Yes, the crash also occurs with the vesa driver. I used a xorg.conf which basically just has
Section "Device"
Identifier "Configured Video Device"
Driver "vesa"
EndSection
This way I can run mathematica and even make simple calculations. Unfortunately, the output of the vesa driver is broken on this chip (see attached picture), otherwise I would just be using the vesa driver on these systems (performance is not really an issue here).
Also, only these systems crash when starting mathematica. We have ~150 systems with other graphics adapters, lots of NVIDIAs, some others, and these are the only ones that give us these problems.
Terminal output of the vesa driver:
root@cip1pavilion4:~# X :1 -config /etc/X11/xorg-vesa.conf
X.Org X Server 1.11.3
Release Date: 2011-12-16
X Protocol Version 11, Revision 0
Build Operating System: Linux 2.6.42-37-generic x86_64 Ubuntu
Current Operating System: Linux cip1pavilion4 3.2.0-55-generic #85-Ubuntu SMP Wed Oct 2 12:29:27 UTC 2013 x86_64
Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.2.0-55-generic root=UUID=89b2d486-cca6-4fd3-9e0c-9efd4b9eaa29 ro
quiet splash
Build Date: 16 October 2013 04:41:23PM
xorg-server 2:1.11.4-0ubuntu10.14 (For technical support please see http://www.ubuntu.com/support)
Current version of pixman: 0.24.4
Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.1.log", Time: Thu Nov 7 12:05:14 2013
(++) Using config file: "/etc/X11/xorg-vesa.conf"
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
error setting MTRR (base = 0xf1000000, size = 0x00e00000, type = 1) Invalid argument (22)
1 XSELINUXs still allocated at reset
SCREEN: 0 objects of 248 bytes = 0 total bytes 0 private allocs
COLORMAP: 0 objects of 8 bytes = 0 total bytes 0 private allocs
DEVICE: 0 objects of 96 bytes = 0 total bytes 0 private allocs
CLIENT: 0 objects of 120 bytes = 0 total bytes 0 private allocs
WINDOW: 0 objects of 48 bytes = 0 total bytes 0 private allocs
PIXMAP: 1 objects of 16 bytes = 16 total bytes 0 private allocs
Xorg.log:
[1382936.641] X Protocol Version 11, Revision 0
[1382936.641] Build Operating System: Linux 2.6.42-37-generic x86_64 Ubuntu
[1382936.641] Current Operating System: Linux cip1pavilion4 3.2.0-55-generic #85-Ubuntu SMP Wed Oct 2 12:29:27 UT
C 2013 x86_64
[1382936.641] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.2.0-55-generic root=UUID=89b2d486-cca6-4fd3-9e0c-9e
fd4b9eaa29 ro quiet splash
[1382936.641] Build Date: 16 October 2013 04:41:23PM
[1382936.641] xorg-server 2:1.11.4-0ubuntu10.14 (For technical support please see http://www.ubuntu.com/support)
[1382936.641] Current version of pixman: 0.24.4
[1382936.641] Before reporting problems, check http://wiki.x.org
[1382936.641] Markers: (--) probed, (**) from config file, (==) default setting,
[1382936.641] (==) Log file: "/var/log/Xorg.1.log", Time: Thu Nov 7 12:05:14 2013
[1382936.641] (++) Using config file: "/etc/X11/xorg-vesa.conf"
[1382936.642] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[1382936.642] (==) No Layout section. Using the first Screen section.
[1382936.642] (**) |-->Screen "Default Screen" (0)
[1382936.642] (**) | |-->Monitor "Configured Monitor"
[1382936.642] (**) | |-->Device "Configured Video Device"
[1382936.642] (==) Automatically adding devices
[1382936.642] (==) Automatically enabling devices
[1382936.642] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[1382936.642] Entry deleted from font path.
[1382936.642] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[1382936.642] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[1382936.642] (WW) The directory "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType" does not exist.
[1382936.642] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/75dpi/:unscaled,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/75dpi,
built-ins
[1382936.642] (==) ModulePath set to "/usr/lib/x86_64-linux-gnu/xorg/extra-modules,/usr/lib/xorg/extra-modules,/u
sr/lib/xorg/modules"
[1382936.642] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[1382936.642] (II) Loader magic: 0x7f5eed6a1b00
[1382936.642] (II) Module ABI versions:
[1382936.642] X.Org ANSI C Emulation: 0.4
[1382936.642] X.Org Video Driver: 11.0
[1382936.642] X.Org XInput driver : 16.0
[1382936.642] X.Org Server Extension : 6.0
[1382936.643] (--) PCI:*(0:1:0:0) 10de:1058:103c:2aed rev 161, Mem @ 0xf6000000/16777216, 0xe8000000/134217728, 0
xf0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/524288
[1382936.643] (II) Open ACPI successful (/var/run/acpid.socket)
[1382936.643] (II) LoadModule: "extmod"
[1382936.644] (II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
[1382936.644] (II) Module extmod: vendor="X.Org Foundation"
[1382936.644] compiled for 1.11.3, module version = 1.0.0
[1382936.644] Module class: X.Org Server Extension
[1382936.644] ABI class: X.Org Server Extension, version 6.0
[1382936.644] (II) Loading extension MIT-SCREEN-SAVER
[1382936.644] (II) Loading extension XFree86-VidModeExtension
[1382936.644] (II) Loading extension XFree86-DGA
[1382936.644] (II) Loading extension DPMS
[1382936.644] (II) Loading extension XVideo
[1382936.644] (II) Loading extension XVideo-MotionCompensation
[1382936.644] (II) Loading extension X-Resource
[1382936.644] (II) LoadModule: "dbe"
[1382936.644] (II) Loading /usr/lib/xorg/modules/extensions/libdbe.so
[1382936.644] (II) Module dbe: vendor="X.Org Foundation"
[1382936.644] (II) Loading extension DOUBLE-BUFFER
[1382936.644] (II) LoadModule: "glx"
[1382936.644] (II) Loading /usr/lib/x86_64-linux-gnu/xorg/extra-modules/libglx.so
[1382936.655] (II) Module glx: vendor="NVIDIA Corporation"
[1382936.655] compiled for 4.0.2, module version = 1.0.0
[1382936.655] Module class: X.Org Server Extension
[1382936.655] (II) NVIDIA GLX Module 304.88 Wed Mar 27 14:46:57 PDT 2013
[1382936.655] (II) Loading extension GLX
[1382936.655] (II) LoadModule: "record"
[1382936.655] (II) Loading /usr/lib/xorg/modules/extensions/librecord.so
[1382936.655] (II) Module record: vendor="X.Org Foundation"
[1382936.655] compiled for 1.11.3, module version = 1.13.0
[1382936.656] ABI class: X.Org Server Extension, version 6.0
[1382936.656] (II) Loading extension RECORD
[1382936.656] (II) LoadModule: "dri"
