Could not get lock /var/lib/dpkg/lock-frontend. It is held by process 115328 (apt-get)…
14:12:50 INFO: Flash DRIVE OS - flash: Waiting for cache lock: Could not get lock /var/lib/dpkg/lock-frontend. It is held by process 115328 (apt-get)…
14:12:51 INFO: Flash DRIVE OS - flash: Waiting for cache lock: Could not get lock /var/lib/dpkg/lock-frontend. It is held by process 115328 (apt-get)…
14:12:55 INFO: Flash DRIVE OS - flash: Waiting for cache lock: Could not get lock /var/lib/dpkg/lock-frontend. It is held by process 115328 (apt-get)…
14:13:01 INFO: Flash DRIVE OS - flash: Waiting for cache lock: Could not get lock /var/lib/dpkg/lock-frontend. It is held by process 115328 (apt-get)…
14:13:02 INFO: Flash DRIVE OS - flash: Waiting for cache lock: Could not get lock /var/lib/dpkg/lock-frontend. It is held by process 115328 (apt-get)…
14:13:03 INFO: Flash DRIVE OS - flash: Waiting for cache lock: Could not get lock /var/lib/dpkg/lock-frontend. It is held by process 115328 (apt-get)…
14:13:05 INFO: Flash DRIVE OS - flash: Waiting for cache lock: Could not get lock /var/lib/dpkg/lock-frontend. It is held by process 115328 (apt-get)…
14:13:06 INFO: Flash DRIVE OS - flash: Waiting for cache lock: Could not get lock /var/lib/dpkg/lock-frontend. It is held by process 115328 (apt-get)…
14:13:07 INFO: Flash DRIVE OS - flash: Waiting for cache lock: Could not get lock /var/lib/dpkg/lock-frontend. It is held by process 115328 (apt-get)…
14:13:10 INFO: Flash DRIVE OS - flash: Waiting for cache lock: Could not get lock /var/lib/dpkg/lock-frontend. It is held by process 115328 (apt-get)…
14:13:11 INFO: Flash DRIVE OS - flash: Waiting for cache lock: Could not get lock /var/lib/dpkg/lock-frontend. It is held by process 115328 (apt-get)…
14:13:12 INFO: Flash DRIVE OS - flash: Waiting for cache lock: Could not get lock /var/lib/dpkg/lock-frontend. It is held by process 115328 (apt-get)…
14:13:13 INFO: Flash DRIVE OS - flash: Waiting for cache lock: Could not get lock /var/lib/dpkg/lock-frontend. It is held by process 115328 (apt-get)…
14:13:16 INFO: Flash DRIVE OS - flash: Waiting for cache lock: Could not get lock /var/lib/dpkg/lock-frontend. It is held by process 115328 (apt-get)…
14:13:38 INFO: Flash DRIVE OS - flash: (Reading database … 100%
14:13:38 INFO: Flash DRIVE OS - flash: (Reading database … 222495 files and directories currently installed.)
14:13:38 INFO: Flash DRIVE OS - flash: Preparing to unpack …/python-is-python3_3.8.2-4_all.deb …
14:13:38 INFO: Flash DRIVE OS - flash: Setting up python-is-python3 (3.8.2-4) …
14:13:39 INFO: Flash DRIVE OS - flash: Adding user dspace' to group dialout’ …
14:13:39 INFO: Flash DRIVE OS - flash: Done.
