Driver Issue with GeForce RTX 3060 Ti - Only 6GB VRAM Detected Instead of 8GB
I am experiencing an issue with my NVIDIA GeForce RTX 3060 Ti where the reported VRAM in nvidia-smi is only 6 GB, while the card is supposed to have 8 GB of GDDR6 VRAM according to the specifications.
Details of my setup:
  • GPU: NVIDIA GeForce RTX 3060 Ti
  • Driver Version: 556.12
  • CUDA Version: 12.5
  • Operating System: Windows 10
Memory Report from nvidia-smi:
| NVIDIA-SMI 556.12                 Driver Version: 556.12         CUDA Version: 12.5     |
| GPU  Name                  Driver-Model | Bus-Id          Disp.A | Volatile Uncorr. ECC |
|   0  NVIDIA GeForce RTX 3060 ...  WDDM  |   00000000:01:00.0 Off |                  N/A |
| N/A   62C    P0             24W /   70W |       0MiB /   6144MiB |      0%      Default |
|                                         |                        |                  N/A |
| Processes:        |
|  GPU   GI   CI        PID   Type   Process name                              GPU Memory |
|        ID   ID                                                               Usage      |
|  No running processes found                                                             |
At the same time, Windows 10 correctly detects and displays the VRAM as 8 GB. But not nvidia-smi and not pytorch.
Hello @Gwwyn and welcome to the NVIDIA developer forums.
Can you tell me the exact brand and model of the GPU?
And can you please post the same output of nvidia-smi from your Windows 10 installation? You can tun it from the command shell just like on Linux, just append the .exe at the end.