[1382936.656] (II) Loading /usr/lib/xorg/modules/extensions/libdri.so
[1382936.656] (II) Module dri: vendor="X.Org Foundation"
[1382936.656] compiled for 1.11.3, module version = 1.0.0
[1382936.656] (II) Loading extension XFree86-DRI
[1382936.656] (II) LoadModule: "dri2"
[1382936.656] (II) Loading /usr/lib/xorg/modules/extensions/libdri2.so
[1382936.656] (II) Module dri2: vendor="X.Org Foundation"
[1382936.656] compiled for 1.11.3, module version = 1.2.0
[1382936.656] (II) Loading extension DRI2
[1382936.656] (II) LoadModule: "vesa"
[1382936.657] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[1382936.657] (II) Module vesa: vendor="X.Org Foundation"
[1382936.657] compiled for 1.11.3, module version = 2.3.0
[1382936.657] Module class: X.Org Video Driver
[1382936.657] ABI class: X.Org Video Driver, version 11.0
[1382936.657] (II) VESA: driver for VESA chipsets: vesa
[1382936.657] (--) using VT number 8
[1382936.667] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[1382936.667] (II) Loading sub module "vbe"
[1382936.667] (II) LoadModule: "vbe"
[1382936.667] (II) Loading /usr/lib/xorg/modules/libvbe.so
[1382936.673] (II) Module vbe: vendor="X.Org Foundation"
[1382936.673] compiled for 1.11.3, module version = 1.1.0
[1382936.673] ABI class: X.Org Video Driver, version 11.0
[1382936.673] (II) Loading sub module "int10"
[1382936.673] (II) LoadModule: "int10"
[1382936.674] (II) Loading /usr/lib/xorg/modules/libint10.so
[1382936.682] (II) Module int10: vendor="X.Org Foundation"
[1382936.682] compiled for 1.11.3, module version = 1.0.0
[1382936.682] ABI class: X.Org Video Driver, version 11.0
[1382936.682] (II) VESA(0): initializing int10
[1382936.682] (II) VESA(0): Primary V_BIOS segment is: 0xc000
[1382936.725] (II) VESA(0): VESA BIOS detected
[1382936.725] (II) VESA(0): VESA VBE Version 3.0
[1382936.725] (II) VESA(0): VESA VBE Total Mem: 14336 kB
[1382936.725] (II) VESA(0): VESA VBE OEM: NVIDIA
[1382936.725] (II) VESA(0): VESA VBE OEM Software Rev: 117.25
[1382936.725] (II) VESA(0): VESA VBE OEM Vendor: NVIDIA Corporation
[1382936.725] (II) VESA(0): VESA VBE OEM Product: GF119 Board - 13030760
[1382936.725] (II) VESA(0): VESA VBE OEM Product Rev: Chip Rev
[1382936.805] (II) VESA(0): Creating default Display subsection in Screen section
"Default Screen" for depth/fbbpp 24/32
[1382936.805] (==) VESA(0): Depth 24, (--) framebuffer bpp 32
[1382936.805] (==) VESA(0): RGB weight 888
[1382936.805] (==) VESA(0): Default visual is TrueColor
[1382936.805] (==) VESA(0): Using gamma correction (1.0, 1.0, 1.0)
[1382936.805] (II) Loading sub module "ddc"
[1382936.805] (II) LoadModule: "ddc"
[1382936.805] (II) Module "ddc" already built-in
[1382936.866] (II) VESA(0): VESA VBE DDC supported
[1382936.866] (II) VESA(0): VESA VBE DDC Level none
[1382936.866] (II) VESA(0): VESA VBE DDC transfer in appr. 0 sec.
[1382939.154] (II) VESA(0): VESA VBE DDC read failed
[1382939.154] (II) VESA(0): VESA VBE PanelID read failed
[1382939.154] (II) VESA(0): Searching for matching VESA mode(s):
[1382939.156] Mode: 100 (640x400)
[1382939.156] ModeAttributes: 0x3bf
[1382939.156] WinAAttributes: 0x7
[1382939.156] WinBAttributes: 0x0
[1382939.156] WinGranularity: 64
[1382939.156] WinSize: 64
[1382939.156] WinASegment: 0xa000
[1382939.156] WinBSegment: 0x0
[1382939.156] WinFuncPtr: 0xc00080d4
[1382939.156] BytesPerScanline: 640
[1382939.156] XResolution: 640
[1382939.156] YResolution: 400
[1382939.156] XCharSize: 8
[1382939.156] YCharSize: 16
[1382939.156] NumberOfPlanes: 1
[1382939.156] BitsPerPixel: 8
[1382939.156] NumberOfBanks: 1
[1382939.156] MemoryModel: 4
[1382939.156] BankSize: 0
[1382939.156] NumberOfImages: 14
[1382939.156] RedMaskSize: 0
[1382939.156] RedFieldPosition: 0
[1382939.156] GreenMaskSize: 0
[1382939.156] GreenFieldPosition: 0
[1382939.156] BlueMaskSize: 0
[1382939.156] BlueFieldPosition: 0
[1382939.156] RsvdMaskSize: 0
[1382939.156] RsvdFieldPosition: 0
[1382939.156] DirectColorModeInfo: 0
[1382939.156] PhysBasePtr: 0xf1000000
[1382939.156] LinBytesPerScanLine: 640
[1382939.156] BnkNumberOfImagePages: 14
[1382939.196] RedFieldPosition: 16
[1382939.196] GreenMaskSize: 8
[1382939.196] GreenFieldPosition: 8
[1382939.196] BlueMaskSize: 8
[1382939.196] BlueFieldPosition: 0
[1382939.196] RsvdMaskSize: 8
[1382939.196] RsvdFieldPosition: 24
[1382939.196] DirectColorModeInfo: 0
[1382939.196] PhysBasePtr: 0xf1000000
[1382939.196] LinBytesPerScanLine: 5120
[1382939.196] BnkNumberOfImagePages: 1
[1382939.196] LinNumberOfImagePages: 1
[1382939.196] LinRedMaskSize: 8
[1382939.196] LinRedFieldPosition: 16
[1382939.197] LinGreenMaskSize: 8
[1382939.197] LinGreenFieldPosition: 8
[1382939.197] LinBlueMaskSize: 8
[1382939.197] LinBlueFieldPosition: 0
[1382939.197] LinRsvdMaskSize: 8
[1382939.197] LinRsvdFieldPosition: 24
[1382939.197] MaxPixelClock: 229500000
[1382939.197]
[1382939.197] (II) VESA(0): Total Memory: 224 64KB banks (14336kB)
[1382939.197] (II) VESA(0): Configured Monitor: Using default hsync range of 31.50-48.00 kHz
[1382939.197] (II) VESA(0): Configured Monitor: Using default vrefresh range of 50.00-70.00 Hz
[1382939.197] (II) VESA(0): Configured Monitor: Using default maximum pixel clock of 65.00 MHz
[1382939.197] (WW) VESA(0): Unable to estimate virtual size
[1382939.197] (II) VESA(0): Not using built-in mode "1920x1080" (no mode of this name)
[1382939.197] (II) VESA(0): Not using built-in mode "1280x1024" (no mode of this name)
[1382939.197] (II) VESA(0): Not using built-in mode "1280x800" (no mode of this name)
[1382939.197] (II) VESA(0): Not using built-in mode "1024x768" (no mode of this name)
[1382939.197] (II) VESA(0): Not using built-in mode "800x600" (no mode of this name)
[1382939.197] (II) VESA(0): Not using built-in mode "640x480" (no mode of this name)
[1382939.197] (II) VESA(0): Not using built-in mode "640x400" (no mode of this name)
[1382939.197] (II) VESA(0): Not using built-in mode "320x400" (no mode of this name)
[1382939.197] (II) VESA(0): Not using built-in mode "320x240" (no mode of this name)
[1382939.197] (II) VESA(0): Not using built-in mode "320x200" (no mode of this name)
[1382939.197] (WW) VESA(0): No valid modes left. Trying less strict filter...