14:13:39 INFO: Flash DRIVE OS - flash: # mount targetfs img to update the EULA metadata and unmount on exit
14:13:39 INFO: Flash DRIVE OS - flash: sudo mount -t ext4 ${NV_WORKSPACE}/drive-linux/filesystem/targetfs.img ${NV_WORKSPACE}/drive-linux/filesystem/targetfs
14:28:56 INFO: Flash DRIVE OS - flash: exec_command [host]:
14:28:56 INFO: Flash DRIVE OS - flash: sudo rm -f /var/lock/LCK..ttyACM* /var/lock/LCK..bootburn_seq /var/lock/LCK..bootburn
14:28:56 INFO: Flash DRIVE OS - flash: current working directory is /home/dspace/nvidia/nvidia_sdk/DRIVE_OS_6.0.6_SDK_Linux_DRIVE_AGX_ORIN_DEVKITS/DRIVEOS
14:28:56 INFO: Flash DRIVE OS - flash: **********************
14:28:56 INFO: Flash DRIVE OS - flash: safe_apt_install "sudo apt install -y python-is-python3 " 5
14:28:56 INFO: Flash DRIVE OS - flash: sudo adduser whoami | xargs echo -n dialout
14:28:56 INFO: Flash DRIVE OS - flash: sudo chmod a+rw /dev/ttyACM*
14:28:56 INFO: Flash DRIVE OS - flash: if [[ ‘’ == wipe-persistent-partition ]]; then
14:28:56 INFO: Flash DRIVE OS - flash: sed -i ‘s/“opt-args”:.*/“opt-args”: [“–init_persistent_partitions”, “-D” ],/’ ./driveinstaller/manifests/install_pdk_config/av_orin_p3710_driveos_linux_tegraA_install_config.json
14:28:56 INFO: Flash DRIVE OS - flash: else
14:28:56 INFO: Flash DRIVE OS - flash: sed -i ‘s/“opt-args”:.*/“opt-args”: [“-D”],/’ ./driveinstaller/manifests/install_pdk_config/av_orin_p3710_driveos_linux_tegraA_install_config.json
14:28:56 INFO: Flash DRIVE OS - flash: fi
14:28:56 INFO: Flash DRIVE OS - flash: if ! grep mount ./driveinstaller/scripts/linux_pre_flash.sh; then
14:28:56 INFO: Flash DRIVE OS - flash: sed -i ‘64 i sudo mount -t ext4 ${NV_WORKSPACE}/drive-linux/filesystem/targetfs.img ${NV_WORKSPACE}/drive-linux/filesystem/targetfs’ ./driveinstaller/scripts/linux_pre_flash.sh
14:28:56 INFO: Flash DRIVE OS - flash: export NV_WORKSPACE=/home/dspace/nvidia/nvidia_sdk/DRIVE_OS_6.0.6_SDK_Linux_DRIVE_AGX_ORIN_DEVKITS/DRIVEOS/
14:28:56 INFO: Flash DRIVE OS - flash: cd driveinstaller && ./driveinstaller --installtype bindflash --boardtype ES --pdkinstalledpath /home/dspace/nvidia/nvidia_sdk/DRIVE_OS_6.0.6_SDK_Linux_DRIVE_AGX_ORIN_DEVKITS/DRIVEOS --configjson ./manifests/install_pdk_config/av_orin_p3710_driveos_linux_tegraA_install_config.json --targetuser nvidia --port ${AURIX_PORT:-/dev/ttyACM1} --eula-accepted 1 --consoleout enable --logpath ~/.nvsdkm/
14:28:56 INFO: Flash DRIVE OS - flash: exec_command: /home/dspace/.nvsdkm/replays/scripts/DRIVE_OS_6.0.6_SDK_Linux/NV_DRIVE_FLASH_DRIVE_COMP.sh
14:28:56 INFO: Flash DRIVE OS - flash: *begin sudo apt install -y python-is-python3 , 5
14:28:56 INFO: Flash DRIVE OS - flash: Reading package lists…
14:28:56 INFO: Flash DRIVE OS - flash: Building dependency tree…
14:28:56 INFO: Flash DRIVE OS - flash: Reading state information…
14:28:56 INFO: Flash DRIVE OS - flash: python-is-python3 is already the newest version (3.8.2-4).
14:28:57 INFO: Flash DRIVE OS - flash: 0 upgraded, 0 newly installed, 0 to remove and 105 not upgraded.
14:28:57 INFO: Flash DRIVE OS - flash: The user dspace' is already a member of dialout’.
14:28:57 INFO: Flash DRIVE OS - flash: # mount targetfs img to update the EULA metadata and unmount on exit
14:28:57 INFO: Flash DRIVE OS - flash: sudo mount -t ext4 ${NV_WORKSPACE}/drive-linux/filesystem/targetfs.img ${NV_WORKSPACE}/drive-linux/filesystem/targetfs
14:28:57 INFO: Flash DRIVE OS - flash: trap “sudo umount -l ${NV_WORKSPACE}/drive-linux/filesystem/targetfs.img” EXIT
14:28:57 INFO: Flash DRIVE OS - flash: # Must lazy umount after operations on rootfs image before running new Build-FS instance.
14:28:57 INFO: Flash DRIVE OS - flash: # Check for errors in umount as it is a pre-req for next step.
