I have been trying to upgrade my driver from nvidia-346 to nvidia-384, but the second fails to launch X server.
Computer : Laptop MSI GE60 2PE Apache Pro
CPU : Intel I5-4200H
GPU : GeForce GTX 860M
System : Linux Mint 17.2 64bits
Linux core : 3.16.0-38-generic
Prime is supported, using nvidia-settings to force nvidia gpu use.
Driver 384.69 should be supported by my GPU, according to Official Drivers | NVIDIA
Here is how I change from 346 driver to 384 driver :
First going to virtual terminal (ctrl+alt+f1)
Then
sudo service mdm stop
sudo apt-get install nvidia-384 ((or nvidia-346 to restore to a working configuration))
sudo service mdm start
After installing nvidia-346 : the X server launch correctly, here is the /var/log/Xorg.0.log file after “mdm start” :
After installing nvidia-384 : the X server fails to launch, here is the /var/log/Xorg.0.log file after “mdm start” :
Driver384 - Xorg.0.log - Pastebin.com → Everything is similar to the first log until line 134
And here is the result of nvidia-bug-report.sh while driver 384 is installed :
Why doesn’t the 384.69 driver works correctly ?
I also tried manual installation of the driver downloaded from here (Linux x64 (AMD64/EM64T) Display Driver | 384.69 | Linux 64-bit | NVIDIA), but it also did not work.
Driver 361 worked on my computer, but it is not anymore there on linux mint repositories.
All driver > 361 did not work as well.
Installing recommended package libcuda1-384 and nvidia-opencl-icd-384 doesn’t help.
Edit : pastebin links also placed as attechement
Driver346_Xorg.0.log (32.3 KB)
Driver384_Xorg.0.log (13.7 KB)
nvidia-bug-report.log (231 KB)