[1382939.197] (II) VESA(0): Configured Monitor: Using hsync range of 31.50-48.00 kHz
[1382939.197] (II) VESA(0): Configured Monitor: Using vrefresh range of 50.00-70.00 Hz
[1382939.197] (II) VESA(0): Configured Monitor: Using maximum pixel clock of 65.00 MHz
[1382939.197] (II) VESA(0): Not using built-in mode "1920x1080" (hsync out of range)
[1382939.197] (II) VESA(0): Not using built-in mode "1280x1024" (hsync out of range)
[1382939.197] (II) VESA(0): Not using built-in mode "1280x800" (hsync out of range)
[1382939.197] (II) VESA(0): Not using built-in mode "640x400" (hsync out of range)
[1382939.197] (II) VESA(0): Not using built-in mode "320x400" (hsync out of range)
[1382939.197] (II) VESA(0): Not using built-in mode "320x240" (illegal horizontal timings)
[1382939.197] (II) VESA(0): Not using built-in mode "320x200" (illegal horizontal timings)
[1382939.197] (--) VESA(0): Virtual size is 1024x768 (pitch 1024)
[1382939.197] (**) VESA(0): *Built-in mode "1024x768"
[1382939.197] (**) VESA(0): *Built-in mode "800x600"
[1382939.197] (**) VESA(0): *Built-in mode "640x480"
[1382939.197] (==) VESA(0): DPI set to (96, 96)
[1382939.197] (II) VESA(0): Attempting to use 60Hz refresh for mode "1024x768" (118)
[1382939.198] (II) VESA(0): Attempting to use 60Hz refresh for mode "800x600" (115)
[1382939.198] (II) VESA(0): Attempting to use 60Hz refresh for mode "640x480" (112)
[1382939.199] (**) VESA(0): Using "Shadow Framebuffer"
[1382939.199] (II) Loading sub module "shadow"
[1382939.199] (II) LoadModule: "shadow"
[1382939.199] (II) Loading /usr/lib/xorg/modules/libshadow.so
[1382939.207] (II) Module shadow: vendor="X.Org Foundation"
[1382939.207] compiled for 1.11.3, module version = 1.1.0
[1382939.207] ABI class: X.Org ANSI C Emulation, version 0.4
[1382939.207] (II) Loading sub module "fb"
[1382939.207] (II) LoadModule: "fb"
[1382939.207] (II) Loading /usr/lib/xorg/modules/libfb.so
[1382939.207] (II) Module fb: vendor="X.Org Foundation"
[1382939.207] compiled for 1.11.3, module version = 1.0.0
[1382939.207] (==) Depth 24 pixmap format is 32 bpp
[1382939.207] (II) Loading sub module "int10"
[1382939.207] (II) LoadModule: "int10"
[1382939.207] (II) Loading /usr/lib/xorg/modules/libint10.so
[1382939.207] (II) Module int10: vendor="X.Org Foundation"
[1382939.207] ABI class: X.Org Video Driver, version 11.0
[1382939.207] (II) VESA(0): initializing int10
[1382939.207] (II) VESA(0): Primary V_BIOS segment is: 0xc000
[1382939.250] (II) VESA(0): VESA BIOS detected
[1382939.250] (II) VESA(0): VESA VBE Version 3.0
[1382939.250] (II) VESA(0): VESA VBE Total Mem: 14336 kB
[1382939.250] (II) VESA(0): VESA VBE OEM: NVIDIA
[1382939.250] (II) VESA(0): VESA VBE OEM Software Rev: 117.25
[1382939.250] (II) VESA(0): VESA VBE OEM Vendor: NVIDIA Corporation
[1382939.250] (II) VESA(0): VESA VBE OEM Product: GF119 Board - 13030760
[1382939.250] (II) VESA(0): VESA VBE OEM Product Rev: Chip Rev
[1382939.252] (II) VESA(0): virtual address = 0x7f5ee51bc000,
physical address = 0xf1000000, size = 14680064
[1382939.273] (II) VESA(0): Setting up VESA Mode 0x118 (1024x768)
[1382939.360] (==) VESA(0): Default visual is TrueColor
[1382939.370] (==) VESA(0): Backing store disabled
[1382939.370] (==) VESA(0): DPMS enabled
[1382939.370] (==) RandR enabled
[1382939.370] (II) Initializing built-in extension Generic Event Extension
[1382939.370] (II) Initializing built-in extension SHAPE
[1382939.370] (II) Initializing built-in extension MIT-SHM
[1382939.370] (II) Initializing built-in extension XInputExtension
[1382939.370] (II) Initializing built-in extension XTEST
[1382939.370] (II) Initializing built-in extension BIG-REQUESTS
[1382939.370] (II) Initializing built-in extension SYNC
[1382939.370] (II) Initializing built-in extension XKEYBOARD
[1382939.370] (II) Initializing built-in extension XC-MISC
[1382939.370] (II) Initializing built-in extension SECURITY
[1382939.370] (II) Initializing built-in extension XINERAMA
[1382939.370] (II) Initializing built-in extension XFIXES
[1382939.370] (II) Initializing built-in extension RENDER
[1382939.370] (II) Initializing built-in extension RANDR
[1382939.370] (II) Initializing built-in extension COMPOSITE
[1382939.370] (II) Initializing built-in extension DAMAGE
[1382939.371] (EE) Failed to initialize GLX extension (Compatible NVIDIA X driver not found)
[1382939.381] (II) XKB: reuse xkmfile /var/lib/xkb/server-B20D7FC79C7F597315E3E501AEF10E0D866E8E92.xkm
[1382939.382] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[1382939.382] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[1382939.382] (II) LoadModule: "evdev"
[1382939.383] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[1382939.383] (II) Module evdev: vendor="X.Org Foundation"
[1382939.383] compiled for 1.11.3, module version = 2.7.0
[1382939.383] Module class: X.Org XInput Driver
[1382939.383] ABI class: X.Org XInput driver, version 16.0
[1382939.383] (II) Using input driver 'evdev' for 'Power Button'
[1382939.383] (**) Power Button: always reports core events
[1382939.383] (**) evdev: Power Button: Device: "/dev/input/event1"
[1382939.383] (--) evdev: Power Button: Vendor 0 Product 0x1
[1382939.383] (--) evdev: Power Button: Found keys
[1382939.383] (II) evdev: Power Button: Configuring as keyboard
[1382939.383] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[1382939.383] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[1382939.383] (**) Option "xkb_rules" "evdev"
[1382939.383] (**) Option "xkb_model" "pc105"
[1382939.383] (**) Option "xkb_layout" "de"
[1382939.384] (II) XKB: reuse xkmfile /var/lib/xkb/server-808BBA3D4C227BDB44C370226C34E44C5D69A4A9.xkm
[1382939.384] (II) config/udev: Adding input device Video Bus (/dev/input/event3)
[1382939.384] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[1382939.384] (II) Using input driver 'evdev' for 'Video Bus'