14:28:57 INFO: Flash DRIVE OS - flash: # Clear trap if umount is good.
14:28:57 INFO: Flash DRIVE OS - flash: sudo umount -l ${NV_WORKSPACE}/drive-linux/filesystem/targetfs.img
14:28:57 INFO: Flash DRIVE OS - flash: host sudo password for dspace:
14:28:57 INFO: Flash DRIVE OS - flash: This script must be run with root privileges!
14:28:57 INFO: Flash DRIVE OS - flash: driveinstaller v2.0
14:28:57 INFO: Flash DRIVE OS - flash: SDK/PDK Installer and Flasher
14:28:57 INFO: Flash DRIVE OS - flash: Run ./driveinstaller --help for usage information.
14:28:57 INFO: Flash DRIVE OS - flash: Initializing board and OS configuration to Autonomous vehicle p3710 Linux Tegra A
14:28:57 INFO: Flash DRIVE OS - flash: Manifest version 2.0
14:28:57 INFO: Flash DRIVE OS - flash: [target] target sudo password for nvidia:
14:29:09 INFO: Flash DRIVE OS - flash: BOARD SKU : 940-63710-0010-300
14:29:09 INFO: Flash DRIVE OS - flash: Found matching board id p3710-10-s05 in 940-63710-0010-300 sku
14:29:09 INFO: Flash DRIVE OS - flash: Applying additional Bind opts
14:29:13 INFO: Flash DRIVE OS - flash: Binding of partitions failed ! Check log for more details.
14:29:13 INFO: Flash DRIVE OS - flash: Failed to bind partitions!
14:29:13 INFO: Flash DRIVE OS - flash: driveinstaller cannot continue! Check the log file for details: /home/dspace/.nvsdkm/driveinstaller.log
14:29:13 ERROR: Flash DRIVE OS - flash: [exec_command]: /bin/bash -c /home/dspace/.nvsdkm/replays/scripts/DRIVE_OS_6.0.6_SDK_Linux/NV_DRIVE_FLASH_DRIVE_COMP.sh; [error]:
14:29:13 INFO: Flash DRIVE OS - flash: [ Component Install Finished with Error ]
14:29:13 INFO: Flash DRIVE OS - flash: [host] [ 7.59 MB released. Disk Avail on Partition /dev/nvme0n1p2: 337.52 GB ]
14:29:13 INFO: Flash DRIVE OS - flash: [ NV_DRIVE_FLASH_DRIVE_COMP Install took 17s ]
14:29:13 ERROR: Flash DRIVE OS - flash: command terminated with error
14:07:46 INFO: Vulkan Packages - target_image: [CP] ‘/home/dspace/nvidia/nvidia_sdk/DRIVE_OS_6.0.6_SDK_Linux_DRIVE_AGX_ORIN_DEVKITS/DRIVEOS//drive-linux/samples/vulkan-sc-samples/binaries/Linux_aarch64/data/shaders/vksc_01tri/vk_01tri_pipeline_0.frag.spv’ to ‘/tmp/tmp_u4hpbz9//targetfs//opt/nvidia/drive-linux/samples/vulkansc/data/shaders/vksc_01tri/vk_01tri_pipeline_0.frag.spv’
14:07:46 INFO: Vulkan Packages - target_image: [33, /opt/nvidia/drive-linux/samples/vulkansc/data/shaders/vksc_01tri/vk_01tri_pipeline_0.vert]
14:07:46 INFO: Vulkan Packages - target_image: [CP] ‘/home/dspace/nvidia/nvidia_sdk/DRIVE_OS_6.0.6_SDK_Linux_DRIVE_AGX_ORIN_DEVKITS/DRIVEOS//drive-linux/samples/vulkan-sc-samples/binaries/Linux_aarch64/data/shaders/vksc_01tri/vk_01tri_pipeline_0.vert’ to ‘/tmp/tmp_u4hpbz9//targetfs//opt/nvidia/drive-linux/samples/vulkansc/data/shaders/vksc_01tri/vk_01tri_pipeline_0.vert’
14:07:46 INFO: Vulkan Packages - target_image: [34, /opt/nvidia/drive-linux/samples/vulkansc/data/shaders/vksc_01tri/vk_01tri_pipeline_0.vert.spv]
Could you also check this issue?
Kind Regards.
