Issue Description: Terminal message shows flashed is successful but I did not see Drive OS updated to the specific version. Cuda libraries are not installed.
Dear @muhammadmobaidul.islam ,
From sdkmanager UI, I can see flashing is successful. It has flashed DRIVE OS 6.0.6
Did you check DRIVE OS version on target ?
What do you see under /usr/local/cuda?
May I know, do you have any specific requirement to use DRIVE OS 6.0.6. if not, you can check flash latest release DRIVE OS 6.0.10 using docker.
Noticed below message in docker flashing logs
self.HostSpaceCheck()\r\n File "/drive/drive-foundation/tools/flashtools/bootburn/../bootburn_t23x_py/bootburn_lib.py", line 447, in HostSpaceCheck\r\n AbnormalTermination("s_ERROR_INSUFFICIENT