[1382939.384] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[1382939.384] (**) Video Bus: always reports core events
[1382939.384] (**) evdev: Video Bus: Device: "/dev/input/event3"
[1382939.384] (--) evdev: Video Bus: Vendor 0 Product 0x6
[1382939.384] (--) evdev: Video Bus: Found keys
[1382939.384] (II) evdev: Video Bus: Configuring as keyboard
[1382939.384] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:19/LNXVIDEO:
00/input/input3/event3"
[1382939.384] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[1382939.384] (**) Option "xkb_rules" "evdev"
[1382939.384] (**) Option "xkb_model" "pc105"
[1382939.384] (**) Option "xkb_layout" "de"
[1382939.385] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[1382939.385] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[1382939.385] (II) Using input driver 'evdev' for 'Power Button'
[1382939.385] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[1382939.385] (**) Power Button: always reports core events
[1382939.385] (**) evdev: Power Button: Device: "/dev/input/event0"
[1382939.385] (--) evdev: Power Button: Vendor 0 Product 0x1
[1382939.385] (--) evdev: Power Button: Found keys
[1382939.385] (II) evdev: Power Button: Configuring as keyboard
[1382939.385] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0
[1382939.385] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 8)
[1382939.385] (**) Option "xkb_rules" "evdev"
[1382939.385] (**) Option "xkb_model" "pc105"
[1382939.385] (**) Option "xkb_layout" "de"
[1382939.385] (II) config/udev: Adding input device HP 1.0MP High Definition Webcam (/dev/input/event10)
[1382939.385] (**) HP 1.0MP High Definition Webcam: Applying InputClass "evdev keyboard catchall"
[1382939.385] (II) Using input driver 'evdev' for 'HP 1.0MP High Definition Webcam'
[1382939.385] (**) HP 1.0MP High Definition Webcam: always reports core events
[1382939.385] (**) evdev: HP 1.0MP High Definition Webcam: Device: "/dev/input/event10"
[1382939.385] (--) evdev: HP 1.0MP High Definition Webcam: Vendor 0xbda Product 0x58b6
[1382939.385] (--) evdev: HP 1.0MP High Definition Webcam: Found keys
[1382939.385] (II) evdev: HP 1.0MP High Definition Webcam: Configuring as keyboard
[1382939.385] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.3/1-1.3:1.0/input
/input10/event10"
[1382939.385] (II) XINPUT: Adding extended input device "HP 1.0MP High Definition Webcam" (type: KEYBOARD, id 9)
[1382939.385] (II) config/udev: Adding input device HDA Intel PCH Mic (/dev/input/event7)
[1382939.385] (II) No input driver specified, ignoring this device.
[1382939.385] (II) This device may have been added with another device file.
[1382939.385] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event8)
[1382939.386] (II) No input driver specified, ignoring this device.
[1382939.386] (II) This device may have been added with another device file.
[1382939.386] (II) config/udev: Adding input device HDA Intel PCH Line-Out (/dev/input/event9)
[1382939.386] (II) config/udev: Adding input device NOVATEK USB Keyboard (/dev/input/event4)
[1382939.386] (**) NOVATEK USB Keyboard: Applying InputClass "evdev keyboard catchall"
[1382939.386] (II) Using input driver 'evdev' for 'NOVATEK USB Keyboard'
[1382939.386] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[1382939.386] (**) NOVATEK USB Keyboard: always reports core events
[1382939.386] (**) evdev: NOVATEK USB Keyboard: Device: "/dev/input/event4"
[1382939.386] (--) evdev: NOVATEK USB Keyboard: Vendor 0x461 Product 0x10
[1382939.386] (--) evdev: NOVATEK USB Keyboard: Found keys
[1382939.386] (II) evdev: NOVATEK USB Keyboard: Configuring as keyboard
[1382939.386] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1/2-1.1:1.0/input
/input4/event4"
[1382939.386] (II) XINPUT: Adding extended input device "NOVATEK USB Keyboard" (type: KEYBOARD, id 10)
[1382939.386] (**) Option "xkb_rules" "evdev"
[1382939.386] (**) Option "xkb_model" "pc105"
[1382939.386] (**) Option "xkb_layout" "de"
[1382939.386] (II) config/udev: Adding input device NOVATEK USB Keyboard (/dev/input/event5)
[1382939.386] (**) evdev: NOVATEK USB Keyboard: Device: "/dev/input/event5"
[1382939.386] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1/2-1.1:1.1/input
/input5/event5"
[1382939.386] (II) XINPUT: Adding extended input device "NOVATEK USB Keyboard" (type: KEYBOARD, id 11)
[1382939.387] (II) config/udev: Adding input device USB Optical Mouse (/dev/input/event6)
[1382939.387] (**) USB Optical Mouse: Applying InputClass "evdev pointer catchall"
[1382939.387] (II) Using input driver 'evdev' for 'USB Optical Mouse'
[1382939.387] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[1382939.387] (**) USB Optical Mouse: always reports core events
[1382939.387] (**) evdev: USB Optical Mouse: Device: "/dev/input/event6"
[1382939.387] (--) evdev: USB Optical Mouse: Vendor 0x461 Product 0x4d0f
[1382939.387] (--) evdev: USB Optical Mouse: Found 3 mouse buttons
[1382939.387] (--) evdev: USB Optical Mouse: Found scroll wheel(s)
[1382939.387] (--) evdev: USB Optical Mouse: Found relative axes
[1382939.387] (--) evdev: USB Optical Mouse: Found x and y relative axes
[1382939.387] (II) evdev: USB Optical Mouse: Configuring as mouse
[1382939.387] (II) evdev: USB Optical Mouse: Adding scrollwheel support
[1382939.387] (**) evdev: USB Optical Mouse: YAxisMapping: buttons 4 and 5
[1382939.387] (**) evdev: USB Optical Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout:
200
[1382939.387] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.4/2-1.4:1.0/input
/input6/event6"
[1382939.387] (II) XINPUT: Adding extended input device "USB Optical Mouse" (type: MOUSE, id 12)
[1382939.387] (II) evdev: USB Optical Mouse: initialized for relative axes.
