DRIVE Kit display port not responsive, possible electrical issues
Software Version
DRIVE OS 6.0.10.0
[*] DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
[*] Linux
QNX
other
Hardware Platform
[*] DRIVE AGX Orin Developer Kit (not sure its number)
other
SDK Manager Version
2.1.0
other
Host Machine Version
[*] native Ubuntu Linux 20.04 Host installed with SDK Manager
other
Issue Description
The DRIVE KIT on a reset after a power shutdown, ceases to connect to all possible monitors with the Display port (measured for response on a multi-meter) comes back as unresponsive. If this is a software issue, how do I upgrade/work around this issue and if it is a hardware issue, how do I resolve this?
Is it possible to contact/send the device to an NVIDIA DRIVE expert?
Is it possible to find the ip address of the device somehow? (the ethernet leds are blinking)
Is it possible to re-flash/upgrade the OS?
Is there a way to factory reset/force recover the device to get the display port up and running?
I have looked into other topics of connecting different monitors.
Is the display monitor working earlier and notice issue recently? Just want to confirm if EULA is ever is accepted on board in booting after flashing. Please see Finalize DRIVE AGX Orin System Setup | NVIDIA Docs if you missed to follow “Finalize DRIVE AGX Orin System Setup”
Is it possible to flash latest release(DRIVE OS 6.0.10.0) if you don’t have any dependency on DRIVE OS 6.0.8.1.
Please see Install DRIVE OS Linux Docker Containers from NGC | NVIDIA Docs for details to flash using docker container. Please use below docker images based on need
DRIVE OS 6.0.8.1 docker image : nvcr.io/drive/driveos-sdk/drive-agx-orin-linux-aarch64-sdk-build-x86:6.0.8.1-0006
DRIVE OS 6.0.10.0 docker image : nvcr.io/drive/driveos-sdk/drive-agx-orin-linux-aarch64-sdk-build-x86:latest
You can connect using minicom withsudo minicom -D /dev/ttyACM0 to tegra console. Make sure host and device connections are set as given in page 12 of Quick start guide
We notice display issue with few monitors. Please see DRIVE AGX no display output issue and The monitor can't receive any dp singnal, what should I do to get the GUI? Now I can only use the CLI through SSH if it helps
