Hello and thanks for the reply, rusty1,
No, I have not done that. I did know I could, actually. How can I go about that? Thank you for the link, too, rusty1. At this point I will literally try anything as long as it won’t hurt my mobo. Which should I download, and how can I tell which is a 32bit download? Seems like there is only a 64bit download list. If that is all they have then I could install Ubuntu 12.04 fresh as a 64bit OS.
I have not yet tried Cinnarch (looks great! I love Cinnamon!), but here is a list of all distros I have tried; Ubuntu 12.04 (completely totals everything), Linux Mint (using now), and Kubuntu (refuses to open at all now). I was going to try Linux Arch, but it refuses to install for me freshly. I will download and burn Cinnarch to try next. Is there any tut on installing nvidia drivers available for it?
As for the site at the end, I have tried that one too. I tried their script, same problems, and then their instructions on manual installation, but I got the same results in all distros and all manners of installation.
My thanks,
EDIT:
Running the command “jockey-text --list”, right now with no GPU in, gives me this;
kmod:nvidia_experimental_304 - Experimental NVIDIA binary Xorg driver, kernel module and VDPAU library (Proprietary, Disabled, Not in use)
kmod:nvidia_173 - NVIDIA binary Xorg driver, kernel module and VDPAU library (Proprietary, Disabled, Not in use)
kmod:nvidia_current - nvidia_current (Free, Enabled, Not in use)
kmod:nvidia_current_updates - NVIDIA binary Xorg driver, kernel module and VDPAU library (Proprietary, Disabled, Not in use)
kmod:nvidia_173_updates - NVIDIA binary Xorg driver, kernel module and VDPAU library (Proprietary, Disabled, Not in use)
Since I cannot get into the computer with the GPU in, I cannot give the output of the file sadly…