[1382939.387] (**) USB Optical Mouse: (accel) keeping acceleration scheme 1
[1382939.387] (**) USB Optical Mouse: (accel) acceleration profile 0
[1382939.387] (**) USB Optical Mouse: (accel) acceleration factor: 2.000
[1382939.387] (**) USB Optical Mouse: (accel) acceleration threshold: 4
[1382939.387] (II) config/udev: Adding input device USB Optical Mouse (/dev/input/mouse0)
[1382939.387] (II) No input driver specified, ignoring this device.
[1382939.387] (II) This device may have been added with another device file.
[1382939.387] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event2)
[1382939.387] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[1382939.387] (II) Using input driver 'evdev' for 'AT Translated Set 2 keyboard'
[1382939.387] (**) AT Translated Set 2 keyboard: always reports core events
[1382939.387] (**) evdev: AT Translated Set 2 keyboard: Device: "/dev/input/event2"
[1382939.387] (--) evdev: AT Translated Set 2 keyboard: Vendor 0x1 Product 0x1
[1382939.387] (--) evdev: AT Translated Set 2 keyboard: Found keys
[1382939.387] (II) evdev: AT Translated Set 2 keyboard: Configuring as keyboard
[1382939.387] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input2/event2"
[1382939.387] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 13)
[1382939.387] (**) Option "xkb_rules" "evdev"
[1382939.387] (**) Option "xkb_model" "pc105"
[1382939.387] (**) Option "xkb_layout" "de"
[1382971.576] (II) evdev: Power Button: Close
[1382971.576] (II) UnloadModule: "evdev"
[1382971.576] (II) Unloading evdev
[1382971.676] (II) evdev: Video Bus: Close
[1382971.676] (II) UnloadModule: "evdev"
[1382971.676] (II) Unloading evdev
[1382971.724] (II) evdev: Power Button: Close
[1382971.724] (II) UnloadModule: "evdev"
[1382971.724] (II) Unloading evdev
[1382971.736] (II) evdev: HP 1.0MP High Definition Webcam: Close
[1382971.736] (II) UnloadModule: "evdev"
[1382971.736] (II) Unloading evdev
[1382971.748] (II) evdev: NOVATEK USB Keyboard: Close
[1382971.748] (II) UnloadModule: "evdev"
[1382971.748] (II) Unloading evdev
[1382971.756] (II) evdev: USB Optical Mouse: Close
[1382971.756] (II) UnloadModule: "evdev"
[1382971.756] (II) Unloading evdev
[1382971.764] (II) evdev: AT Translated Set 2 keyboard: Close
[1382971.764] (II) UnloadModule: "evdev"
[1382971.764] (II) Unloading evdev
[1382971.933] 1 XSELINUXs still allocated at reset
[1382971.933] SCREEN: 0 objects of 248 bytes = 0 total bytes 0 private allocs
[1382971.933] COLORMAP: 0 objects of 8 bytes = 0 total bytes 0 private allocs
[1382971.933] DEVICE: 0 objects of 96 bytes = 0 total bytes 0 private allocs
[1382971.933] CLIENT: 0 objects of 120 bytes = 0 total bytes 0 private allocs
[1382971.933] WINDOW: 0 objects of 48 bytes = 0 total bytes 0 private allocs
[1382971.933] PIXMAP: 1 objects of 16 bytes = 16 total bytes 0 private allocs
[1382971.933] GC: 0 objects of 56 bytes = 0 total bytes 0 private allocs
[1382971.933] CURSOR: 0 objects of 8 bytes = 0 total bytes 0 private allocs
[1382971.933] CURSOR_BITS: 0 objects of 8 bytes = 0 total bytes 0 private allocs
[1382971.933] DBE_WINDOW: 0 objects of 24 bytes = 0 total bytes 0 private allocs
[1382971.933] TOTAL: 1 objects, 16 bytes, 0 allocs
[1382971.933] 1 PIXMAPs still allocated at reset
[1382971.934] (II) Open ACPI successful (/var/run/acpid.socket)
[1382971.934] (II) APM registered successfully
[1382971.934] (II) Loading sub module "int10"
[1382971.934] (II) LoadModule: "int10"
[1382971.934] (II) Loading /usr/lib/xorg/modules/libint10.so
[1382971.934] (II) Module int10: vendor="X.Org Foundation"
[1382971.934] compiled for 1.11.3, module version = 1.0.0
[1382971.934] ABI class: X.Org Video Driver, version 11.0
[1382971.934] (II) VESA(0): initializing int10
[1382971.934] (II) VESA(0): Primary V_BIOS segment is: 0xc000
[1382971.977] (II) VESA(0): VESA BIOS detected
[1382971.977] (II) VESA(0): VESA VBE Version 3.0
[1382971.977] (II) VESA(0): VESA VBE Total Mem: 14336 kB
[1382971.977] (II) VESA(0): VESA VBE OEM: NVIDIA
[1382971.977] (II) VESA(0): VESA VBE OEM Software Rev: 117.25
[1382971.977] (II) VESA(0): VESA VBE OEM Vendor: NVIDIA Corporation
[1382971.977] (II) VESA(0): VESA VBE OEM Product: GF119 Board - 13030760
[1382971.977] (II) VESA(0): VESA VBE OEM Product Rev: Chip Rev
[1382971.980] (II) VESA(0): virtual address = 0x7f5ee51bc000,
[1382971.982] (II) VESA(0): Setting up VESA Mode 0x118 (1024x768)
[1382972.080] (==) VESA(0): Default visual is TrueColor
[1382972.081] (==) VESA(0): DPMS enabled
[1382972.081] (==) RandR enabled
[1382972.081] (EE) Failed to initialize GLX extension (Compatible NVIDIA X driver not found)
[1382972.090] (II) XKB: reuse xkmfile /var/lib/xkb/server-B20D7FC79C7F597315E3E501AEF10E0D866E8E92.xkm
[1382972.092] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[1382972.092] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[1382972.092] (II) Using input driver 'evdev' for 'Power Button'
[1382972.092] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[1382972.092] (**) Power Button: always reports core events
[1382972.092] (**) evdev: Power Button: Device: "/dev/input/event1"
[1382972.092] (--) evdev: Power Button: Vendor 0 Product 0x1
[1382972.092] (--) evdev: Power Button: Found keys
[1382972.092] (II) evdev: Power Button: Configuring as keyboard
[1382972.092] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[1382972.092] (**) Option "xkb_rules" "evdev"
[1382972.092] (**) Option "xkb_model" "pc105"
[1382972.092] (**) Option "xkb_layout" "de"
[1382972.093] (II) XKB: reuse xkmfile /var/lib/xkb/server-808BBA3D4C227BDB44C370226C34E44C5D69A4A9.xkm
[1382972.093] (II) config/udev: Adding input device Video Bus (/dev/input/event3)
[1382972.093] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[1382972.093] (II) Using input driver 'evdev' for 'Video Bus'
[1382972.093] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[1382972.093] (**) Video Bus: always reports core events
[1382972.093] (**) evdev: Video Bus: Device: "/dev/input/event3"
[1382972.093] (--) evdev: Video Bus: Vendor 0 Product 0x6
[1382972.093] (--) evdev: Video Bus: Found keys
[1382972.093] (II) evdev: Video Bus: Configuring as keyboard
[1382972.093] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:19/LNXVIDEO:
[1382972.093] (**) Option "xkb_rules" "evdev"
[1382972.093] (**) Option "xkb_model" "pc105"
[1382972.093] (**) Option "xkb_layout" "de"
[1382972.094] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[1382972.094] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[1382972.094] (II) Using input driver 'evdev' for 'Power Button'
[1382972.094] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[1382972.094] (**) Power Button: always reports core events
[1382972.094] (**) evdev: Power Button: Device: "/dev/input/event0"
[1382972.094] (--) evdev: Power Button: Vendor 0 Product 0x1
[1382972.094] (--) evdev: Power Button: Found keys
[1382972.094] (II) evdev: Power Button: Configuring as keyboard
[1382972.094] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0
[1382972.094] (**) Option "xkb_rules" "evdev"
[1382972.094] (**) Option "xkb_model" "pc105"
[1382972.094] (**) Option "xkb_layout" "de"
[1382972.094] (II) config/udev: Adding input device HP 1.0MP High Definition Webcam (/dev/input/event10)
[1382972.094] (**) HP 1.0MP High Definition Webcam: Applying InputClass "evdev keyboard catchall"
[1382972.094] (II) Using input driver 'evdev' for 'HP 1.0MP High Definition Webcam'
[1382972.094] (**) HP 1.0MP High Definition Webcam: always reports core events
[1382972.094] (**) evdev: HP 1.0MP High Definition Webcam: Device: "/dev/input/event10"
[1382972.094] (--) evdev: HP 1.0MP High Definition Webcam: Vendor 0xbda Product 0x58b6
[1382972.094] (--) evdev: HP 1.0MP High Definition Webcam: Found keys
[1382972.094] (II) evdev: HP 1.0MP High Definition Webcam: Configuring as keyboard
[1382972.094] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.3/1-1.3:1.0/input
/input10/event10"
[1382972.094] (II) config/udev: Adding input device HDA Intel PCH Mic (/dev/input/event7)
[1382972.094] (II) No input driver specified, ignoring this device.
[1382972.094] (II) This device may have been added with another device file.
[1382972.095] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event8)
[1382972.095] (II) No input driver specified, ignoring this device.
[1382972.095] (II) This device may have been added with another device file.
[1382972.095] (II) config/udev: Adding input device HDA Intel PCH Line-Out (/dev/input/event9)
[1382972.095] (II) config/udev: Adding input device NOVATEK USB Keyboard (/dev/input/event4)
[1382972.095] (**) NOVATEK USB Keyboard: Applying InputClass "evdev keyboard catchall"
[1382972.095] (II) Using input driver 'evdev' for 'NOVATEK USB Keyboard'
[1382972.095] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[1382972.095] (**) NOVATEK USB Keyboard: always reports core events
[1382972.095] (**) evdev: NOVATEK USB Keyboard: Device: "/dev/input/event4"
[1382972.095] (--) evdev: NOVATEK USB Keyboard: Vendor 0x461 Product 0x10
[1382972.095] (--) evdev: NOVATEK USB Keyboard: Found keys
[1382972.095] (II) evdev: NOVATEK USB Keyboard: Configuring as keyboard
[1382972.095] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1/2-1.1:1.0/input
/input4/event4"
[1382972.095] (**) Option "xkb_rules" "evdev"
[1382972.095] (**) Option "xkb_model" "pc105"
[1382972.095] (**) Option "xkb_layout" "de"
[1382972.095] (II) config/udev: Adding input device NOVATEK USB Keyboard (/dev/input/event5)
[1382972.095] (**) evdev: NOVATEK USB Keyboard: Device: "/dev/input/event5"
[1382972.095] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1/2-1.1:1.1/input
/input5/event5"
[1382972.096] (II) config/udev: Adding input device USB Optical Mouse (/dev/input/event6)
[1382972.096] (**) USB Optical Mouse: Applying InputClass "evdev pointer catchall"
[1382972.096] (II) Using input driver 'evdev' for 'USB Optical Mouse'
[1382972.096] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[1382972.096] (**) USB Optical Mouse: always reports core events
[1382972.096] (**) evdev: USB Optical Mouse: Device: "/dev/input/event6"
[1382972.096] (--) evdev: USB Optical Mouse: Vendor 0x461 Product 0x4d0f
[1382972.096] (--) evdev: USB Optical Mouse: Found 3 mouse buttons
[1382972.096] (--) evdev: USB Optical Mouse: Found scroll wheel(s)
[1382972.096] (--) evdev: USB Optical Mouse: Found relative axes
[1382972.096] (--) evdev: USB Optical Mouse: Found x and y relative axes
[1382972.096] (II) evdev: USB Optical Mouse: Configuring as mouse
[1382972.096] (II) evdev: USB Optical Mouse: Adding scrollwheel support
[1382972.096] (**) evdev: USB Optical Mouse: YAxisMapping: buttons 4 and 5
[1382972.096] (**) evdev: USB Optical Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout:
200
[1382972.096] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.4/2-1.4:1.0/input
/input6/event6"
[1382972.096] (II) evdev: USB Optical Mouse: initialized for relative axes.
[1382972.096] (**) USB Optical Mouse: (accel) keeping acceleration scheme 1
[1382972.096] (**) USB Optical Mouse: (accel) acceleration profile 0
[1382972.096] (**) USB Optical Mouse: (accel) acceleration factor: 2.000
[1382972.096] (**) USB Optical Mouse: (accel) acceleration threshold: 4
[1382972.096] (II) config/udev: Adding input device USB Optical Mouse (/dev/input/mouse0)
[1382972.096] (II) No input driver specified, ignoring this device.
[1382972.096] (II) This device may have been added with another device file.
[1382972.096] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event2)
[1382972.096] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[1382972.096] (II) Using input driver 'evdev' for 'AT Translated Set 2 keyboard'
[1382972.096] (**) AT Translated Set 2 keyboard: always reports core events
[1382972.096] (**) evdev: AT Translated Set 2 keyboard: Device: "/dev/input/event2"
[1382972.096] (--) evdev: AT Translated Set 2 keyboard: Vendor 0x1 Product 0x1
[1382972.096] (--) evdev: AT Translated Set 2 keyboard: Found keys
[1382972.096] (II) evdev: AT Translated Set 2 keyboard: Configuring as keyboard
[1382972.096] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input2/event2"
[1382972.096] (**) Option "xkb_rules" "evdev"
[1382972.096] (**) Option "xkb_model" "pc105"
[1382972.096] (**) Option "xkb_layout" "de"
[1382972.152] (II) evdev: Power Button: Close
[1382972.152] (II) UnloadModule: "evdev"
[1382972.152] (II) Unloading evdev
[1382972.180] (II) evdev: Video Bus: Close
[1382972.180] (II) UnloadModule: "evdev"
[1382972.180] (II) Unloading evdev
[1382972.252] (II) evdev: Power Button: Close
[1382972.252] (II) UnloadModule: "evdev"
[1382972.252] (II) Unloading evdev
[1382972.252] (II) evdev: HP 1.0MP High Definition Webcam: Close
[1382972.256] (II) evdev: NOVATEK USB Keyboard: Close
[1382972.256] (II) UnloadModule: "evdev"
[1382972.256] (II) Unloading evdev
[1382972.260] (II) evdev: USB Optical Mouse: Close
[1382972.260] (II) UnloadModule: "evdev"
[1382972.260] (II) Unloading evdev
[1382972.260] (II) evdev: AT Translated Set 2 keyboard: Close
[1382972.417] 1 XSELINUXs still allocated at reset
[1382972.417] SCREEN: 0 objects of 248 bytes = 0 total bytes 0 private allocs
[1382972.417] COLORMAP: 0 objects of 8 bytes = 0 total bytes 0 private allocs
[1382972.417] DEVICE: 0 objects of 96 bytes = 0 total bytes 0 private allocs
[1382972.417] CLIENT: 0 objects of 120 bytes = 0 total bytes 0 private allocs
[1382972.417] WINDOW: 0 objects of 48 bytes = 0 total bytes 0 private allocs
[1382972.418] PIXMAP: 1 objects of 16 bytes = 16 total bytes 0 private allocs
[1382972.418] GC: 0 objects of 56 bytes = 0 total bytes 0 private allocs
[1382972.418] CURSOR: 0 objects of 8 bytes = 0 total bytes 0 private allocs
[1382972.418] CURSOR_BITS: 0 objects of 8 bytes = 0 total bytes 0 private allocs
[1382972.418] DBE_WINDOW: 0 objects of 24 bytes = 0 total bytes 0 private allocs
[1382972.418] TOTAL: 1 objects, 16 bytes, 0 allocs
[1382972.418] 1 PIXMAPs still allocated at reset
[1382972.418] (II) Open ACPI successful (/var/run/acpid.socket)
[1382972.418] (II) APM registered successfully
[1382972.418] (II) Loading sub module "int10"
[1382972.418] (II) LoadModule: "int10"
[1382972.418] (II) Loading /usr/lib/xorg/modules/libint10.so
[1382972.418] (II) Module int10: vendor="X.Org Foundation"
[1382972.418] compiled for 1.11.3, module version = 1.0.0
[1382972.418] ABI class: X.Org Video Driver, version 11.0
[1382972.418] (II) VESA(0): initializing int10
[1382972.419] (II) VESA(0): Primary V_BIOS segment is: 0xc000
[1382972.461] (II) VESA(0): VESA BIOS detected
[1382972.461] (II) VESA(0): VESA VBE Version 3.0
[1382972.461] (II) VESA(0): VESA VBE Total Mem: 14336 kB
[1382972.461] (II) VESA(0): VESA VBE OEM: NVIDIA
[1382972.461] (II) VESA(0): VESA VBE OEM Software Rev: 117.25
[1382972.461] (II) VESA(0): VESA VBE OEM Vendor: NVIDIA Corporation
[1382972.461] (II) VESA(0): VESA VBE OEM Product: GF119 Board - 13030760
[1382972.461] (II) VESA(0): VESA VBE OEM Product Rev: Chip Rev
[1382972.464] (II) VESA(0): virtual address = 0x7f5ee51bc000,
[1382972.466] (II) VESA(0): Setting up VESA Mode 0x118 (1024x768)
[1382972.582] (==) VESA(0): Default visual is TrueColor
[1382972.582] (==) VESA(0): DPMS enabled
[1382972.582] (==) RandR enabled
[1382972.583] (EE) Failed to initialize GLX extension (Compatible NVIDIA X driver not found)
[1382972.594] (II) XKB: reuse xkmfile /var/lib/xkb/server-B20D7FC79C7F597315E3E501AEF10E0D866E8E92.xkm
[1382972.595] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[1382972.595] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[1382972.595] (II) Using input driver 'evdev' for 'Power Button'
[1382972.595] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[1382972.595] (**) Power Button: always reports core events
[1382972.595] (**) evdev: Power Button: Device: "/dev/input/event1"
[1382972.595] (--) evdev: Power Button: Vendor 0 Product 0x1
[1382972.595] (--) evdev: Power Button: Found keys
[1382972.595] (II) evdev: Power Button: Configuring as keyboard
[1382972.595] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[1382972.595] (**) Option "xkb_rules" "evdev"
[1382972.595] (**) Option "xkb_model" "pc105"
[1382972.595] (**) Option "xkb_layout" "de"
[1382972.596] (II) XKB: reuse xkmfile /var/lib/xkb/server-808BBA3D4C227BDB44C370226C34E44C5D69A4A9.xkm
[1382972.597] (II) config/udev: Adding input device Video Bus (/dev/input/event3)
[1382972.597] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[1382972.597] (II) Using input driver 'evdev' for 'Video Bus'
[1382972.597] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[1382972.597] (**) Video Bus: always reports core events
[1382972.597] (**) evdev: Video Bus: Device: "/dev/input/event3"
[1382972.597] (--) evdev: Video Bus: Vendor 0 Product 0x6
[1382972.597] (--) evdev: Video Bus: Found keys
[1382972.597] (II) evdev: Video Bus: Configuring as keyboard
[1382972.597] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:19/LNXVIDEO:
[1382972.597] (**) Option "xkb_rules" "evdev"
[1382972.597] (**) Option "xkb_model" "pc105"
[1382972.597] (**) Option "xkb_layout" "de"
[1382972.597] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[1382972.597] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[1382972.597] (II) Using input driver 'evdev' for 'Power Button'
[1382972.597] (**) Power Button: always reports core events
[1382972.597] (**) evdev: Power Button: Device: "/dev/input/event0"
[1382972.597] (--) evdev: Power Button: Vendor 0 Product 0x1
[1382972.597] (--) evdev: Power Button: Found keys
[1382972.597] (II) evdev: Power Button: Configuring as keyboard
[1382972.597] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0
[1382972.598] (II) config/udev: Adding input device HP 1.0MP High Definition Webcam (/dev/input/event10)
[1382972.598] (**) HP 1.0MP High Definition Webcam: Applying InputClass "evdev keyboard catchall"
[1382972.598] (II) Using input driver 'evdev' for 'HP 1.0MP High Definition Webcam'
[1382972.598] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[1382972.598] (**) HP 1.0MP High Definition Webcam: always reports core events
[1382972.598] (**) evdev: HP 1.0MP High Definition Webcam: Device: "/dev/input/event10"
[1382972.598] (--) evdev: HP 1.0MP High Definition Webcam: Vendor 0xbda Product 0x58b6
[1382972.598] (--) evdev: HP 1.0MP High Definition Webcam: Found keys
[1382972.598] (II) evdev: HP 1.0MP High Definition Webcam: Configuring as keyboard
[1382972.598] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.3/1-1.3:1.0/input
/input10/event10"
[1382972.598] (**) Option "xkb_rules" "evdev"
[1382972.598] (**) Option "xkb_model" "pc105"
[1382972.598] (**) Option "xkb_layout" "de"
[1382972.598] (II) config/udev: Adding input device HDA Intel PCH Mic (/dev/input/event7)
[1382972.598] (II) No input driver specified, ignoring this device.
[1382972.598] (II) This device may have been added with another device file.
[1382972.598] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event8)
[1382972.598] (II) config/udev: Adding input device HDA Intel PCH Line-Out (/dev/input/event9)
[1382972.598] (II) config/udev: Adding input device NOVATEK USB Keyboard (/dev/input/event4)
[1382972.598] (**) NOVATEK USB Keyboard: Applying InputClass "evdev keyboard catchall"
[1382972.598] (II) Using input driver 'evdev' for 'NOVATEK USB Keyboard'
[1382972.598] (**) NOVATEK USB Keyboard: always reports core events
[1382972.598] (**) evdev: NOVATEK USB Keyboard: Device: "/dev/input/event4"
[1382972.598] (--) evdev: NOVATEK USB Keyboard: Vendor 0x461 Product 0x10
[1382972.598] (--) evdev: NOVATEK USB Keyboard: Found keys
[1382972.598] (II) evdev: NOVATEK USB Keyboard: Configuring as keyboard
[1382972.598] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1/2-1.1:1.0/input
/input4/event4"
[1382972.599] (II) config/udev: Adding input device NOVATEK USB Keyboard (/dev/input/event5)
[1382972.599] (**) NOVATEK USB Keyboard: Applying InputClass "evdev keyboard catchall"
[1382972.599] (II) Using input driver 'evdev' for 'NOVATEK USB Keyboard'
[1382972.599] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[1382972.599] (**) NOVATEK USB Keyboard: always reports core events
[1382972.599] (**) evdev: NOVATEK USB Keyboard: Device: "/dev/input/event5"
[1382972.599] (--) evdev: NOVATEK USB Keyboard: Vendor 0x461 Product 0x10
[1382972.599] (--) evdev: NOVATEK USB Keyboard: Found keys
[1382972.599] (II) evdev: NOVATEK USB Keyboard: Configuring as keyboard
[1382972.599] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1/2-1.1:1.1/input
/input5/event5"
[1382972.599] (**) Option "xkb_rules" "evdev"
[1382972.599] (**) Option "xkb_model" "pc105"
[1382972.599] (**) Option "xkb_layout" "de"
[1382972.599] (II) config/udev: Adding input device USB Optical Mouse (/dev/input/event6)
[1382972.599] (**) USB Optical Mouse: Applying InputClass "evdev pointer catchall"
[1382972.599] (II) Using input driver 'evdev' for 'USB Optical Mouse'
[1382972.599] (**) USB Optical Mouse: always reports core events
[1382972.599] (**) evdev: USB Optical Mouse: Device: "/dev/input/event6"
[1382972.599] (--) evdev: USB Optical Mouse: Vendor 0x461 Product 0x4d0f
[1382972.599] (--) evdev: USB Optical Mouse: Found 3 mouse buttons
[1382972.599] (--) evdev: USB Optical Mouse: Found scroll wheel(s)
[1382972.599] (--) evdev: USB Optical Mouse: Found relative axes
[1382972.599] (--) evdev: USB Optical Mouse: Found x and y relative axes
[1382972.599] (II) evdev: USB Optical Mouse: Configuring as mouse
[1382972.599] (II) evdev: USB Optical Mouse: Adding scrollwheel support
[1382972.599] (**) evdev: USB Optical Mouse: YAxisMapping: buttons 4 and 5
[1382972.599] (**) evdev: USB Optical Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout:
200
[1382972.599] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.4/2-1.4:1.0/input
/input6/event6"
[1382972.599] (II) evdev: USB Optical Mouse: initialized for relative axes.
[1382972.599] (**) USB Optical Mouse: (accel) keeping acceleration scheme 1
[1382972.599] (**) USB Optical Mouse: (accel) acceleration profile 0
[1382972.599] (**) USB Optical Mouse: (accel) acceleration factor: 2.000
[1382972.599] (**) USB Optical Mouse: (accel) acceleration threshold: 4
[1382972.599] (II) config/udev: Adding input device USB Optical Mouse (/dev/input/mouse0)
[1382972.599] (II) No input driver specified, ignoring this device.
[1382972.599] (II) This device may have been added with another device file.
[1382972.600] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event2)
[1382972.600] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[1382972.600] (II) Using input driver 'evdev' for 'AT Translated Set 2 keyboard'
[1382972.600] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[1382972.600] (**) AT Translated Set 2 keyboard: always reports core events
[1382972.600] (**) evdev: AT Translated Set 2 keyboard: Device: "/dev/input/event2"
[1382972.600] (--) evdev: AT Translated Set 2 keyboard: Vendor 0x1 Product 0x1
[1382972.600] (--) evdev: AT Translated Set 2 keyboard: Found keys
[1382972.600] (II) evdev: AT Translated Set 2 keyboard: Configuring as keyboard
[1382972.600] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input2/event2"
[1382972.600] (**) Option "xkb_rules" "evdev"
[1382972.600] (**) Option "xkb_model" "pc105"
[1382972.600] (**) Option "xkb_layout" "de"
[1383001.363] (II) Open ACPI successful (/var/run/acpid.socket)
[1383001.364] (II) VESA(0): Setting up VESA Mode 0x118 (1024x768)
[1383207.604] (II) evdev: Power Button: Close
[1383207.604] (II) UnloadModule: "evdev"
[1383207.604] (II) Unloading evdev
[1383207.684] (II) evdev: Video Bus: Close
[1383207.684] (II) UnloadModule: "evdev"
[1383207.684] (II) Unloading evdev
[1383207.764] (II) evdev: Power Button: Close
[1383207.764] (II) UnloadModule: "evdev"
[1383207.764] (II) Unloading evdev
[1383207.844] (II) evdev: HP 1.0MP High Definition Webcam: Close
[1383207.844] (II) UnloadModule: "evdev"
[1383207.844] (II) Unloading evdev
[1383207.924] (II) evdev: NOVATEK USB Keyboard: Close
[1383207.924] (II) UnloadModule: "evdev"
[1383207.924] (II) Unloading evdev
[1383208.004] (II) evdev: NOVATEK USB Keyboard: Close
[1383208.004] (II) UnloadModule: "evdev"
[1383208.004] (II) Unloading evdev
[1383208.084] (II) evdev: USB Optical Mouse: Close
[1383208.084] (II) UnloadModule: "evdev"
[1383208.084] (II) Unloading evdev
[1383208.164] (II) evdev: AT Translated Set 2 keyboard: Close
[1383208.164] (II) UnloadModule: "evdev"
[1383208.164] (II) Unloading evdev
[1383208.344] ddxSigGiveUp: Closing log
[1383208.344] Server terminated successfully (0). Closing log file.
